angelus249
- Dec 19, 2014
Hello together,
I run the latest 9.3.0 with all updates, 4x 4TB in a RAID-Z configuration. The WebGUI storage section gives me a healthy status, however I seem to have a problem with my ada3 disk. Not sure though, how to interpret the reads.
I see "SMART overall-health self-assessment test result: PASSED", but compared to the other 3 disks, a few values differ, those respectively:
These are read errors, right? Should I be worried? The disks are fairly new.
Also, one last question. If I remove the drive for RMA, can I use/access my storage in the meantime (without the parity bit/disk so to speak)?
Cheers
[root@NAS] ~# smartctl -i -H -A -l error /dev/ada3
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p5 amd64] (local build)
Device Model: TOSHIBA MD04ACA400
Serial Number: xxx
LU WWN Device Id: 5 000039 58bd8262c
Firmware Version: FP1A
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Dec 19 16:10:02 2014 CET
SMART support is: Enabled
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 7289
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 224
7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 1392
10 Spin_Retry_Count 0x0033 100 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 67
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 6
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 20
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 36 (Min/Max 17/51)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 25
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 136
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 253 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 0
222 Loaded_Hours 0x0032 097 097 000 Old_age Always - 1392
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 296
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
ATA Error Count: 378 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 378 occurred at disk power-on lifetime: 1391 hours (57 days + 23 hours)
ER ST SC SN CL CH DH
40 41 18 58 7e ce 40 Error: WP at LBA = 0x00ce7e58 = 13532760
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 10 58 e8 a5 99 40 00 00:10:17.236 WRITE FPDMA QUEUED
61 18 58 b8 79 40 40 00 00:10:17.236 WRITE FPDMA QUEUED
61 10 58 70 79 40 40 00 00:10:17.235 WRITE FPDMA QUEUED
61 20 58 88 7e 40 40 00 00:10:17.235 WRITE FPDMA QUEUED
61 08 58 60 7e 40 40 00 00:10:17.235 WRITE FPDMA QUEUED
Error 377 occurred at disk power-on lifetime: 1391 hours (57 days + 23 hours)
40 41 c0 d0 5b cd 40 Error: UNC at LBA = 0x00cd5bd0 = 13458384
60 08 00 18 49 d2 40 00 00:10:12.836 READ FPDMA QUEUED
60 08 f8 78 a6 0a 40 00 00:10:12.824 READ FPDMA QUEUED
60 08 f0 70 ae cf 40 00 00:10:12.796 READ FPDMA QUEUED
60 90 e8 b8 ad 7d 40 00 00:10:12.774 READ FPDMA QUEUED
60 48 e0 48 8d 7d 40 00 00:10:12.774 READ FPDMA QUEUED
Error 376 occurred at disk power-on lifetime: 1391 hours (57 days + 23 hours)
40 41 10 f0 aa cd 40 Error: UNC at LBA = 0x00cdaaf0 = 13478640
60 20 10 e0 aa cd 40 00 00:10:03.618 READ FPDMA QUEUED
61 08 08 f8 bd c0 40 00 00:10:03.618 WRITE FPDMA QUEUED
61 08 00 f8 bb c0 40 00 00:10:03.618 WRITE FPDMA QUEUED
61 08 f8 f8 03 40 40 00 00:10:03.618 WRITE FPDMA QUEUED
61 08 f0 f8 01 40 40 00 00:10:03.618 WRITE FPDMA QUEUED
Error 375 occurred at disk power-on lifetime: 1391 hours (57 days + 23 hours)
40 41 98 48 51 cc 40 Error: UNC at LBA = 0x00cc5148 = 13390152
60 08 a0 50 d2 d1 40 00 00:09:56.409 READ FPDMA QUEUED
60 08 98 48 51 cc 40 00 00:09:56.409 READ FPDMA QUEUED
ef 02 00 00 00 00 40 00 00:09:56.409 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 40 00 00:09:56.408 SET FEATURES [Enable read look-ahead]
c6 00 10 00 00 00 40 00 00:09:56.408 SET MULTIPLE MODE
Error 374 occurred at disk power-on lifetime: 1391 hours (57 days + 23 hours)
40 41 90 48 51 cc 40 Error: UNC at LBA = 0x00cc5148 = 13390152
60 08 98 50 d2 d1 40 00 00:09:50.318 READ FPDMA QUEUED
60 08 90 48 51 cc 40 00 00:09:50.318 READ FPDMA QUEUED
60 08 88 50 b6 cd 40 00 00:09:50.318 READ FPDMA QUEUED
ef 02 00 00 00 00 40 00 00:09:50.317 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 40 00 00:09:50.317 SET FEATURES [Enable read look-ahead]
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 11 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 224 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 67 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 25 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 136
Cheers
