Jail / plugin can't write to a !foldername anymore?
diskdiddler
I recently updated my QBittorrent to 3.3.15 according to the updated guide by Dietrich (thank you)
However my mount point is the same, yet I can't get QBit to move the completed files to
/media/ (mount point)
/media/download/!completed
(note the !)
Any ideas?
joeschmuck
Old Man
This is off the cuff but did you by chance start using user qbittorent vice root which is what you had been using before? I'm just thinking it could be a permissions thing if you are now using a different user to run the qbittorent daemon. I don't see why this would make a difference honestly. Have you checked out the qbitorrent forum (if one exists) to see if this is a common issue?
diskdiddler
I found that the guide, I have never needed to do the whole permission groups thing.
I mean I can shell in and manually change to the directory using the qbit jail. Don't know if I can create a folder within it, but I can test.
diskdiddler
I have done further testing and I'm almost entirely convinced the "move to, when complete" code in 3.3.15 is broken - is anyone else seeing this?
I've entirely changed paths on my server, to some test paths
It's now /media/1/ /media/2/ and /media/3/
