blahhumbug
 - Apr 25, 2015
I recently built my first FreeNAS box using 8xWD Red 3TB (WD30EFRX) drives.  As part of my initial system checks I ran memtest86 for 48 hours and then ran the following tests in parallel across all 8 drives:
smartctl -t short
smartctl -t conveyance
smartctl -t long
smartctl -a
smartctl reported no errors and all tests passed across all 8 drives. At this point I created a raid-z2 volume on the drives so that I could play around with configuring some jails. While I did this I let jgreco's solnet-array-test-v2.sh script run which does many parallel dd read tasks. This script ran for ~48 hours before completing. I then halted my jails and detached the raid-z2 volume and ran the following tests:
badblocks -ns #non-destructive test
smartctl -t long
smartctl -a
On 1 out of 8 of the drives, I got the following smartctl report.
The SMART error log shows "No Errors Logged", but the Extended Offline test lists "Completed: read failure" and shows an LBA with error. Multi_Zone_Error_Rate now has a raw_value of 1, although value/worst/thresh are unchanged and match all the passing drives. Does no 'errors-logged' indidcate that maybe a bad sector was remapped? But I do not know what kind of encoding WD uses for this smart attribute, so that number may not be a cause for concern?
I was expecting to see a non-zero Current_Pending_Sector count, but since it did not change, I'm unsure how serious this is. I ran the extended-offline test once more and got the same failure at the same LBA. Still "No Errors Logged" and Multi_Zone_Error_Rate remaine the same as above.
My assumption is that this is an issue worthy of an immediate RMA. But I wanted to ping the experts here to make sure I'm not misunderstanding the SMART results, or if there are any additional steps I should take or tests I should perform before doing an RMA?
I saw a few threads elsewhere talking about using fdisk and a few other utilities to determine a block location then using dd to get the drive to remap the bad block, but in those cases Current_Pending_Count was non-zero, so I'm not sure that applies in this case.
If needed, the full system hardware specs can be found in this post:
https://forums.freenas.org/index.php?threads/first-nas-build-avoton-8-core-and-24tb-wd-red.30460/
The drive in question is /dev/ada3, attached to SATA_3 on an Asrock C2750D4I (Intel Sata2.0 port, not one of the Marvell). It is in the 4th bay from the bottom of a Silverstone DS380B case.
After a few hours of stress testing with the parallel dd read script, I did observe that the drive reached 43C. This fluctuated a little during the dd reads, but mostly remained above 40C during random spot checks over the 2 days it ran. The drive at the top of the case also reached 43C, but all others remained under 40C. While this temperature is higher than I would like, I'm not sure it's an immediate cause for concern. When idle or under normal use-case load, the drive does stay between 35C and 39C.
			smartctl -t short
smartctl -t long
smartctl -a
smartctl -t long
smartctl -a
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-************
LU WWN Device Id: * ****** *********
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Wed May  6 19:35:29 2015 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      ( 113) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (39540) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 397) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       145
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       42
194 Temperature_Celsius     0x0022   115   109   000    Old_age   Always       -       35
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       1
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed: read failure       10%       138         901099712
# 2  Extended offline    Completed without error       00%        32         -
# 3  Conveyance offline  Completed without error       00%        24         -
# 4  Short offline       Completed without error       00%        24         -
