BUILD FreeNAS + bhyve (final build)
acoustician
Usage
  • Server for me(bhyve[maybe php+mysql or smth like this]), NAS for family(4 members).
  • Plex(2 threads simultaneously maximum) + SMB + transmission/rtorrent(seedbox) + backups.
Build
Question:
1. What do you think of my build?
2. What kind of CPU do I really need?
Mirfster
Got your message, however I am not a SuperMicro user. While I could fancy up a suggested CPU; I will gladly defer to those who are more of an expert on SuperMicro Boards. With that said, I will tag @Ericloewe , @Bidule0hm and @BigDave and let their expertise guide you. ;)
*** Not trying to forget/exclude anyone else so don't nobody go getting all huffy at me... :P
jgreco
Resident Grinch
*** Not trying to forget/exclude anyone else so don't nobody go getting all huffy at me... :p
*Huff*.
It's fine.
Do you need to transcode? If not, the Pentiums are fine.
If you do, the i3 gives you enough horsepower to probably not have to worry about it.
Consider an X11SSM-F. It's cheaper and more flexible. You lose the M.2 slot, but you have more PCI-e bandwidth available overall (and one more slot, instead of the M.2 slot).
Will i ever need an SSD for cache
Probably not.
If it ends up being the case and you want to spend money on a PCI-e SSD, just get an M.2 adapter, or a U.2 adapter or simply a PCI card form factor SSD.
May be only 1(of 2) thread for transcoding at the same time.
Then the i3 is a better option.
