I keep getting ATA errors. I'm not sure if the HDD's are failing, but I keep getting Errors on different drives, but they all Pass SMART test. Also I can't see anything suspicious in the smart reports. Maybe the issue is with the SATA cables, HBA or CPU/Mainboard!? I just replaced the PSU, so that should not be the issue.
My System:
4x 10TB WD Red RAIDZ1
3x 4TB Seagate IronWolf RAIDZ2
Intel Xeon E3-1230 V2
MSI MS-S0121 LGA1155
2x8GB DDR3 ECC Memory (I know, the system could use more)
Corsair RM750x (Brandnew. just replaced my old PSU, thought the Errors might be caused by the previous old PSU)
LSI SAS2008 H310
My System:
LSI SAS2008 H310
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD100EFAX-68LHPN0
Serial Number: 1DGP88BZ
LU WWN Device Id: 5 000cca 26cc9aad6
Firmware Version: 83.H0A83
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 31 13:16:45 2022 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 93) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1070) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 094 094 016 Pre-fail Always - 1703936
2 Throughput_Performance 0x0004 130 130 054 Old_age Offline - 108
3 Spin_Up_Time 0x0007 165 165 024 Pre-fail Always - 381 (Average 414)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 3564
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0
8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18
9 Power_On_Hours 0x0012 095 095 000 Old_age Always - 38926
10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2955
22 Helium_Level 0x0023 099 099 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 096 096 000 Old_age Always - 4999
193 Load_Cycle_Count 0x0012 096 096 000 Old_age Always - 4999
194 Temperature_Celsius 0x0002 138 138 000 Old_age Always - 47 (Min/Max 22/56)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 55 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 55 occurred at disk power-on lifetime: 38926 hours (1621 days + 22 hours)
ER ST SC SN CL CH DH
40 41 00 00 00 00 00 Error: UNC at LBA = 0x00000000 = 0
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 28 a0 e9 b5 40 00 02:59:26.432 READ FPDMA QUEUED
60 b0 00 18 ed b5 40 00 02:59:19.490 READ FPDMA QUEUED
60 b0 08 b8 eb b5 40 00 02:59:19.476 READ FPDMA QUEUED
60 c0 30 a0 ea b5 40 00 02:59:19.356 READ FPDMA QUEUED
60 00 20 a0 e8 b5 40 00 02:59:19.356 READ FPDMA QUEUED
Error 54 occurred at disk power-on lifetime: 38926 hours (1621 days + 22 hours)
60 00 10 20 06 c6 40 00 02:58:53.936 READ FPDMA QUEUED
61 18 28 28 bf 3d 40 00 02:58:47.353 WRITE FPDMA QUEUED
60 88 20 20 08 c6 40 00 02:58:47.009 READ FPDMA QUEUED
60 00 18 20 07 c6 40 00 02:58:47.009 READ FPDMA QUEUED
60 00 08 20 05 c6 40 00 02:58:47.009 READ FPDMA QUEUED
Error 53 occurred at disk power-on lifetime: 38926 hours (1621 days + 22 hours)
60 00 10 20 03 c6 40 00 02:58:46.742 READ FPDMA QUEUED
61 18 40 c8 ba 3d 40 00 02:58:40.153 WRITE FPDMA QUEUED
61 10 50 90 fc 3f 40 00 02:58:39.797 WRITE FPDMA QUEUED
61 10 48 90 fa 3f 40 00 02:58:39.797 WRITE FPDMA QUEUED
61 10 40 90 02 40 40 00 02:58:39.797 WRITE FPDMA QUEUED
Error 52 occurred at disk power-on lifetime: 38926 hours (1621 days + 22 hours)
60 e0 38 38 00 c6 40 00 02:58:39.525 READ FPDMA QUEUED
61 18 40 b0 ba 3d 40 00 02:58:32.670 WRITE FPDMA QUEUED
60 00 30 38 ff c5 40 00 02:58:32.566 READ FPDMA QUEUED
60 00 28 38 fe c5 40 00 02:58:32.566 READ FPDMA QUEUED
60 00 20 38 fd c5 40 00 02:58:32.566 READ FPDMA QUEUED
Error 51 occurred at disk power-on lifetime: 38926 hours (1621 days + 22 hours)
60 00 10 f8 ae bb 40 00 02:57:20.485 READ FPDMA QUEUED
60 28 68 88 d6 bb 40 00 02:57:13.320 READ FPDMA QUEUED
60 00 60 88 d5 bb 40 00 02:57:13.320 READ FPDMA QUEUED
60 00 58 88 d4 bb 40 00 02:57:13.320 READ FPDMA QUEUED
60 78 50 68 d2 bb 40 00 02:57:13.320 READ FPDMA QUEUED
# 1 Short offline Completed without error 00% 38914 -
# 2 Short offline Completed without error 00% 38889 -
# 3 Short offline Completed without error 00% 38865 -
# 4 Short offline Completed without error 00% 38841 -
# 5 Short offline Completed without error 00% 38817 -
# 6 Short offline Completed without error 00% 38799 -
# 7 Short offline Completed without error 00% 38775 -
# 8 Short offline Completed without error 00% 38751 -
# 9 Short offline Completed without error 00% 38727 -
#10 Short offline Completed without error 00% 38703 -
#11 Short offline Completed without error 00% 38679 -
#12 Short offline Completed without error 00% 38655 -
#13 Short offline Completed without error 00% 38631 -
#14 Short offline Completed without error 00% 38607 -
#15 Short offline Completed without error 00% 38583 -
#16 Short offline Completed without error 00% 38564 -
#17 Short offline Completed without error 00% 38535 -
#18 Short offline Completed without error 00% 38511 -
#19 Short offline Completed without error 00% 38488 -
#20 Short offline Completed without error 00% 38464 -
#21 Short offline Completed without error 00% 38440 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
