TheGeekn°72
- Mar 24, 2023
I bought the three drives in two different orders so if one dies, there's a 50% chance of a second one dying shortly after lel (if they are, as I hope they should be, from two different production lots)@TheGeekn°72 : Good to hear! Your system should work as intended.
As a note, you bought the data drives at the same time, they'll see the same workload, and they'll die at the same time (unless one kicks off early). If one starts dying of old age, statistically there's a 10% chance you'll lose your data before the Z1 array is rebuilt. If you had a Z2 array it's 10% of 10%, or a 1% chance. When you consider there's a statistical probability your (untested?) backup is corrupt (the % depending on many variables), you may lose some data. I've lost data intermittently over the years despite reasonable efforts to the contrary, so run Z3. (Most members here run Z2.)
I was planning to do RAID-6/RAID-Z2 but, eh, budget constraints, drives are about 25% pricier in the EU than in the US...
I mean, maybe I could have got them from the US, thus got one for the same price and paid a premium on delivery I guess but I'd have had to spend more on a bigger motherboard for the subsequent higher SATA ports count requirement and I really didn't want to do that either since it'd have cascaded down on my parts' list compatibility (bigger case and non proprietary PSU, maybe different RAM, most likely a new CPU as well) and the goal really was to just make a learning platform (on which I could dump low value content I wouldn't care much about if I lost it, such as video game captures and files that I could ultimately redownload from their sources but save me the trouble of waiting hours on end to save locally because of the sources' terrible upload speeds) so Z1 is probably more than good enough for this as a start off
I have a few RAM sticks, I'll check them out to see if they're ECC'd (though I highly doubt it tbh) and if I do have some that are ECC then I'll use them, if not then too badThe other note is ZFS heavily uses RAM for caching, RAM has a lot of errors (Zebras All the Way Down), so ECC RAM is highly suggested. Note I'm not telling you to use it, though I use it and Xenon processors for 4-bit ECC.
From the ones I have, I can put together a 4x8GB kit of 2x2 similar stick kits, hopefully that should run well enough-ish ?
I knew about that possibility and was fully intending on backing up the boot drive's content at a reasonable frequency (still thinking about how often that should be zo that'll make it relevant without being too much either)One final note, if you lose your OS drive your data array *might* get trashed--though I don't know how accurate that assessment is. efs3 and efs4 have tools to recover a wrecked array under LVM, I'm not so sure how ZFS will handle it. It's something to look into.
