Network Performance with Truenas
ianmontana
Newbie
Hi
I'm hoping someone can assist me with the network speed issues I'm currently experiencing - I have two servers connected via a 10GB switch
One server is running Unraid and the other Truenas Core
I've set a rsynch batch running in unraid to copy over to the Truenas server as a backup - Truenas recognizes the card as 10Gbase-SR
My issue is the speed, nothing much going on in the network and the transfer is running at 8 - 10 MiB/s which is really disappointing after upgrading my network
Are there any settings I can review to check or improve whats going on ?'
Thanks in anticipation
Ian
ChrisRJ
Senior Member
Welcome! Please be so kind and check the forums rules and what level of technical detail is required to give reasonable recommendations.
jenksdrummer
Member
I noticed replication between TrueNAS (or FreeNAS) boxes was on the slow side, but then discovered that it can use netcat; which greatly improves performance. In your situation, perhaps consider if you're using encryption as that will also cause it to slow down; create a dedicated replication vlan and not worry about the traffic being encrypted ;)
