I've updated from 9.10.2-U2 to 9.10.2-U3 and I got an error message that I didn't get before (from the daily security run):
I've had a restart today and the same error appears in the log again.
from vat/log/messages:
I'm using an Asrock C2750D4I.
what does that mean and do I need to freak out?
Thanks for the help!
freenas.local changes in mounted filesystems: 17c17 < freenas-boot/ROOT/9.10.2-U2 / zfs rw,noatime,nfsv4acls 0 0 --- > freenas-boot/ROOT/9.10.2-U3 / zfs rw,noatime,nfsv4acls 0 0 freenas.local kernel log messages: > FreeBSD 10.3-STABLE #0 r295946+21897e6695f(9.10.2-STABLE): Thu Apr 20 17:58:31 UTC 2017 > module_register_init: MOD_LOAD (vesa, 0xffffffff80e489b0, 0) error 19 > SMP: AP CPU #4 Launched! > SMP: AP CPU #7 Launched! > SMP: AP CPU #3 Launched! > SMP: AP CPU #2 Launched! > Timecounter "TSC-low" frequency 1200029832 Hz quality 1000 > Trying to mount root from zfs:freenas-boot/ROOT/9.10.2-U3 []... -- End of security output --
Apr 29 22:14:02 freenas notifier: Stopping nginx. Apr 29 22:14:02 freenas notifier: Waiting for PIDS: 2962. Apr 29 22:14:07 freenas syslog-ng[52646]: syslog-ng starting up; version='3.6.4' Apr 29 22:14:07 freenas kernel: pid 1508 (syslog-ng), uid 0: exited on signal 6 (core dumped) Apr 29 22:14:07 freenas kernel: epair0a: link state changed to DOWN Apr 29 22:14:07 freenas kernel: epair0a: link state changed to DOWN Apr 29 22:14:07 freenas kernel: epair0b: link state changed to DOWN Apr 29 22:14:07 freenas kernel: epair0b: link state changed to DOWN Apr 29 22:14:07 freenas kernel: igb1: link state changed to DOWN Apr 29 22:14:07 freenas kernel: igb1: link state changed to DOWN Apr 29 22:14:07 freenas kernel: igb1: promiscuous mode disabled Apr 29 22:14:07 freenas kernel: bridge0: link state changed to DOWN Apr 29 22:14:07 freenas kernel: bridge0: link state changed to DOWN Apr 29 22:14:11 freenas smbd: dnssd_clientstub DNSServiceProcessResult called with DNSServiceRef with no ProcessReply function Apr 29 22:14:11 freenas kernel: igb1: link state changed to UP Apr 29 22:14:11 freenas kernel: igb1: link state changed to UP Apr 29 22:14:11 freenas dhclient: New IP Address (igb1): IP_censored Apr 29 22:14:11 freenas dhclient: New Subnet Mask (igb1): IP_censored Apr 29 22:14:11 freenas dhclient: New Broadcast Address (igb1): IP_censored Apr 29 22:14:11 freenas dhclient: New Routers (igb1): IP_censored Apr 29 22:14:11 freenas upsmon[2099]: upsmon parent: read Apr 29 22:14:11 freenas upsd[2093]: mainloop: Interrupted system call Apr 29 22:14:11 freenas ntpd[1979]: ntpd exiting on signal 15 (Terminated) Apr 29 22:14:12 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Apr 29 22:14:13 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Apr 29 22:14:14 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Apr 29 22:14:15 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Apr 29 22:14:16 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Apr 29 22:14:17 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Apr 29 22:14:18 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 ... Apr 29 22:14:41 freenas ugen0.3: <EATON> at usbus0 (disconnected) Apr 29 22:14:41 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Apr 29 22:14:42 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Apr 29 22:14:43 freenas ugen0.3: <EATON> at usbus0 Apr 29 22:14:43 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Apr 29 22:14:44 