Mirrored to Raid z-1
mpriney
  • Motherboard make and model: Alienware Aurora R3 0DF1G9 046MHW LGA 1155 P67
  • CPU make and model: Intel 2600k
  • RAM quantity: DDR3 24gb
  • Hard drives
    • Quantity - 5+1 boot ssd
    • Model numbers - Seagate 1tb
    • RAID configuration- mirror
    • Boot drive- 256gb
  • Hard disk controllers - SATA
  • Network cards – RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
  • OS: TrueNAS-SCALE-23.10.1
New user, first post.
When first setting up TrueNAS scale i didn't know what i was doing so i setup 1 pool with 2 mirrored zvols.
To fix this
  1. copy everything I care about (photos and videos) from the server to another machine on the network
  2. delete the existing pool
  3. setup a new pool with raid z1
  4. reinstall and re-setup all my apps
Do i have that right, or is there a better solution?
Davvo
Generally it's advised to put the apps on a mirror pool. Besides that you can copy the files in many ways not just via network.
Also, do not use the word RAID with ZFS; and zvols are a different thing, you likely meant VDEVs.
