IceBoosteR
 - Sep 27, 2016
Hi guys,
when I loged in into my server today, I saw that /dev/da5 got a problem with SMART.
Here is the output:
No my question, what should I do next? This drive is about a year old, and after my big move, all was fine in a long test. Nothing happend to the server, it is just running.
Any help -> Appreciated :)
Do you need my system specs? Please look to my signature ;)
I have made another test, now without errors? :O
When I looked at the timing, the only thing I could eventually imagine, that a microwave caused the problem. Due to some issues of space, the server is in my kitchen, in a big metal Nanoxia Deep Silence 6 Rev.B.
About 50cm near to it, there is my microwave. Could this be the reason? If yes, if need to move that damn thing :/
Funny, but it should not https://www.reddit.com/r/pcmasterra..._there_risks_in_keeping_your_computer_near_a/.
Okey well another one:
I will go with an long test, but maybe I need to replace this drive.
Here is the output:
root@freenas:~ # smartctl -a /dev/da5 smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD40EFRX-68WT0N0 Serial Number: WD-WCXXXXXXXXXXX LU WWN Device Id: 5 0014ee 2b8716486 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Nov 2 21:20:08 2017 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 113) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (51720) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 517) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 35 3 Spin_Up_Time 0x0027 184 171 021 Pre-fail Always - 7775 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 99 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3769 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 99 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 12 193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 4756 194 Temperature_Celsius 0x0022 125 112 000 Old_age Always - 27 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: read failure 10% 3729 51135160 # 2 Short offline Completed without error 00% 3705 - # 3 Extended offline Completed without error 00% 3592 - # 4 Conveyance offline Completed without error 00% 3582 - # 5 Short offline Completed without error 00% 3582 - # 6 Short offline Completed without error 00% 3576 - # 7 Extended offline Completed without error 00% 3461 - # 8 Short offline Completed without error 00% 3337 - # 9 Extended offline Completed without error 00% 3245 - #10 Short offline Completed without error 00% 3165 - #11 Short offline Completed without error 00% 3093 - #12 Short offline Completed without error 00% 3021 - #13 Short offline Completed without error 00% 2949 - #14 Short offline Completed without error 00% 2877 - #15 Short offline Completed without error 00% 2805 - #16 Short offline Completed without error 00% 2733 - #17 Short offline Completed without error 00% 2661 - #18 Short offline Completed without error 00% 2589 - #19 Short offline Completed without error 00% 2529 - #20 Short offline Completed without error 00% 2468 - #21 Short offline Completed without error 00% 2467 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 3769 - # 2 Short offline Completed: read failure 10% 3729 51135160 # 3 Short offline Completed without error 00% 3705 - # 4 Extended offline Completed without error 00% 3592 - # 5 Conveyance offline Completed without error 00% 3582 - # 6 Short offline Completed without error 00% 3582 - # 7 Short offline Completed without error 00% 3576 - # 8 Extended offline Completed without error 00% 3461 - # 9 Short offline Completed without error 00% 3337 - #10 Extended offline Completed without error 00% 3245 - #11 Short offline Completed without error 00% 3165 - #12 Short offline Completed without error 00% 3093 - #13 Short offline Completed without error 00% 3021 - #14 Short offline Completed without error 00% 2949 - #15 Short offline Completed without error 00% 2877 - #16 Short offline Completed without error 00% 2805 - #17 Short offline Completed without error 00% 2733 - #18 Short offline Completed without error 00% 2661 - #19 Short offline Completed without error 00% 2589 - #20 Short offline Completed without error 00% 2529 - #21 Short offline Completed without error 00% 2468 -
Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 35 3 Spin_Up_Time 0x0027 184 171 021 Pre-fail Always - 7775 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 99 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3769 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 99 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 12 193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 4756 194 Temperature_Celsius 0x0022 124 112 000 Old_age Always - 28 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: read failure 10% 3769 51142152 # 2 Short offline Completed without error 00% 3769 - # 3 Short offline Completed: read failure 10% 3729 51135160 # 4 Short offline Completed without error 00% 3705 - # 5 Extended offline Completed without error 00% 3592 - # 6 Conveyance offline Completed without error 00% 3582 - # 7 Short offline Completed without error 00% 3582 - # 8 Short offline Completed without error 00% 3576 - # 9 Extended offline Completed without error 00% 3461 - #10 Short offline Completed without error 00% 3337 - #11 Extended offline Completed without error 00% 3245 - #12 Short offline Completed without error 00% 3165 - #13 Short offline Completed without error 00% 3093 - #14 Short offline Completed without error 00% 3021 - #15 Short offline Completed without error 00% 2949 - #16 Short offline Completed without error 00% 2877 - #17 Short offline Completed without error 00% 2805 - #18 Short offline Completed without error 00% 2733 - #19 Short offline Completed without error 00% 2661 - #20 Short offline Completed without error 00% 2589 - #21 Short offline Completed without error 00% 2529 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