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Apr 29 22:14:45 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Apr 29 22:14:47 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Apr 29 22:14:48 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Apr 29 22:14:49 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Apr 29 22:14:50 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Apr 29 22:14:51 freenas syslog-ng[52646]: syslog-ng shutting down; version='3.6.4' Apr 29 22:20:36 freenas syslog-ng[1508]: syslog-ng starting up; version='3.6.4' Apr 29 22:20:36 freenas Copyright (c) 1992-2016 The FreeBSD Project. Apr 29 22:20:36 freenas Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 Apr 29 22:20:36 freenas The Regents of the University of California. All rights reserved. Apr 29 22:20:36 freenas FreeBSD is a registered trademark of The FreeBSD Foundation. Apr 29 22:20:36 freenas FreeBSD 10.3-STABLE #0 r295946+21897e6695f(9.10.2-STABLE): Thu Apr 20 17:58:31 UTC 2017 Apr 29 22:20:36 freenas root@gauntlet:/freenas-9.10-releng/_BE/objs/freenas-9.10-releng/_BE/os/sys/FreeNAS.amd64 amd64 Apr 29 22:20:36 freenas FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512 Apr 29 22:20:36 freenas CPU: Intel(R) Atom(TM) CPU C2750 @ 2.40GHz (2400.06-MHz K8-class CPU) Apr 29 22:20:36 freenas Origin="GenuineIntel" Id=0x406d8 Family=0x6 Model=0x4d Stepping=8 Apr 29 22:20:36 freenas Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE> Apr 29 22:20:36 freenas Features2=0x43d8e3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,RDRAND> Apr 29 22:20:36 freenas AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM> Apr 29 22:20:36 freenas AMD Features2=0x101<LAHF,Prefetch> Apr 29 22:20:36 freenas Structured Extended Features=0x2282<TSCADJ,SMEP,ERMS,NFPUSG> Apr 29 22:20:36 freenas VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID Apr 29 22:20:36 freenas TSC: P-state invariant, performance statistics Apr 29 22:20:36 freenas real memory = 17985175552 (17152 MB) Apr 29 22:20:36 freenas avail memory = 16558247936 (15791 MB) Apr 29 22:20:36 freenas Event timer "LAPIC" quality 600 Apr 29 22:20:36 freenas ACPI APIC Table: <INTEL TIANO > Apr 29 22:20:36 freenas FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs Apr 29 22:20:36 freenas FreeBSD/SMP: 1 package(s) x 8 core(s) Apr 29 22:20:36 freenas cpu0 (BSP): APIC ID: 0 Apr 29 22:20:36 freenas cpu1 (AP): APIC ID: 2 Apr 29 22:20:36 freenas cpu2 (AP): APIC ID: 4 Apr 29 22:20:36 freenas cpu3 (AP): APIC ID: 6 Apr 29 22:20:36 freenas cpu4 (AP): APIC ID: 8 Apr 29 22:20:36 freenas cpu5 (AP): APIC ID: 10 Apr 29 22:20:36 freenas cpu6 (AP): APIC ID: 12 Apr 29 22:20:36 freenas cpu7 (AP): APIC ID: 14 Apr 29 22:20:36 freenas random: <Software, Yarrow> initialized Apr 29 22:20:36 freenas WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. Apr 29 22:20:36 freenas ioapic0 <Version 2.0> irqs 0-23 on motherboard Apr 29 22:20:36 freenas kbd1 at kbdmux0 Apr 29 22:20:36 freenas module_register_init: MOD_LOAD (vesa, 0xffffffff80e489b0, 0) error 19 Apr 29 22:20:36 freenas aesni0: <AES-CBC,AES-XTS> on motherboard Apr 29 22:20:36 freenas padlock0: No ACE support. Apr 29 22:20:36 freenas cryptosoft0: <software crypto> on motherboard Apr 29 22:20:36 freenas acpi0: <ALASKA A M I > on motherboard Apr 29 22:20:36 freenas acpi0: Power Button (fixed) Apr 29 22:20:36 freenas cpu0: <ACPI CPU> on acpi0 Apr 29 22:20:36 freenas cpu1: <ACPI CPU> on acpi0 Apr 29 22:20:36 freenas cpu2: <ACPI CPU> on acpi0 Apr 29 22:20:36 freenas cpu3: <ACPI CPU> on acpi0 Apr 29 22:20:36 freenas cpu4: <ACPI CPU> on acpi0 Apr 29 22:20:36 freenas cpu5: <ACPI CPU> on acpi0 Apr 29 22:20:36 freenas cpu6: <ACPI CPU> on acpi0 Apr 29 22:20:36 freenas cpu7: <ACPI CPU> on acpi0 Apr 29 22:20:36 freenas hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Apr 29 22:20:36 freenas Timecounter "HPET" frequency 14318180 Hz quality 950 Apr 29 22:20:36 freenas Event timer "HPET" frequency 14318180 Hz quality 350 Apr 29 22:20:36 freenas Event timer "HPET1" frequency 14318180 Hz quality 340 Apr 29 22:20:36 freenas Event timer "HPET2" frequency 14318180 Hz quality 340 Apr 29 22:20:36 freenas atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0 Apr 29 22:20:36 freenas atrtc0: Warning: Couldn't map I/O. Apr 29 22:20:36 freenas Event timer "RTC" frequency 32768 Hz quality 0 Apr 29 22:20:36 freenas attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0 Apr 29 22:20:36 freenas Timecounter "i8254" frequency 1193182 Hz quality 0 Apr 29 22:20:36 freenas Event timer "i8254" frequency 1193182 Hz quality 100 Apr 29 22:20:36 freenas Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 Apr 29 22:20:36 freenas acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0 Apr 29 22:20:36 freenas pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 Apr 29 22:20:36 freenas pci0: <ACPI PCI bus> on pcib0 Apr 29 22:20:36 freenas pcib1: <ACPI PCI-PCI bridge> mem 0xdf740000-0xdf75ffff irq 16 at device 1.0 on pci0 Apr 29 22:20:36 freenas pci1: <ACPI PCI bus> on pcib1 Apr 29 22:20:36 freenas pcib2: <ACPI PCI-PCI bridge> mem 0xdf720000-0xdf73ffff irq 20 at device 3.0 on pci0 Apr 29 22:20:36 freenas pci2: <ACPI PCI bus> on pcib2 Apr 29 22:20:36 freenas pcib3: <ACPI PCI-PCI bridge> mem 0xdf500000-0xdf51ffff irq 22 at device 0.0 on pci2 Apr 29 22:20:36 freenas pci3: <ACPI PCI bus> on pcib3 Apr 29 22:20:36 freenas pcib4: <PCI-PCI bridge> irq 23 at device 1.0 on pci3 Apr 29 22:20:36 freenas pci4: <PCI bus> on pcib4 Apr 29 22:20:36 freenas ahci0: <Marvell 88SE9172 AHCI SATA controller> port 0xc040-0xc047,0xc030-0xc033,0xc020-0xc027,0xc010-0xc013,0xc000-0xc00f mem 0xdf410000-0xdf4101ff irq 23 at device 0.0 on pci4 Apr 29 22:20:36 freenas ahci0: AHCI v1.00 with 2 6Gbps ports, Port Multiplier supported with FBS Apr 29 22:20:36 freenas ahcich0: <AHCI channel> at channel 0 on ahci0 Apr 29 22:20:36 freenas ahcich1: <AHCI channel> at channel 1 on ahci0 Apr 29 22:20:36 freenas pcib5: <PCI-PCI bridge> irq 23 at device 5.0 on pci3 Apr 29 22:20:36 freenas pci5: <PCI bus> on pcib5 Apr 29 22:20:36 freenas pcib6: <PCI-PCI bridge> irq 23 at device 0.0 on pci5 Apr 29 22:20:36 freenas pci6: <PCI bus> on pcib6 Apr 29 22:20:36 freenas vgapci0: <VGA-compatible display> port 0xb000-0xb07f mem 0xde000000-0xdeffffff,0xdf000000-0xdf01ffff irq 23 at device 0.0 on pci6 Apr 29 22:20:36 freenas vgapci0: Boot video device Apr 29 22:20:36 freenas pcib7: <PCI-PCI bridge> irq 21 at device 7.0 on pci3 Apr 29 22:20:36 freenas pci7: <PCI bus> on pcib7 Apr 29 22:20:36 freenas igb0: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0xa000-0xa01f mem 0xdf300000-0xdf37ffff,0xdf380000-0xdf383fff irq 21 at device 0.0 on pci7 Apr 29 22:20:36 freenas igb0: Using MSIX interrupts with 5 vectors Apr 29 22:20:36 freenas igb0: Ethernet address: xx:xx:xx:xx:xx:xx Apr 29 22:20:36 freenas igb0: