Missing 3/4 passthrough drives in Hyper-v
Marc Allard
I have decided to make a test with Hyper-v with 4 drives
The 4 drives are passed through but the GUI can't see them (while fdisk can).
Only one drive is seen.
I have seen that creating the pool manually (zpool create -f TestPool......) works perfectly.
Once created the pool must be exported to be imported in the GUI.
After that sometimes there is a message telling there is a problem getting information on the pool (while zpool status shows no problem).
My 4 HDD are passthrough from a Fantec QB-35US3-6G (I see 4 drives in Windows that I take offline to pass them to hyper-v).
Is there something I am missing?
Thank you
Marc
ChrisRJ
Is the adapter (on-board or separate HBA), to which the disks are connected, passed through on PCIe-level?
Marc Allard
Thank you for the answer.
I use the USB3 port (and I have put the 4 disks offline in Windows to pass them through) as disks (with a virtual SCSI adapter).
Patrick M. Hausen
That won't work. You need to pass an entire adapter via PCIe passthrough. Or pass NVME disks which is also PCIe.
Marc Allard
Thank you
I guess it is too dangerous to make the pool in command line (it is bound to have problems in the future) and as Hyper-v doesn't allow to passthrough adapters I should forget it. Am I correct?
Patrick M. Hausen
Hyper-V does allow the pass-through of adapters. That's the point. You need a dedicated PCIe-SATA adapter for that, but then it is supposed to work.
HoneyBadger
actually does care
Administrator
Fantec QB-35US3-6G
This is an external USB/eSATA enclosure, and neither of those two connection methods will work well with FreeNAS; USB isn't well-supported, and eSATA would imply the use of SATA port multiplication.
Is it possible to connect the drives internally? You could then use Hyper-V to do PCI passthrough of an internal storage controller and have a much better supported solution.
jgreco
Resident Grinch
Just a note that this is the TrueNAS SCALE forum. It's still not a good idea, but Linux might work a bit better (until the cable pulls loose, of course).
HoneyBadger
actually does care
Administrator
I didn't even notice, my bad.
Linux has significantly better UASP drivers which might make that a reliable option (barring an unplug, of course) but that depends on the enclosure having support for the protocol.
