Lots of problems here:
- 6744 reallocated (bad) sectors
- 992 pending sectors
- 992 offline uncorrectable sectors
- No long SMART tests in the log
- The disk's running hot (though that's a more minor concern)
I'd say it's time to replace the disk, but should be well within its warranty period.
Hello
I have the same problem can you tell me if my disk can be fixed
root@freenas[~]# smartctl -x /dev/da11
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke,
www.smartmontools.org
Device Model: WDC WD80PURZ-85YNPY0
Serial Number: R6GM4JBY
LU WWN Device Id: 5 000cca 263c8b40c
Firmware Version: 80.H0A80
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri Oct 30 17:07:08 2020 CDT
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 101) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1117) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0
2 Throughput_Performance P-S--- 133 133 054 - 108
3 Spin_Up_Time POS--- 145 145 024 - 454 (Average 454)
4 Start_Stop_Count -O--C- 100 100 000 - 34
5 Reallocated_Sector_Ct PO--CK 100 100 005 - 0
7 Seek_Error_Rate PO-R-- 100 100 067 - 0
8 Seek_Time_Performance P-S--- 128 128 020 - 18
9 Power_On_Hours -O--C- 097 097 000 - 22762
10 Spin_Retry_Count PO--C- 100 100 060 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 21
22 Unknown_Attribute PO---K 100 100 025 - 100
192 Power-Off_Retract_Count -O--CK 100 100 000 - 959
193 Load_Cycle_Count -O--C- 100 100 000 - 959
194 Temperature_Celsius -O---- 253 253 000 - 22 (Min/Max 18/45)
196 Reallocated_Event_Count -O--CK 100 100 000 - 0
197 Current_Pending_Sector -O---K 100 100 000 - 0
198 Offline_Uncorrectable ---R-- 100 100 000 - 48
199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 1 Comprehensive SMART error log
0x03 GPL R/O 1 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x12 GPL R/O 1 SATA NCQ Non-Data log
0x15 GPL,SL R/W 1 Rebuild Assist log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x24 GPL R/O 256 Current Device Internal Status Data log
0x25 GPL R/O 256 Saved Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed: read failure 90% 22608 15336154928
# 2 Short offline Completed: read failure 90% 22608 15336154928
# 3 Short offline Completed: read failure 90% 22608 15336154928
# 4 Short offline Completed: read failure 90% 22608 15336154928
# 5 Short offline Completed: read failure 90% 22608 15336154928
# 6 Short offline Completed: read failure 90% 22608 15336154928
# 7 Short offline Completed: read failure 90% 22490 15336154928
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 256 (0x0100)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 22 Celsius
Power Cycle Min/Max Temperature: 21/25 Celsius
Lifetime Min/Max Temperature: 18/45 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/65 Celsius
Min/Max Temperature Limit: -40/70 Celsius
Temperature History Size (Index): 128 (42)
Index Estimated Time Temperature Celsius
43 2020-10-30 15:00 23 ****
... ..( 20 skipped). .. ****
64 2020-10-30 15:21 23 ****
65 2020-10-30 15:22 22 ***
66 2020-10-30 15:23 23 ****
67 2020-10-30 15:24 22 ***
... ..( 71 skipped). .. ***
11 2020-10-30 16:36 22 ***
12 2020-10-30 16:37 23 ****
... ..( 14 skipped). .. ****
27 2020-10-30 16:52 23 ****
28 2020-10-30 16:53 22 ***
... ..( 12 skipped). .. ***
41 2020-10-30 17:06 22 ***
42 2020-10-30 17:07 23 ****
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 2) ==
0x01 0x008 4 21 --- Lifetime Power-On Resets
0x01 0x018 6 79523709041 --- Logical Sectors Written
0x01 0x020 6 1423168685 --- Number of Write Commands
0x01 0x028 6 92763538599 --- Logical Sectors Read
0x01 0x030 6 549696124 --- Number of Read Commands
0x01 0x038 6 81944890250 --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 22502 --- Spindle Motor Power-on Hours
0x03 0x010 4 22502 --- Head Flying Hours
0x03 0x018 4 959 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 310924 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 2 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 22 --- Current Temperature
0x05 0x010 1 21 N-- Average Short Term Temperature
0x05 0x018 1 30 N-- Average Long Term Temperature
0x05 0x020 1 45 --- Highest Temperature
0x05 0x028 1 18 --- Lowest Temperature
0x05 0x030 1 42 N-- Highest Average Short Term Temperature
0x05 0x038 1 19 N-- Lowest Average Short Term Temperature
0x05 0x040 1 37 N-- Highest Average Long Term Temperature
0x05 0x048 1 25 N-- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 65 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 0 --- Number of Hardware Resets
0x06 0x010 4 0 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 1 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 1 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
