droptic
- May 28, 2022
Hello everyone
I have been using TrueNAS for a short time, I am using scale in its latest version, I wanted to install murmur (mumble server), everything went well when adding the Docker image, it works without problem, i made the adjustments in config files, but on reboot all is lost. I have seen that this is part of Docker and this is how it works. The files that should not be modified are in the /data folder, try to make it persistent but it always overwrites it. Is there a way to make it permanent? I don't want to create a virtual machine for so little. Thank you
PD: sorry for my english
