Issues setting up a Win 10 VM in Truenas
When loading the VirtIO drivers during Windows 10 Setup to make a disk/partiton available on which Windows can be installed the system always brings up the following message.
So at the moment it doesnt work for me to set up a standard Win 10 VM, which is urgently needed.
What can I do to load the Drivers to get a partition?
HolyK
Ninja Turtle
One of the way is to modify the installation (use nLite for example) and integrate the drives to the installation. Then it will install just fine.
Thanks for the hint, I will try that out.
Is the cause of my described issue known? I mean in every youtube Tutorial know one has this issue when loading Virtio-Drivers.
Integrating the virtio-drivers via ntlite worked like a charm - thanks!
