BigDave
FreeNAS Enthusiast
- Oct 6, 2013
These drives (smart tests shown below) are part of a test platform contained in my new CSE-836 chassis build.
I purchased 16 used/refurbished drives (40GB) for <$3 each for the intended purpose of testing the backplane.
I just recently set up SMART testing a couple of weeks ago and logged in to SSH when the forum went down
around lunch time today (I was bored). I was shocked to see some of the drives have a huge number for atribute #9
I'm interested to see the Brand Names/Model Numbers that will surface in the responses,
come on, dig out those oldies but goodies!
Can anyone beat my 6 MILLION hours?
You must run a passed SMART test (long or short) in order to have bragging rights. Let's have some fun! Here's mine...
Here is the other Samsung drive
Oopsie, We have to raise the benchmark! Check this out...
[root@brookhollow] ~# smartctl -a /dev/da7 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: SAMSUNG SP0411C Serial Number: S048J20Y754240 Firmware Version: UU100-05 User Capacity: 40,020,664,320 bytes [40.0 GB] Sector Size: 512 bytes logical/physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA/ATAPI-7 T13/1532D revision 0 Local Time is: Fri Nov 11 11:59:07 2016 CST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 1500) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 25) minutes. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 100 100 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0007 100 100 025 Pre-fail Always - 4800 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 852 5 Reallocated_Sector_Ct 0x0033 100 100 011 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 100 100 051 Pre-fail Always - 0 8 Seek_Time_Performance 0x0025 100 100 015 Pre-fail Offline - 0 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 4543413 10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0 11 Calibration_Retry_Count 0x0012 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 487 194 Temperature_Celsius 0x0022 133 088 000 Old_age Always - 35 195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 2112314 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x000a 100 100 051 Old_age Always - 0 201 Soft_Read_Error_Rate 0x000a 100 100 051 Old_age Always - 0 (edit: content removed for brevity) SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 37851 - # 2 Extended offline Completed without error 00% 37762 - # 3 Short offline Completed without error 00% 37578 - SMART Selective self-test log data structure revision number 0 Note: revision number not 1 implies that no selective self-test has ever been run SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
[root@brookhollow] ~# smartctl -a /dev/da8 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: SAMSUNG SP0411C/R Serial Number: S0DAJ1IL314296 Firmware Version: UU100-05 User Capacity: 40,020,664,320 bytes [40.0 GB] Sector Size: 512 bytes logical/physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA/ATAPI-7 T13/1532D revision 0 Local Time is: Fri Nov 11 12:03:43 2016 CST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 1500) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 25) minutes. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 100 100 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0007 100 100 025 Pre-fail Always - 4544 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 199 5 Reallocated_Sector_Ct 0x0033 100 100 011 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 100 100 051 Pre-fail Always - 0 8 Seek_Time_Performance 0x0025 100 100 015 Pre-fail Offline - 0 9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 4212267 10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0 11 Calibration_Retry_Count 0x0012 100 100 000 Old_age Always - 17 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 184 194 Temperature_Celsius 0x0022 139 088 000 Old_age Always - 33 195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 693423 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x000a 100 100 051 Old_age Always - 0 201 Soft_Read_Error_Rate 0x000a 100 100 051 Old_age Always - 0
[root@brookhollow] ~# smartctl -a /dev/da12 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: SAMSUNG SP0411C Serial Number: S048J10X966410 Firmware Version: UU100-05 User Capacity: 40,020,664,320 bytes [40.0 GB] Sector Size: 512 bytes logical/physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA/ATAPI-7 T13/1532D revision 0 Local Time is: Fri Nov 11 12:21:25 2016 CST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 1500) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 25) minutes. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 098 097 051 Pre-fail Always - 1740 3 Spin_Up_Time 0x0007 100 100 025 Pre-fail Always - 4864 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 249 5 Reallocated_Sector_Ct 0x0033 100 100 011 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 100 100 051 Pre-fail Always - 0 8 Seek_Time_Performance 0x0025 100 100 015 Pre-fail Offline - 0 9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 6541445 10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0 11 Calibration_Retry_Count 0x0012 100 100 000 Old_age Always - 2 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 184 194 Temperature_Celsius 0x0022 127 088 000 Old_age Always - 37 195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 15565615 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x000a 100 100 051 Old_age Always - 0 201 Soft_Read_Error_Rate 0x000a 100 100 051 Old_age Always - 0
