SOLVED Lost Volume after upgrade to 11.1, working now on 11.0 u4
i4m
ThinkServer TS440
4 CPUs x Intel(R) Xeon(R) CPU E3-1245 v3 @ 3.40GHz
ESXI 6.0 u3, 32GB ram, 4 x 2TB HDD attached to LSI LSI1068E raid card in raid-z1 pool called nas, 1 x 1TB HDD, 1 x 250GB SDD.
i upgraded from 11.0 u3 to 11.1 without issue. a few days later i was unable to access any shared drives and the gui was unresponsive. i reloaded my machine and at bootup it was stuck at importing pool, eventually i got a "slow spa_sync" message. I searched the net and found others, some time ago, with this same issue who left their systems and they restored themselves. I left my system in this state for over a week and the fault remained.
I created a fresh vm, installed 11.0 u4 and moved my raw disks from the broken vm to this new one, although in the gui the new 11.0 u4 vm can see the individual disks it won't see the pool to import as a volume. i then tried the same with 9.3 with the same results
i then moved the raw disks back to the original vm :
i managed to load "FreeNAS-9.3-STABLE-201509022158" and it shows the pool and allows me to import the volume and all my data appears intact.
i then managed to load 11.0 u1 and my pool loaded fine again all data present
i then managed to load 11.0 u3 and my pool loaded fine again all data present
i then managed to load 11.0 u4 and again my pool loaded fine all data present
I'm sticking with 11.0 u4 for the moment.
I started writing this post as a call for help, but have managed to get up and running through the course of gathering info for the post. Im shareing in case it helps someone else.
Well, that title is misleading. The pool was never "lost", it just wouldn't import due to a bug in 11.1. It sounds like a trivial distinction, but it does make a difference.
i4m
yes it is trivial :).
when it happens, it is lost to you, all your data is unavailable. Once you've worked out how to get it back its not lost. Then you work out its a bug in the new OS. :)
When something is gone and you no longer have it its generally described as lost.
Back to the issue i was faced with......
i was unsuccessful importing the volume in a new vm and i'm not sure why, i'll need to understand why in case i have the need to import the volume in a new vm again.
FreeBSD 11.0-STABLE (FreeNAS.amd64) #0 r321665+25fe8ba8d06(freenas/11.0-stable): Mon Sep 25 06:24:11 UTC 2017
	FreeNAS (c) 2009-2015, The FreeNAS Development Team
	All rights reserved.
	FreeNAS is released under the modified BSD license.
	For more information, documentation, help or support, go here:
	http://freenas.org
Welcome to FreeNAS
[root@freenas] ~# zpool import
   pool: freenas-boot
  state: ONLINE
 status: Some supported features are not enabled on the pool.
 action: The pool can be imported using its name or numeric identifier, though
	some features will not be available without an explicit 'zpool upgrade'.
	freenas-boot  ONLINE
	  da0p2	 ONLINE
   pool: nas
  state: ONLINE
 action: The pool can be imported using its name or numeric identifier.
	nas											 ONLINE
	  raidz1-0									  ONLINE
		gptid/2e4ded5e-4737-11e3-a697-009c02abd7cd  ONLINE
		gptid/2ef6184c-4737-11e3-a697-009c02abd7cd  ONLINE
		gptid/d372c18b-4808-11e3-94b2-009c02abd7cd  ONLINE
		gptid/69dc2257-ad23-11e3-93a0-009c02abd7cd  ONLINE
	  gptid/587b7a88-9c12-11e5-8338-000c2902e55b	ONLINE
	cache
	  da6p1
	logs
	  gptid/47ed0870-9c14-11e5-8338-000c2902e55b	ONLINE
[root@freenas] ~# zpool status Storage -v
cannot open 'Storage': no such pool
cannot open '-v': name must begin with a letter
[root@freenas] ~# zpool status nas -v
  pool: nas
 state: ONLINE
  scan: scrub repaired 0 in 228h41m with 0 errors on Tue Jan  9 04:42:04 2018
	NAME											STATE	 READ WRITE CKSUM
	nas											 ONLINE	   0	 0	 0
	  raidz1-0									  ONLINE	   0	 0	 0
		gptid/2e4ded5e-4737-11e3-a697-009c02abd7cd  ONLINE	   0	 0	 0
		gptid/2ef6184c-4737-11e3-a697-009c02abd7cd  ONLINE	   0	 0	 0
		gptid/d372c18b-4808-11e3-94b2-009c02abd7cd  ONLINE	   0	 0	 0
		gptid/69dc2257-ad23-11e3-93a0-009c02abd7cd  ONLINE	   0	 0	 0
	  gptid/587b7a88-9c12-11e5-8338-000c2902e55b	ONLINE	   0	 0	 0
	logs
	  gptid/47ed0870-9c14-11e5-8338-000c2902e55b	ONLINE	   0	 0	 0
	cache
	  da6p1										 ONLINE	   0	 0	 0
errors: No known data errors
anyone able to offer an insight as to why i was unable to import the volume in a new instance even though the raw disks where online to the freenas OS?
Thanks
I see a pool "nas" that is already imported. If it doesn't show up in the GUI, it's because you went around its back and imported it in the CLI.
i4m
thats interesting,
when i create a new disk in the vm, install freenas on it, change the bios disk order and boot it, i see the pool available for import.
but i don't when i do the same from a new vm instance.
Export it from the CLI. Then you can import it from the GUI.
  • Like
Reactions: i4m
i4m
Thanks Eric,
can you advise on the procedure for CLI export?
You managed to zpool import it just fine, so zpool export poolname
  • Like
Reactions: i4m
i4m
Thanks Eric,
the pool import however i did it was many years ago, prob 2013 when i was doing global support on a redhat based product and i was more familiar with required syntax for zfs on freebasd. i've been back on networks for a few years now and a lot of the commands needed for specific procedures are out of my head, hence the ask. But thanks.
