KDB: enter: panic
F1aX
Hello.
My Freenas crashed today for no obvious reason.
I logged in via IPMI and found this message. Attached screenshot.
I've rebooted 3times and it hangs with the same message every time after a couple of minutes.
Logs show nothing.
Latest freenas.
C2750D4I, 4x8gb ecc ram, 6x2tb hdd.
Any ideas?
edit. It boots fine, but then suddenly crashes again.
D
dlavigne
Guest
Looks like the boot device died. Reinstall onto another stick and restore your saved config.
F1aX
Hmm. It's a mirror, so should work then?
Redcoat
I suggest that you contact ASRock ASAP - many of us here got replacement boards under warranty - see here
