Spacemarine
- Jul 19, 2014
I am happily running two 9.10.2-U6 installations in different locations. I replicate data from one the other every day and both installations are encrypted to protect against physical theft.
I want to upgrade to 11.2-U4.1. I bought 4 new USB-sticks, two for each installation so I can make fresh installations and go back to the old (unchanged) system in case anything goes wrong. Is this assumption correct?
I want to be extra cautious as these systems contain sensitive data. I am therefore worried if I need to take some special care about the encryption or the replication?
Can I just set up replication between the two systems after the re-installation and it will just continue to work where it has stopped? I don't want to copy the entire data again.
Is there anything to consider about the encryption besides what is mentioned in the manual?
Thanks!
Thanks!
