kepford
- Sep 28, 2021
Version: TrueNAS-12.0-U2
Hardware: TrueNAS Mini E+
* 4-Core 2.2GHz Intel Processor
* 16GB of High-speed ECC Memory
* 4x 1GbE NICs
Note: I'm pretty new to TrueNAS
* While I was working on one of my VMs on TrueNAS I noticed some odd errors when I tried to create a new VM.
* Saw SQL errors in the web GUI
* I tried checking for updates to TrueNAS and that produced similar errors
* Thought I would try just rebooting. That was a mistake.
* Network services never started after reboot
* Had to hook up a monitor and keyboard because the server never came back on the network
* Not able to ping external or internal addresses from TrueNAS console. Have no network connection
* In the console running `ifconfig` shows that none of the interfaces (two of which are plugged into my switch and are lighting up) are connected or have IPs
* NIC lights up and shows up with `ifconfig`. Therefore I don't believe this is a hardware issue.
* I tried running `/etc/netcli` to configure the network interface and see what options I have.
* I get python errors with the netcli commands
* Not sure what is causing all this but it doesn't seem good.
* My best guess is a failed TrueNAS upgrade and I didn't notice the issue until now.
What should I do?
Is there a offline manual update process I can use?
Can I re-install TrueNAS from a thumb drive without losing my existing configuration?
Any pointers or direction appreciated. I'm still learning TrueNAS coming from Linux :)
* 4x 1GbE NICs
What should I do?
