Dataset with path /mnt/<PoolName> not found
Gnrl Kitty
I needed to clone a pool from one drive onto a new pool on a second drive. I followed this guide to do this.
Now when I try to click any link in the UI, I get a blank page:
If I log out and back in or refresh the page, I get taken to this screen:
After I choose the correct settings and try to click save, I get this error:
Dataset with path /mnt/pool1 not found
I'm unable to get into the shell due to it going to a blank page, but if I enter legacy UI I'm able to navigate the UI as normal, including entering the shell. When I use the command zfs list I get this output:
Pool2/.system                                           5.49M  1.73T    96K  /mnt/Pool2/.system
Pool2/.system/configs-32ba719d89394fea981ab0fa19727414  1.46M  1.73T  1.46M  /mnt/Pool2/.system/configs-32ba719d89394fea981ab0fa1972
7414
Pool2/.system/cores                                     3.35M  1.73T  3.35M  /mnt/Pool2/.system/cores
Pool2/.system/rrd-32ba719d89394fea981ab0fa19727414        88K  1.73T    88K  /mnt/Pool2/.system/rrd-32ba719d89394fea981ab0fa19727414
Pool2/.system/samba4                                     268K  1.73T   260K  /mnt/Pool2/.system/samba4
Pool2/.system/syslog-32ba719d89394fea981ab0fa19727414     88K  1.73T    88K  /mnt/Pool2/.system/syslog-32ba719d89394fea981ab0fa19727
414
Pool2/.system/webui                                       88K  1.73T    88K  /mnt/Pool2/.system/webui
Pool2/Data                                              22.6G  1.73T  18.2G  /mnt/Pool2/Data
Pool2/iocage                                             610M  1.73T  3.82M  /mnt/Pool2/iocage
Pool2/iocage/download                                    125M  1.73T    88K  /mnt/Pool2/iocage/download
Pool2/iocage/download/11.2-RELEASE                       125M  1.73T   125M  /mnt/Pool2/iocage/download/11.2-RELEASE
Pool2/iocage/images                                       88K  1.73T    88K  /mnt/Pool2/iocage/images
Pool2/iocage/jails                                      86.0M  1.73T    88K  /mnt/Pool2/iocage/jails
Pool2/iocage/jails/rclone                               85.9M  1.73T    92K  /mnt/Pool2/iocage/jails/rclone
Pool2/iocage/jails/rclone/root                          85.8M  1.73T   476M  /mnt/Pool2/iocage/jails/rclone/root
Pool2/iocage/log                                          92K  1.73T    92K  /mnt/Pool2/iocage/log
Pool2/iocage/releases                                    395M  1.73T    88K  /mnt/Pool2/iocage/releases
Pool2/iocage/releases/11.2-RELEASE                       395M  1.73T    88K  /mnt/Pool2/iocage/releases/11.2-RELEASE
Pool2/iocage/releases/11.2-RELEASE/root                  395M  1.73T   395M  /mnt/Pool2/iocage/releases/11.2-RELEASE/root
Pool2/iocage/templates                                    88K  1.73T    88K  /mnt/Pool2/iocage/templates
freenas-boot                                            6.38G  7.78G    64K  none
freenas-boot/ROOT                                       6.37G  7.78G    29K  none
freenas-boot/ROOT/11.2-U6                               6.37G  7.78G  5.55G  /
freenas-boot/ROOT/Initial-Install                          1K  7.78G   825M  legacy
freenas-boot/ROOT/default                                317K  7.78G   825M  legacy
freenas-boot/grub                                       6.97M  7.78G  6.97M  legacy
pool1                                                   23.2G   876G    92K  /mnt/mnt/pool1
pool1/.system                                           5.67M   876G    96K  legacy
pool1/.system/configs-32ba719d89394fea981ab0fa19727414  1.46M   876G  1.46M  legacy
pool1/.system/cores                                     3.40M   876G  3.35M  legacy
pool1/.system/rrd-32ba719d89394fea981ab0fa19727414        88K   876G    88K  legacy
pool1/.system/samba4                                     336K   876G   236K  legacy
pool1/.system/syslog-32ba719d89394fea981ab0fa19727414     88K   876G    88K  legacy
pool1/.system/webui                                       88K   876G    88K  legacy
pool1/Data                                              22.6G   876G  18.2G  /mnt/mnt/pool1/Data
pool1/iocage                                             611M   876G  3.82M  /mnt/mnt/pool1/iocage
pool1/iocage/download                                    125M   876G    88K  /mnt/mnt/pool1/iocage/download
pool1/iocage/download/11.2-RELEASE                       125M   876G   125M  /mnt/mnt/pool1/iocage/download/11.2-RELEASE
pool1/iocage/images                                       88K   876G    88K  /mnt/mnt/pool1/iocage/images
pool1/iocage/jails                                        86M   876G    88K  /mnt/mnt/pool1/iocage/jails
pool1/iocage/jails/rclone                               85.9M   876G    92K  /mnt/mnt/pool1/iocage/jails/rclone
pool1/iocage/jails/rclone/root                          85.8M   876G   476M  /mnt/mnt/pool1/iocage/jails/rclone/root
pool1/iocage/log                                          92K   876G    92K  /mnt/mnt/pool1/iocage/log
pool1/iocage/releases                                    395M   876G    88K  /mnt/mnt/pool1/iocage/releases
pool1/iocage/releases/11.2-RELEASE                       395M   876G    88K  /mnt/mnt/pool1/iocage/releases/11.2-RELEASE
pool1/iocage/releases/11.2-RELEASE/root                  395M   876G   395M  /mnt/mnt/pool1/iocage/releases/11.2-RELEASE/root
pool1/iocage/templates                                    88K   876G    88K  /mnt/mnt/pool1/iocage/templates
I imagine the problem would have to do with the lines where it says /mnt/mnt/pool1 but I don't know what to do about that.
What do I do about this?
What version of FreeNAS are you using? Did you follow those commands EXACTLY or did you do some of them via the GUI and others via the CLI? Also, do you have SSH access to the machine? Was this pool pool the pool which had your .system dataset on it?
Gnrl Kitty
Version 11.2-U6.
Copy and pasted every command into shell.
I do not have SSH enabled.
Yes it was the .system dataset pool.
Well, my first theory would be that system dataset didn't get moved over or can't be found.
You may also want to import the pool such that it mounts where FreeNAS expects it with zpool import -f -R /mnt <pool>. This makes sure that the pool mounts where it is expected to be. Does the UI load now? Prior to the import, make note of the full ouptut of zpool import.
If the UI still doesn't load my next theory would be the database. What do you get with zpool status pool1 and then sqlite3 /data/freenas-v1.db 'select * from storage_volume; select * from storage_encrypteddisk;'? And then what is the output of zpool status pool1 and what was the ID as given when you did zpool import above?
I'll be honest with you that I don't know 100% what the exact issue is but am happy to try to troubleshoot with you if you'd like including fixing the database. You may be safer trying to undo the whole thing and do the export/import steps from the GUI and move the system dataset temporarily.
In general following advice elsewhere for zfs that isn't specific to FreeNAS can cause problems because FreeNAS expects certain flags etc when issuing zfs commands.
Maybe someone who knows exactly what is wrong will step in and tell us; otherwise I'm happy to help troubleshoot either approach you prefer.
Gnrl Kitty
You're probably right. In fact, I have all of the data on the pool backed up to Google Drive, so it's probably not worth the headache to fix this problem. I'll just wipe and recreate the pool and cloud sync the data back into the server.
Thanks for trying to help, I really appreciate it.
