No access to SMB-shares after upgrade 11.3-U5 to Truenas 12.0
rolfhartmut
After upgrading my shares are no longer accessible from WIN 10 like \\freenas\xxx but only with ip-adress. What can I do??
Same behaviour when creating a new share.
AirborneTrooper
Did you change your local host name? You can try flushing dns if you're on windows to see if that helps.
rolfhartmut
No, didn´t change hostname and flushdns didn´t help.
rolfhartmut
Went back to 11.3-u5 and everything is fine!
rolfhartmut
Netbios was enabled.
I found a solution: I had to enable guest access for each share, not necessary in 11.3-U5
Whe3zy
I think I'm having similar issues. Ive enabled Allow Guest Access but still cant see the files within my folder structure. Only the folders themselves are visible.
gwaitsi
my was working under 11.3U5 but stopped working (other than for existing mapped devices/accounts) till i upgraded.
added "enable web service discovery=yes" to the smb auxillary parameters and problem was solved.
Whe3zy
If you dont mind me asking how did you do that?
When I attempt to add the suggested.....
I am presented with the following....
anodos
Sambassador
Yeah, that fails because it's an illegal parameter for a share. We do minimum validation of auxiliary parameters. In this case Samba's libparam is raising an exception about your parameter.
gwaitsi
gwaitsi