Bound queue 0 to cpu 0 Apr 29 22:20:36 freenas igb0: Bound queue 1 to cpu 1 Apr 29 22:20:36 freenas igb0: Bound queue 2 to cpu 2 Apr 29 22:20:36 freenas igb0: Bound queue 3 to cpu 3 Apr 29 22:20:36 freenas pcib8: <PCI-PCI bridge> irq 23 at device 9.0 on pci3 Apr 29 22:20:36 freenas pci8: <PCI bus> on pcib8 Apr 29 22:20:36 freenas igb1: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0x9000-0x901f mem 0xdf200000-0xdf27ffff,0xdf280000-0xdf283fff irq 23 at device 0.0 on pci8 Apr 29 22:20:36 freenas igb1: Using MSIX interrupts with 5 vectors Apr 29 22:20:36 freenas igb1: Ethernet address: xx:xx:xx:xx:xx:xx Apr 29 22:20:36 freenas igb1: Bound queue 0 to cpu 4 Apr 29 22:20:36 freenas igb1: Bound queue 1 to cpu 5 Apr 29 22:20:36 freenas igb1: Bound queue 2 to cpu 6 Apr 29 22:20:36 freenas igb1: Bound queue 3 to cpu 7 Apr 29 22:20:36 freenas pcib9: <ACPI PCI-PCI bridge> mem 0xdf700000-0xdf71ffff at device 4.0 on pci0 Apr 29 22:20:36 freenas pci9: <ACPI PCI bus> on pcib9 Apr 29 22:20:36 freenas ahci1: <Marvell 88SE9230 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0xdf610000-0xdf6107ff irq 23 at device 0.0 on pci9 Apr 29 22:20:36 freenas ahci1: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported Apr 29 22:20:36 freenas ahci1: quirks=0x900<NOBSYRES,ALTSIG> Apr 29 22:20:36 freenas ahcich2: <AHCI channel> at channel 0 on ahci1 Apr 29 22:20:36 freenas ahcich3: <AHCI channel> at channel 1 on ahci1 Apr 29 22:20:36 freenas ahcich4: <AHCI channel> at channel 2 on ahci1 Apr 29 22:20:36 freenas ahcich5: <AHCI channel> at channel 3 on ahci1 Apr 29 22:20:36 freenas ahcich6: <AHCI channel> at channel 4 on ahci1 Apr 29 22:20:36 freenas ahcich7: <AHCI channel> at channel 5 on ahci1 Apr 29 22:20:36 freenas ahcich8: <AHCI channel> at channel 6 on ahci1 Apr 29 22:20:36 freenas ahcich9: <AHCI channel> at channel 7 on ahci1 Apr 29 22:20:36 freenas pci0: <base peripheral, IOMMU> at device 15.0 (no driver attached) Apr 29 22:20:36 freenas ehci0: <Intel Avoton USB 2.0 controller> mem 0xdf763000-0xdf7633ff irq 23 at device 22.0 on pci0 Apr 29 22:20:36 freenas usbus0: EHCI version 1.0 Apr 29 22:20:36 freenas usbus0 on ehci0 Apr 29 22:20:36 freenas ahci2: <Intel Avoton AHCI SATA controller> port 0xe0d0-0xe0d7,0xe0c0-0xe0c3,0xe0b0-0xe0b7,0xe0a0-0xe0a3,0xe040-0xe05f mem 0xdf762000-0xdf7627ff irq 19 at device 23.0 on pci0 Apr 29 22:20:36 freenas ahci2: AHCI v1.30 with 4 3Gbps ports, Port Multiplier not supported Apr 29 22:20:36 freenas ahcich10: <AHCI channel> at channel 0 on ahci2 Apr 29 22:20:36 freenas ahcich11: <AHCI channel> at channel 1 on ahci2 Apr 29 22:20:36 freenas ahcich12: <AHCI channel> at channel 2 on ahci2 Apr 29 22:20:36 freenas ahcich13: <AHCI channel> at channel 3 on ahci2 Apr 29 22:20:36 freenas ahci3: <Intel Avoton AHCI SATA controller> port 0xe090-0xe097,0xe080-0xe083,0xe070-0xe077,0xe060-0xe063,0xe020-0xe03f mem 0xdf761000-0xdf7617ff irq 19 at device 24.0 on pci0 Apr 29 22:20:36 freenas ahci3: AHCI v1.30 with 2 6Gbps ports, Port Multiplier not supported Apr 29 22:20:36 freenas ahcich14: <AHCI channel> at channel 0 on ahci3 Apr 29 22:20:36 freenas ahcich15: <AHCI channel> at channel 1 on ahci3 Apr 29 22:20:36 freenas isab0: <PCI-ISA bridge> at device 31.0 on pci0 Apr 29 22:20:36 freenas isa0: <ISA bus> on isab0 Apr 29 22:20:36 freenas uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 Apr 29 22:20:36 freenas uart2: <16550 or compatible> port 