I am planning a migration from a windows server build running Hyper-V to Truenas Scale. I currently have a RAID card hosting a 60TB array, formatted as NTFS. I will be upgrading to larger SAS 3 drives and connecting them to a HBA on the same computer.
The plan is to lose Windows install Truenas, create a pool with the new drives, then bring up one of my Windows VMs, passthrough the RAID volume to that VM, and use that to copy my data over to the new Truenas volume. Will this work?
Alternately, can I mount the NTFS RAID array in Truenas Scale, and copy it over using the CLI?
Are there other suggestions for moving the data from the RAID array to the new Truenas volume, given that I only have one server?
Thanks,
fermie
Thanks,
fermie
