Need Help Moving Systems
JacobM348
So I have 2 old desktops one is running FreeNAS and the other is just a windows one. the FreeNAS machine is in a bigger box and I am in a situation where i want to move it into the windows box. They are old dell optiplex desktops so i cannon change out the motherboards. so pretty much I want to move my drives over to the smaller box, can I just move everything and just boot from the USB again or do I have to go through the whole setup process again. please help
Jailer
Not strong, but bad
You can just move it all over and as long as the hardware is compatible it will work.
JacobM348
thanks, i tried that and it worked. now i just cant activate any plugins, in the old box i never had any problems with them not turning on, but recently ive moved house and had it shutdown for a while, when i tried to get it working today it wouldnt turn any on so i thought that moving the systems will help it fix that issue but nope, im still having it
Jailer
Not strong, but bad
Post your complete hardware specs along with any error messages you are receiving.
