Stefan Krieger
- Jan 11, 2016
I'm considering the following build:
SUPERMICRO MBD-X10SRL-F Server Motherboard LGA 2011 R3 ($234)
Intel Xeon E5-1620 v3 Haswell-EP 3.5 GHz LGA 2011-3 ($308)
Crucial 64GB (4 x 16GB = 64GB) 288-Pin DDR4 SDRAM ECC DDR4 2133 (PC4 17000) ($464)
SeaSonic Platinum SS-860XP2 860W ATX12V / EPS12V ($150)
2x SanDisk Cruzer Fit 32 GB USB 2.0 Flash Drive (2x $15) as mirrored boot drives
SAMSUNG 850 EVO 2.5" 250GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E250B/AM ($95) for jails
Fractal Design Define R5 FD-CA-DEF-R5-BK Black Computer Case ($90)
2x Fractal Design Silent Series R2 FD-FAN-SSR2-140 140mm 140mm Fan (2x $15) as extra fans
8x WD Red 6TB HDD for a RaidZ2 ($245)
Researching FreeNas I had my usual cost escalating enthusiasms: looking Supermicro boards with SAS controllers, separate SAS/SATA controller cards, SAS drives, faster CPUs, X11 boards, Supermicro chassis with more bays. The one cost escalating enthusiasm left is buying lots of RAM since ZFS is RAM hungry. I could scale back and just get 32GB now, adding more RAM later if useful, but it appears that is asking for noticeably worse performance. I did go with a LGA 2011-3 board to have the ability go beyond the X10 LGA 1150 board 32GB limit (and not experience driver frustration with 64GB limited LGA 1151 X11 boards). Still thinking of going with the E5-1650 v3, but it is a big price bump at $570 (not at Newegg, using Google shopping instead here, I assume 4/5 star vendors are okay). I did consider SAS drives, but for my use cases (see below) it very much doesn't seem worth the extra $600+ for disks and controller.
The purpose of this NAS would be, for the most part, to be one of my backups (mostly many TB of photos, some music) and a video server (currently running Plex and Serviio on my Win 7 machine) for non-backed up video. I assume I'll find things to do in jails beyond that. 4K streaming should show up in the next two years. I found FreeNas by thinking I could do better than paying QNAP or Synology $999 for an 8-bay machine with a slow CPU and little RAM. And I'd learn more and have more fun if I built a FreeNas machine. My current desktop is no longer doubly backed up for my important data and some stuff isn't backed up at all anymore. 13 disks on a Win 7 is probably enough too...I don't want to add to that.
I'm putting in 8x 6TB immediately, since the overhead cost of RaidZ2 seems to warrant it. The case won't take more than 3 more drives (with an adapter for the 5.25 bay), so I'll need to move to a new case for a 2nd vdev, but that's probably far enough in the future that I don't need to plan for it now (and the R3 case is only $90). I could see using a smaller PSU, but I like being on the larger safe side (I could be talked in to a larger PSU) and I might end up using this PSU elsewhere in the future as well. I am planning on using the stock cooler, but I might go with a narrow R2011-3 cooler, most likely Noctua NH-U12DX i4 ($64), instead if the stock cooler is loud.
So 32GB now with the option to go to 64GB, or just go to 64GB now? E5-1620 v3 or E5-1650 v3? Anything else? Am I being stupid/silly somewhere?
And looking at cost of 8x 6TB disks the QNAP/Synology approach with pay-as-you-go raid expansion does seem attractive...
Thanks!
Thanks!
