I have been receiving some SMART errors on one of my six drives. I have the drives in a RAID-Z2 configuration (4 data + 2 redundancy). These SMART errors seem to only show up on one of the drives, but I am unfamiliar with what to make of them. Can someone help me understand them or point me in the right direction?
Thank you
Below is the output. Notice the errors only show for ada0.
Thank you
########## ZPool status report for storage ##########
pool: storage
state: ONLINE
scan: scrub repaired 0 in 0 days 01:20:40 with 0 errors on Mon Jul 1 02:20:41 2019
NAME STATE READ WRITE CKSUM
storage ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/deb50bc2-b2fd-11e7-94b1-ac1f6b1956d2 ONLINE 0 0 0
gptid/df39ddfb-b2fd-11e7-94b1-ac1f6b1956d2 ONLINE 0 0 0
gptid/dfbf39bd-b2fd-11e7-94b1-ac1f6b1956d2 ONLINE 0 0 0
gptid/e04ea62a-b2fd-11e7-94b1-ac1f6b1956d2 ONLINE 0 0 0
gptid/e0d14e92-b2fd-11e7-94b1-ac1f6b1956d2 ONLINE 0 0 0
gptid/e155e419-b2fd-11e7-94b1-ac1f6b1956d2 ONLINE 0 0 0
errors: No known data errors
########## SMART status report for ada0 drive (Western Digital Red: 7SGEEVGC) ##########
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0004 128 128 054 Old_age Offline - 116
3 Spin_Up_Time 0x0007 199 199 024 Pre-fail Always - 267 (Average 394)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 31
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0
8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 9141
10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 31
22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 403
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 403
194 Temperature_Celsius 0x0002 166 166 000 Old_age Always - 39 (Min/Max 24/42)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
ATA Error Count: 31 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 31 occurred at disk power-on lifetime: 62 hours (2 days + 14 hours)
When the command that caused the error occurred, the device was doing SMART Offline or Self-test.
ER ST SC SN CL CH DH
40 41 00 00 00 00 00 Error: UNC at LBA = 0x00000000 = 0
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 08 80 c8 ae 80 40 08 2d+14:00:42.940 READ FPDMA QUEUED
2f 00 01 10 00 00 00 08 2d+14:00:40.215 READ LOG EXT
60 08 70 c8 ae 80 40 08 2d+14:00:37.469 READ FPDMA QUEUED
2f 00 01 10 00 00 00 08 2d+14:00:37.465 READ LOG EXT
60 08 60 c8 ae 80 40 08 2d+14:00:34.719 READ FPDMA QUEUED
Error 30 occurred at disk power-on lifetime: 62 hours (2 days + 14 hours)
60 08 70 c8 ae 80 40 08 2d+14:00:40.215 READ FPDMA QUEUED
2f 00 01 10 00 00 00 08 2d+14:00:34.715 READ LOG EXT
60 08 50 c8 ae 80 40 08 2d+14:00:31.860 READ FPDMA QUEUED
Error 29 occurred at disk power-on lifetime: 62 hours (2 days + 14 hours)
60 08 60 c8 ae 80 40 08 2d+14:00:37.465 READ FPDMA QUEUED
2f 00 01 10 00 00 00 08 2d+14:00:31.857 READ LOG EXT
60 08 40 c8 ae 80 40 08 2d+14:00:29.158 READ FPDMA QUEUED
Error 28 occurred at disk power-on lifetime: 62 hours (2 days + 14 hours)
60 08 50 c8 ae 80 40 08 2d+14:00:34.715 READ FPDMA QUEUED
60 08 38 c0 ae 80 40 08 2d+14:00:29.158 READ FPDMA QUEUED
60 08 30 b8 ae 80 40 08 2d+14:00:29.157 READ FPDMA QUEUED
Error 27 occurred at disk power-on lifetime: 62 hours (2 days + 14 hours)
60 08 40 c8 ae 80 40 08 2d+14:00:31.856 READ FPDMA QUEUED
60 08 28 b0 ae 80 40 08 2d+14:00:29.157 READ FPDMA QUEUED
60 08 20 a8 ae 80 40 08 2d+14:00:29.157 READ FPDMA QUEUED
Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
Extended offline Completed without error 00% 8653 -
Short offline Completed without error 00% 9096 -
########## SMART status report for ada1 drive (Western Digital Red: 7SGEGHRC) ##########
2 Throughput_Performance 0x0004 128 128 054 Old_age Offline - 117
3 Spin_Up_Time 0x0007 196 196 024 Pre-fail Always - 270 (Average 400)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 404
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 404
194 Temperature_Celsius 0x0002 158 158 000 Old_age Always - 41 (Min/Max 25/44)
No Errors Logged
Extended offline Completed without error 00% 8651 -
########## SMART status report for ada2 drive (Western Digital Red: 7SGB3U0C) ##########
2 Throughput_Performance 0x0004 129 129 054 Old_age Offline - 112
3 Spin_Up_Time 0x0007 189 189 024 Pre-fail Always - 266 (Average 429)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 33
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 33
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 406
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 406
194 Temperature_Celsius 0x0002 166 166 000 Old_age Always - 39 (Min/Max 25/42)
No Errors Logged
########## SMART status report for ada3 drive (Western Digital Red: 7SGERNKC) ##########
3 Spin_Up_Time 0x0007 185 185 024 Pre-fail Always - 273 (Average 437)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 32
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 32
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 405
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 405
No Errors Logged
########## SMART status report for ada4 drive (Western Digital Red: 7SGD9UZC) ##########
3 Spin_Up_Time 0x0007 198 198 024 Pre-fail Always - 271 (Average 394)
194 Temperature_Celsius 0x0002 158 158 000 Old_age Always - 41 (Min/Max 25/43)
No Errors Logged
########## SMART status report for ada5 drive (Western Digital Red: 7SGEG9GC) ##########
2 Throughput_Performance 0x0004 130 130 054 Old_age Offline - 108
3 Spin_Up_Time 0x0007 195 195 024 Pre-fail Always - 275 (Average 399)
194 Temperature_Celsius 0x0002 166 166 000 Old_age Always - 39 (Min/Max 25/43)
No Errors Logged
