Thomas8675309
- Sep 2, 2013
I'm building a home back-up server, my first FreeNAS system (although I've built a few non-FreeNAS systems in the past). My goal is to make it reasonably efficient and quiet.
My proposed build:
1 x Intel Core i3 3220T 35W CPU
1 x Intel S1200BTSR Micro ATX Server Motherboard
2 x Kingston KVR16E11/8I 8GB DDR3 SDRAM ECC Unbuffered 1600 Server Memory
6 x Seagate NAS HDD ST2000VN000 2TB 64MB Cache SATA 6.0Gb/s Internal Hard Drive
1 x SeaSonic SSR-360GP 360W ATX12V v2.31 80 PLUS GOLD Certified Active PFC Power Supply
1 x LIAN LI PC-V354B Black Aluminum MicroATX Mini Tower Computer Case
1 x Silverstone PP07-BTSB 11.81" Extension Power Supply Cable, 1 x 4pin to 4 x SATA connectors
I welcome any general comments or suggestions on my build choices. I also have the following specific questions:
1. Intel vs. Supermicro motherboard. I chose this Intel motherboard because I've successfully used Intel motherboards on prior (non-FreeNAS) builds and because Intel specifically states that the S1200BTSR is compatible with the Core i3 3220T. I know a lot of folks here recommend Supermicro boards. Would I be better off using a Supermicro board (for example, the MBD-X9SCM-F-O) instead of using an Intel board?
2. Ivy Bridge vs. Haswell. The 3220T is a 35W Socket 1155 3rd generation Core i3 that (like all 3rd generation Core i3s) supports ECC memory. (See http://ark.intel.com/products/65694/Intel-Core-i3-3220T-Processor-3M-Cache-2_80-GHz). For almost the same money, I could instead use an i3-4130T, which is a 35W Socket 1150 4th generation Core i3 that (like all 4th generation Core i3s) also supports ECC memory. (See http://ark.intel.com/products/77481/Intel-Core-i3-4130T-Processor-3M-Cache-2_90-GHz). Oddly, Intel does not yet have any micro ATX motherboards supporting that processor, but Supermicro does - for example, the Supermicro MBD-X10SLM-F-O. Should I go with the newer Haswell CPU, or stick with the Ivy Bridge CPU?
Thanks in advance for your help.
Best regards.
Tom
My proposed build:
Best regards.
Tom