0x248-0x24f irq 3 on acpi0 Apr 29 22:20:36 freenas ichwd0: <Intel Avoton/Rangeley SoC watchdog timer> on isa0 Apr 29 22:20:36 freenas ichwd0: ICH WDT present but disabled in BIOS or hardware Apr 29 22:20:36 freenas device_attach: ichwd0 attach returned 6 Apr 29 22:20:36 freenas wbwd0: <Nuvoton NCT6776 (0xc3/0x33) Watchdog Timer> at port 0x2e-0x2f on isa0 Apr 29 22:20:36 freenas ichwd0: <Intel Avoton/Rangeley SoC watchdog timer> at port 0x430-0x437,0x460-0x47f on isa0 Apr 29 22:20:36 freenas ichwd0: ICH WDT present but disabled in BIOS or hardware Apr 29 22:20:36 freenas device_attach: ichwd0 attach returned 6 Apr 29 22:20:36 freenas orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0 Apr 29 22:20:36 freenas sc0: <System console> at flags 0x100 on isa0 Apr 29 22:20:36 freenas sc0: CGA <16 virtual consoles, flags=0x300> Apr 29 22:20:36 freenas vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0 Apr 29 22:20:36 freenas atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0 Apr 29 22:20:36 freenas atkbd0: <AT Keyboard> irq 1 on atkbdc0 Apr 29 22:20:36 freenas kbd0 at atkbd0 Apr 29 22:20:36 freenas atkbd0: [GIANT-LOCKED] Apr 29 22:20:36 freenas coretemp0: <CPU On-Die Thermal Sensors> on cpu0 Apr 29 22:20:36 freenas est0: <Enhanced SpeedStep Frequency Control> on cpu0 Apr 29 22:20:36 freenas coretemp1: <CPU On-Die Thermal Sensors> on cpu1 Apr 29 22:20:36 freenas est1: <Enhanced SpeedStep Frequency Control> on cpu1 Apr 29 22:20:36 freenas coretemp2: <CPU On-Die Thermal Sensors> on cpu2 Apr 29 22:20:36 freenas est2: <Enhanced SpeedStep Frequency Control> on cpu2 Apr 29 22:20:36 freenas coretemp3: <CPU On-Die Thermal Sensors> on cpu3 Apr 29 22:20:36 freenas est3: <Enhanced SpeedStep Frequency Control> on cpu3 Apr 29 22:20:36 freenas coretemp4: <CPU On-Die Thermal Sensors> on cpu4 Apr 29 22:20:36 freenas est4: <Enhanced SpeedStep Frequency Control> on cpu4 Apr 29 22:20:36 freenas coretemp5: <CPU On-Die Thermal Sensors> on cpu5 Apr 29 22:20:36 freenas est5: <Enhanced SpeedStep Frequency Control> on cpu5 Apr 29 22:20:36 freenas coretemp6: <CPU On-Die Thermal Sensors> on cpu6 Apr 29 22:20:36 freenas est6: <Enhanced SpeedStep Frequency Control> on cpu6 Apr 29 22:20:36 freenas coretemp7: <CPU On-Die Thermal Sensors> on cpu7 Apr 29 22:20:36 freenas est7: <Enhanced SpeedStep Frequency Control> on cpu7 Apr 29 22:20:36 freenas random: unblocking device. Apr 29 22:20:36 freenas usbus0: 480Mbps High Speed USB v2.0 Apr 29 22:20:36 freenas ZFS filesystem version: 5 Apr 29 22:20:36 freenas ZFS storage pool version: features support (5000) Apr 29 22:20:36 freenas Timecounters tick every 1.000 msec Apr 29 22:20:36 freenas ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled Apr 29 22:20:36 freenas ugen0.1: <Intel> at usbus0 Apr 29 22:20:36 freenas uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0 Apr 29 22:20:36 freenas uhub0: 8 ports with 8 removable, self powered Apr 29 22:20:36 freenas ugen0.2: <vendor 0x8087> at usbus0 Apr 29 22:20:36 freenas uhub1: <vendor 0x8087 product 0x07db, class 9/0, rev 2.00/0.02, addr 2> on usbus0 Apr 29 22:20:36 freenas uhub1: 4 ports with 4 removable, self powered Apr 29 22:20:36 freenas ugen0.3: <EATON> at usbus0 Apr 29 22:20:36 freenas ugen0.4: <SanDisk> at usbus0 Apr 29 22:20:36 freenas umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.10/1.00, addr 4> on usbus0 Apr 29 22:20:36 freenas umass0: SCSI over Bulk-Only; quirks = 0xc100 Apr 29 22:20:36 freenas umass0:17:0:-1: Attached to scbus17 Apr 29 22:20:36 freenas ugen0.5: <SanDisk> at usbus0 Apr 29 22:20:36 freenas umass1: <SanDisk Cruzer Fit, class 0/0, rev 2.10/1.00, addr 5> on usbus0 Apr 29 22:20:36 freenas umass1: SCSI over Bulk-Only; quirks = 0xc100 Apr 29 22:20:36 freenas umass1:18:1:-1: Attached to scbus18 Apr 29 22:20:36 freenas ugen0.6: <American Megatrends Inc.