MY POOL FAILS
xames
I have two pools, one with 3 disks, another with 2.
Pool2 is going
Pool1 is offline
My disks of pool2 is showing pool2, my disks on pool1 is not showing nothing.
My jails and default pool disk dissapear.
How i have to proceed, yesterday is working, i don't do anything.
c77dk
We need to know what hardware you're using and how the pools are setup - otherwise there's nothing to suggest where to look. Since you wrote jails, I'm assuming you're using CORE?
xames
Did you check/re-seat the SATA-connections in your server?
Please post the output of zfs list here, in CODE]...[/CODE] brackets.
xames
sorry my keyboard is in germany, im spanish and i dont know how to copy paste with text
The connections are fine i try changing but nothing
Looks like pool Agrupacio1 is offline.
Please post the full specs of the hardware of your server, as is forum rule.
c77dk
what's the output of zpool status ? It normally gives a hint
Davvo
Try zpool status -vx, zpool import Agrupacio1 and zpool online Agrupacio1.
Please provide your hardware specifications.
xames
i don't know exactly hardware specifications its and old asus workstation with i3 or something like that.
xames
its like hdds still there, but pool and jail dissapear, i have a task to shutdown on night and open on mornings, thats all working one year
Davvo
You need to know where are you running TrueNAS because it's not designed to be run on all kinds of hardware.
Please read the following resources:
Davvo
No success with the zpool online command?
You also need to schedule (and read) regular smart tests to verify the health of your drives or they just suddenly die on you.
In order to help you any further, this is important to know. Especially if there is some kind of RAID-card or SATA-controller in play.
xames
But if suddenly die, i have 3 hdd on raid, i put for change one if anyone fails, but these are new, pool dissapear because bad hardware?
Davvo
sata expansor card
Generally that's bad.
Please read the following resource.
Please provide us as much information as possibile, use Google Translate if language is an issue.
Did you try the zpool online Agrupacio1 command?
Also try zpool status Agrupacio1.
