rwfitzy
 - Nov 20, 2014
My first jail with iocage and not able to see network. Problem with ping after started, I read a post about the error:
I did issue a
The IP assigned to the jail and on the
Also, is the VNET setup stable?
ping: ssend socket: Operation not permitted
I did issue a
 iocage set allow_raw_sockets=1 monitor. From the jail, I can now ping itself and the FreeNAS server lagg interfaces, but nothing else. Here is my ifconfig from the jail:Code:
root@monitor:~ # ifconfig em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:15:17:2d:5d:8e hwaddr 00:15:17:2d:5d:8e inet 208.x.x.24 netmask 0xffffffc0 broadcast 208.x.x.63 media: Ethernet autoselect (1000baseT <full-duplex>) status: active em1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:15:17:2d:5d:8f hwaddr 00:15:17:2d:5d:8f media: Ethernet autoselect (1000baseT <full-duplex>) status: active em2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:15:17:2d:5d:8f hwaddr 00:11:0a:56:f3:7e media: Ethernet autoselect (1000baseT <full-duplex>) status: active em3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:15:17:2d:5d:8e hwaddr 00:11:0a:56:f3:7f media: Ethernet autoselect (1000baseT <full-duplex>) status: active em4: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:15:17:2d:5d:8f hwaddr 00:30:48:74:fe:40 media: Ethernet autoselect (1000baseT <full-duplex>) status: active em5: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:15:17:2d:5d:8f hwaddr 00:30:48:74:fe:41 media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> groups: lo lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:15:17:2d:5d:8f media: Ethernet autoselect status: active groups: lagg laggproto lacp lagghash l2,l3,l4 laggport: em1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: em2 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: em4 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: em5 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> lagg1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:15:17:2d:5d:8e media: Ethernet autoselect status: active groups: lagg laggproto lacp lagghash l2,l3,l4 laggport: em0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: em3 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:58:53:b2:af:00 groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 12 priority 128 path cost 2000 member: lagg1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 9 priority 128 path cost 10000 epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:93:90:00:0c:0a hwaddr 02:93:90:00:0c:0a media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
 em0 interface is the same subnet as thge IP assigned to the  lagg1 interface. I enabled ssh and can log in from the FreeNAS server with long wait time for a password prompt. Cannot ping gateway of server. Do I need to add a default route to the rc.conf file?Also, is the VNET setup stable?