> at usbus0 Apr 29 22:20:36 freenas uhub2: <7-port Hub> on usbus0 Apr 29 22:20:36 freenas uhub2: 5 ports with 5 removable, self powered Apr 29 22:20:36 freenas ugen0.7: <American Megatrends Inc.> at usbus0 Apr 29 22:20:36 freenas ukbd0: <Keyboard Interface> on usbus0 Apr 29 22:20:36 freenas kbd2 at ukbd0 Apr 29 22:20:36 freenas ada0 at ahcich10 bus 0 scbus10 target 0 lun 0 Apr 29 22:20:36 freenas ada0: <WDC WD20EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Apr 29 22:20:36 freenas ada0: Serial Number WD-WCC4M6JVEV1K Apr 29 22:20:36 freenas ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Apr 29 22:20:36 freenas ada0: Command Queueing enabled Apr 29 22:20:36 freenas ada0: 1907729MB (3907029168 512 byte sectors) Apr 29 22:20:36 freenas ada0: quirks=0x1<4K> Apr 29 22:20:36 freenas ada0: Previously was known as ad24 Apr 29 22:20:36 freenas ada1 at ahcich11 bus 0 scbus11 target 0 lun 0 Apr 29 22:20:36 freenas ada1: <WDC WD20EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Apr 29 22:20:36 freenas ada1: Serial Number WD-WCC4M2YRJCJY Apr 29 22:20:36 freenas ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Apr 29 22:20:36 freenas ada1: Command Queueing enabled Apr 29 22:20:36 freenas ada1: 1907729MB (3907029168 512 byte sectors) Apr 29 22:20:36 freenas ada1: quirks=0x1<4K> Apr 29 22:20:36 freenas ada1: Previously was known as ad26 Apr 29 22:20:36 freenas ada2 at ahcich12 bus 0 scbus12 target 0 lun 0 Apr 29 22:20:36 freenas ada2: <WDC WD20EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Apr 29 22:20:36 freenas ada2: Serial Number WD-WCC4M7DKDK6S Apr 29 22:20:36 freenas ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Apr 29 22:20:36 freenas ada2: Command Queueing enabled Apr 29 22:20:36 freenas ada2: 1907729MB (3907029168 512 byte sectors) Apr 29 22:20:36 freenas ada2: quirks=0x1<4K> Apr 29 22:20:36 freenas ada2: Previously was known as ad28 Apr 29 22:20:36 freenas ada3 at ahcich13 bus 0 scbus13 target 0 lun 0 Apr 29 22:20:36 freenas ada3: <WDC WD20EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Apr 29 22:20:36 freenas ada3: Serial Number WD-WCC4M7DKDU51 Apr 29 22:20:36 freenas ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Apr 29 22:20:36 freenas ada3: Command Queueing enabled Apr 29 22:20:36 freenas ada3: 1907729MB (3907029168 512 byte sectors) Apr 29 22:20:36 freenas ada3: quirks=0x1<4K> Apr 29 22:20:36 freenas ada3: Previously was known as ad30 Apr 29 22:20:36 freenas ada4 at ahcich14 bus 0 scbus14 target 0 lun 0 Apr 29 22:20:36 freenas ada4: <WDC WD20EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Apr 29 22:20:36 freenas ada4: Serial Number WD-WCC4M1HSJX4Y Apr 29 22:20:36 freenas ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Apr 29 22:20:36 freenas ada4: Command Queueing enabled Apr 29 22:20:36 freenas ada4: 1907729MB (3907029168 512 byte sectors) Apr 29 22:20:36 freenas ada4: quirks=0x1<4K> Apr 29 22:20:36 freenas ada4: Previously was known as ad32 Apr 29 22:20:36 freenas ada5 at ahcich15 bus 0 