paul.warwicker.1
- Apr 30, 2016
I recently upgraded from 11.1-U7 to 11.2-U3. Since then I have been experiencing random failures, particularly when backing up to the server from a couple of Windows 10 machines overnight. Initially, I suspected the samba setup but the issue appears to be that I am losing a whole pool. It is nothing to do with the timing as such; I can cause the problem during the day, although I have to wait a random time, often a few hours after a manual start of the full backup. The share and the oracle02/.system/samba4 dataset just evaporates under its feet.
I have raised the smbd logging to try to give an indication of the time when the failure occurs, but checking the other logs, around the time of the failure has so far revealed nothing. If I stay logged in, I can issue some commands, but trying to read /var/log is impossible and df hangs. I have to reboot to inspect any logs.
It goes from this:
to this:
Any sage words of advice??
It all was all working okay at 11.1.
-paul
It goes from this:
root@oracle[~]# zfs list NAME USED AVAIL REFER MOUNTPOINT freenas-boot 1.02G 107G 176K none freenas-boot/ROOT 1.02G 107G 136K none freenas-boot/ROOT/Initial-Install 8K 107G 1.01G legacy freenas-boot/ROOT/default 1.02G 107G 1.01G legacy oracle01 23.1G 5.08T 128K /mnt/oracle01 oracle01/ubackups 23.1G 5.08T 23.1G /mnt/oracle01/ubackups oracle01/utest 1.07M 5.08T 1.07M /mnt/oracle01/utest oracle02 6.97T 3.42T 99.0M /mnt/oracle02 oracle02/.bhyve_containers 70.5M 3.42T 70.5M /mnt/oracle02/.bhyve_containers oracle02/.system 35.1M 3.42T 170K legacy oracle02/.system/configs-1e6cbdfb415748b98d868947a6e14a88 454K 3.42T 454K legacy oracle02/.system/cores 156K 3.42T 156K legacy oracle02/.system/rrd-1e6cbdfb415748b98d868947a6e14a88 24.2M 3.42T 24.2M legacy oracle02/.system/samba4 604K 3.42T 604K legacy oracle02/.system/syslog-1e6cbdfb415748b98d868947a6e14a88 9.34M 3.42T 9.34M legacy oracle02/.system/webui 156K 3.42T 156K legacy oracle02/docker 498M 3.42T 498M /mnt/oracle02/docker oracle02/iocage 4.97G 3.42T 4.13M /mnt/oracle02/iocage oracle02/iocage/download 272M 3.42T 156K /mnt/oracle02/iocage/download oracle02/iocage/download/11.2-RELEASE 272M 3.42T 272M /mnt/oracle02/iocage/download/11.2-RELEASE oracle02/iocage/images 156K 3.42T 156K /mnt/oracle02/iocage/images oracle02/iocage/jails 3.35G 3.42T 156K /mnt/oracle02/iocage/jails oracle02/iocage/jails/jenkins 648M 3.42T 334K /mnt/oracle02/iocage/jails/jenkins oracle02/iocage/jails/jenkins/root 648M 3.42T 1.60G /mnt/oracle02/iocage/jails/jenkins/root oracle02/iocage/jails/plex 2.72G 3.42T 320K /mnt/oracle02/iocage/jails/plex oracle02/iocage/jails/plex/root 2.72G 3.42T 3.66G /mnt/oracle02/iocage/jails/plex/root oracle02/iocage/log 170K 3.42T 170K /mnt/oracle02/iocage/log oracle02/iocage/releases 1.35G 3.42T 156K /mnt/oracle02/iocage/releases oracle02/iocage/releases/11.2-RELEASE 1.35G 3.42T 156K /mnt/oracle02/iocage/releases/11.2-RELEASE oracle02/iocage/releases/11.2-RELEASE/root 1.35G 3.42T 1.35G /mnt/oracle02/iocage/releases/11.2-RELEASE/root oracle02/iocage/templates 156K 3.42T 156K /mnt/oracle02/iocage/templates oracle02/jails 3.30G 3.42T 185K /mnt/oracle02/jails oracle02/jails/.warden-template-pluginjail-11.0-x64 648M 3.42T 648M /mnt/oracle02/jails/.warden-template-pluginjail-11.0-x64 oracle02/jails/.warden-template-standard-11.0-x64 2.67G 3.42T 2.67G /mnt/oracle02/jails/.warden-template-standard-11.0-x64 oracle02/local 1.19T 3.42T 1.19T /mnt/oracle02/local oracle02/media 740G 3.42T 740G /mnt/oracle02/media oracle02/ubackups 23.1G 3.42T 23.1G /mnt/oracle02/ubackups oracle02/utest 1.14M 3.42T 1.14M /mnt/oracle02/utest oracle02/vmware 415G 3.42T 415G /mnt/oracle02/vmware oracle02/wbackups 4.33T 3.42T 4.09T /mnt/oracle02/wbackups oracle02/wroot 304G 3.42T 304G /mnt/oracle02/wroot root@oracle[~]#
to this:
[paulw@oracle ~]$ zfs list NAME USED AVAIL REFER MOUNTPOINT freenas-boot 1.02G 107G 176K none freenas-boot/ROOT 1.02G 107G 136K none freenas-boot/ROOT/Initial-Install 8K 107G 1.01G legacy freenas-boot/ROOT/default 1.02G 107G 1.01G legacy oracle01 23.1G 5.08T 128K /mnt/oracle01 oracle01/ubackups 23.1G 5.08T 23.1G /mnt/oracle01/ubackups oracle01/utest 1.07M 5.08T 1.07M /mnt/oracle01/utest [paulw@oracle ~]$
-paul
