MountRoot Error - FreeNas 8
FredVerquin
HY,
After the installation from CD, when the pc reboots , the system can't mount the main disk.
I have the prompt "mountroot >"
It seems that there invalid setting in fstab ?
Can you help me ?
ProtoSD
What EXACT version are you using? (not the FreeBSD version) This seems to be a common problem/bug? that doesn't seem to have a clear resolution yet. You can try wiping your entire flash drive with something like 'dd' and then reinstall.
G
gcooper
Guest
If you were upgrading on the nightlies this past week, I broke the build. Sorry for the inconvenience, but it's fixed now.
