Link aggregation failover doesn't work
Lucas Rey
Dear all, I've configured the following link aggregation in failover mode (below the interfaces configuration).
em0 is the master/active interface, so if the interface goes down I'm expecting em1 take all the traffic.
The problem is when I setup em0 as down:
[root@freenas] ~# ifconfig em0 down
lagg0 interface will activate em1:
laggport: em1 flags=4<ACTIVE>
laggport: em0 flags=1<MASTER>
But I loose all the connections... Seems failover doesn't work, but why??? :confused:
[root@freenas] ~# ifconfig lagg0
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM>
        ether 00:50:56:3b:76:64
        inet 192.168.10.169 netmask 0xffffff00 broadcast 192.168.10.255
        media: Ethernet autoselect
        status: active
        laggproto failover
        laggport: em1 flags=0<>
        laggport: em0 flags=5<MASTER,ACTIVE>
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
[root@freenas] ~# ifconfig em1
em1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        status: active
Lucas Rey
What does the switch side look like?
I'm using VMWare... Probably the problem is there, but where?
I used VMWare because I want to make some test prior to configure a "real" environment! :rolleyes:
Lucas Rey
OK, definitely it was VMWare issue (for unknown reasons). In production system links aggregation works perfect!