scbus15 target 0 lun 0 Apr 29 22:20:36 freenas ada5: <WDC WD20EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Apr 29 22:20:36 freenas ada5: Serial Number WD-WCC4M6JVEV16 Apr 29 22:20:36 freenas ada5: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Apr 29 22:20:36 freenas ada5: Command Queueing enabled Apr 29 22:20:36 freenas ada5: 1907729MB (3907029168 512 byte sectors) Apr 29 22:20:36 freenas ada5: quirks=0x1<4K> Apr 29 22:20:36 freenas ada5: Previously was known as ad34 Apr 29 22:20:36 freenas da0 at umass-sim0 bus 0 scbus17 target 0 lun 0 Apr 29 22:20:36 freenas da0: <SanDisk Cruzer Fit 1.00> Removable Direct Access SPC-4 SCSI device Apr 29 22:20:36 freenas da0: Serial Number 4C530314240317111444 Apr 29 22:20:36 freenas da0: 40.000MB/s transfers Apr 29 22:20:36 freenas da0: 15264MB (31260672 512 byte sectors) Apr 29 22:20:36 freenas da0: quirks=0x2<NO_6_BYTE> Apr 29 22:20:36 freenas da1 at umass-sim1 bus 1 scbus18 target 0 lun 0 Apr 29 22:20:36 freenas da1: <SanDisk Cruzer Fit 1.00> Removable Direct Access SPC-4 SCSI device Apr 29 22:20:36 freenas da1: Serial Number 4C530001251217110421 Apr 29 22:20:36 freenas da1: 40.000MB/s transfers Apr 29 22:20:36 freenas da1: 15264MB (31260672 512 byte sectors) Apr 29 22:20:36 freenas da1: quirks=0x2<NO_6_BYTE> Apr 29 22:20:36 freenas pass0 at ahcich9 bus 0 scbus9 target 0 lun 0 Apr 29 22:20:36 freenas pass0: <Marvell Console 1.01> Removable Processor SCSI device Apr 29 22:20:36 freenas pass0: Serial Number HKDP221516WL Apr 29 22:20:36 freenas pass0: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes) Apr 29 22:20:36 freenas SMP: AP CPU #1 Launched! Apr 29 22:20:36 freenas SMP: AP CPU #5 Launched! Apr 29 22:20:36 freenas SMP: AP CPU #6 Launched! Apr 29 22:20:36 freenas SMP: AP CPU #4 Launched! Apr 29 22:20:36 freenas SMP: AP CPU #7 Launched! Apr 29 22:20:36 freenas SMP: AP CPU #3 Launched! Apr 29 22:20:36 freenas SMP: AP CPU #2 Launched! Apr 29 22:20:36 freenas Timecounter "TSC-low" frequency 1200029832 Hz quality 1000 Apr 29 22:20:36 freenas Trying to mount root from zfs:freenas-boot/ROOT/9.10.2-U3 []... Apr 29 22:20:36 freenas ugen0.3: <EATON> at usbus0 (disconnected) Apr 29 22:20:36 freenas ugen0.3: <EATON> at usbus0 Apr 29 22:20:36 freenas GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) Apr 29 22:20:36 freenas ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0 Apr 29 22:20:36 freenas ipmi0: KCS mode found at io 0xca2 on acpi Apr 29 22:20:36 freenas ipmi0: IPMI device rev. 1, firmware rev. 0.23, version 2.0 Apr 29 22:20:36 freenas ipmi0: Number of channels 2 Apr 29 22:20:36 freenas ipmi0: Attached watchdog Apr 29 22:20:36 freenas ichwd0: <Intel Avoton/Rangeley SoC watchdog timer> at port 0x430-0x437,0x460-0x47f on isa0 Apr 29 22:20:36 freenas ichwd0: ICH WDT present but disabled in BIOS or hardware Apr 29 22:20:36 freenas device_attach: ichwd0 attach returned 6 Apr 29 22:20:36 freenas hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/2/40/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/40/0x67<INT,USR,SYS,REA,WRI> Apr 29 22:20:36 freenas ugen0.3: <EATON> at usbus0 (disconnected) Apr 29 22:20:36 freenas ugen0.3: <EATON> at usbus0 Apr 29 22:20:36 freenas kernel: igb1: link state changed to UP Apr 29 22:20:36 freenas kernel: igb1: link state changed to UP Apr 29 22:20:36 freenas ums0: <Mouse Interface> on usbus0 Apr 29 22:20:36 freenas ums0: 3 buttons and [Z] coordinates ID=0 