Not sure why you had issues with importing your Sophos Config though?
Yeah, the X9 stuff wasn't a problem, the PCH ports on the X9 Cougar Point and Patsburg just magically worked for passthrough, and I was very disappointed that the X10 Wellsburg stuff didn't.
Still not particularly worrying. Here at home, we're on the far end of a utility run that basically goes through Tarzan's jungle, about two miles through backyards with fifty or sixty year old trees. We lose power once or twice a year, the A rail UPS (~10 min runtime) always discharge fully before transferring onto the B rail UPS's which are generator-backed. Since replacing them about 4 years ago they've probably been through at least 8 full cycles and they're still showing as very healthy.
I'm actually quite pleased with the new APC SMX units, though I don't know how "FreeNAS-compatible" they might be. Unlike the old APC Smart-UPS units, I haven't caught any of these doing any battery-cooking, and in fact we managed to hit the five year mark before we finally got any sort of battery warning. I had purchased a desktop SMT 750 to experiment with back in ~2010, and it finally gave it up a few months ago and needed a new battery pack. We had one other SMT unit arrive DOA but I think that may be the total extent of the bad things I can say about the new models. I was always griping about replacing batteries in the older Smart-UPS's... with several dozen units there was always one needing replacing, and usually the batteries had cooked and bulged without any alarm or warning.
If you are using generator, wouldn't you think that online ups will be more proper, like SURTA line up, instead line interactive SMX ?
Get a high quality generator. Gillette makes some well-regarded stuff. They use heavy duty diodes for which they provide a lifetime warranty, and heavy duty capacitors as part of their CLC voltage regulation design. They used to have a nice explanation of their "kleen-power" technology on their web site but I don't see it right now.
I wouldn't consider anything less than the best , it s felony:)
I took a peak at these guys you mention and their patriot statement:"All generator sets are USA wound, built, and thoroughly tested. Complete production models are USA factory built." and as long as it says honda on the pictures I could trust them :)))))))
Anyways I just wanted to make sure my green friend is aware of it. And and honestly speaking I was hoping you would said that you already have online ups, cause I am considering that option but it seems we are not together on this one.
Well it's different: Any raid controller is not good for zfs, but online UPS is better cause that's actually the only real "uninterrupted" power supply. Everything else just carries the name UPS but actually is directly connected to the power. Let me remind you about line interactive UPS that every time when switches to battery mode is actually cutting the power for several ms , and there is a risk the power supply will drop the load from having shorter "hold time" that the ups can make the switch.
P.S.I use to disable a UPS self-test for that reason.
A PSU should be able to hold its own for several milliseconds.
Some of us actually expect our gear to work in the real world. So when you run a generator test every two weeks and let the automatic transfer switch cut from A to B, there's this very interesting several seconds where it is transiting from A to B and not actually powered. Good test for all the gear.
I see what you are saying. I don't have a generator but I already have a automatic transfer switch (APC model) which I am going to get when get generator one day. This switching gap between A and B on transfer switch I would worry because it will not cause your servers to drop their load, since you'll have a ups in between to pick up that interruption.
By the way I did enable the UPS test recently feeling little bit more comfortable knowing that I have dual PSU on most of my servers so if one drop the load hopeful other wont.
I would assume in enterprise environment they would use online ups , this is something you would know better I am only assuming ?
P.S. By the way Linus tech tips got a new shiny ups's and they are online type :)
Assume what you want.
"Typically incorporated in the double-conversion UPSs that are the first choice for almost all critical data center applications, this functionality works by, in effect, feeding the load direct from the mains supply when this supply is within tolerance and problem free, but switching to normal double-conversion within two milliseconds of a mains supply problem occurring"
I am gonna have to check check the links you provide, very interesting stuff by the way. I guess by datacenter I didn't mean a actual datacenter, but in something smaller like business environment with several racks in a server room. Perhaps that's what's more accurate of what I had in mind.
I am not sure where is this quote from ,but this won't be the online UPS I understood: The idea is that it run from batteries the whole the time and AC from outside is charging the batteries in a mean time , so it will never have to switch , or even change it's output voltage regardless if AC source is removed or not. Otherwise what is the point of the double conversion ? It will be no different than stand by UPS (line interactive) like you said if this quote is true?! If is not feed by the batteries all the time and therefore avoid any switching transfers, there is not much a advantage over line interactive UPS.
P.S. Main disadvantage I see in online ups is the lower efficiency because of the double conversion - around 82% compared to line interactive which is easily get around 97-98%