Apr 29 22:20:38 freenas GEOM_ELI: Device ada4p1.eli created. Apr 29 22:20:38 freenas GEOM_ELI: Encryption: AES-XTS 128 Apr 29 22:20:38 freenas GEOM_ELI: Crypto: hardware Apr 29 22:20:38 freenas GEOM_ELI: Device ada5p1.eli created. Apr 29 22:20:38 freenas GEOM_ELI: Encryption: AES-XTS 128 Apr 29 22:20:38 freenas GEOM_ELI: Crypto: hardware Apr 29 22:20:38 freenas GEOM_ELI: Device ada0p1.eli created. Apr 29 22:20:38 freenas GEOM_ELI: Encryption: AES-XTS 128 Apr 29 22:20:38 freenas GEOM_ELI: Crypto: hardware Apr 29 22:20:38 freenas GEOM_ELI: Device ada1p1.eli created. Apr 29 22:20:38 freenas GEOM_ELI: Encryption: AES-XTS 128 Apr 29 22:20:38 freenas GEOM_ELI: Crypto: hardware Apr 29 22:20:38 freenas GEOM_ELI: Device ada2p1.eli created. Apr 29 22:20:38 freenas GEOM_ELI: Encryption: AES-XTS 128 Apr 29 22:20:38 freenas GEOM_ELI: Crypto: hardware Apr 29 22:20:38 freenas GEOM_ELI: Device ada3p1.eli created. Apr 29 22:20:38 freenas GEOM_ELI: Encryption: AES-XTS 128 Apr 29 22:20:38 freenas GEOM_ELI: Crypto: hardware Apr 29 22:20:39 freenas ntpd[1978]: ntpd 4.2.8p9-a (1): Starting Apr 29 22:20:47 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Apr 29 22:20:47 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd Apr 29 22:20:48 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Apr 29 22:20:50 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Apr 29 22:20:51 freenas smbd: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:35 Err:-1 Errno:2 No such file or directory Apr 29 22:21:04 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Apr 29 22:21:04 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Apr 29 22:21:07 freenas bridge0: Ethernet address: xx:xx:xx:xx:xx:xx Apr 29 22:21:07 freenas kernel: igb1: promiscuous mode enabled Apr 29 22:21:07 freenas kernel: bridge0: link state changed to UP Apr 29 22:21:07 freenas kernel: bridge0: link state changed to UP Apr 29 22:21:07 freenas epair0a: Ethernet address: xx:xx:xx:xx:xx:xx Apr 29 22:21:07 freenas epair0b: Ethernet address: xx:xx:xx:xx:xx:xx Apr 29 22:21:07 freenas kernel: epair0a: link state changed to UP Apr 29 22:21:07 freenas kernel: epair0a: link state changed to UP Apr 29 22:21:07 freenas kernel: epair0b: link state changed to UP Apr 29 22:21:07 freenas kernel: epair0b: link state changed to UP Apr 29 22:21:07 freenas kernel: igb1: link state changed to DOWN Apr 29 22:21:07 freenas kernel: igb1: link state changed to DOWN Apr 29 22:21:07 freenas kernel: epair0a: promiscuous mode enabled Apr 29 22:21:08 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair0b Apr 29 22:21:08 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair0b Apr 29 22:21:12 freenas kernel: igb1: link state changed to UP Apr 29 22:21:12 freenas kernel: igb1: link state changed to UP Apr 29 22:21:12 freenas dhclient: New IP Address (igb1): IP_censored Apr 29 22:21:12 freenas dhclient: New Subnet Mask (igb1): IP_censored Apr 29 22:21:12 freenas dhclient: New Broadcast Address (igb1): IP_censored Apr 29 22:21:12 freenas dhclient: New Routers (igb1): IP_censored Apr 29 23:00:03 freenas autosnap.py: [tools.autosnap:66] Popen()ing: /sbin/zfs snapshot "Pool1_Z2_censored" Apr 29 23:00:04 freenas autosnap.py: [tools.autosnap:66] Popen()ing: /sbin/zfs destroy -r -d "Pool1_Z2_censored" Apr 29 23:21:20 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Apr 29 23:21:20 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name
