HI folks,
I need to build a fast node for algorithmic computations. I'm thinking to use 2x Xeon GOLD 6136 for that.
Currently I'm using Rancher and all my deployments and workflows are kubectl based. My rancher installation is based on ubuntu nodes, which are VMs inside TrueNas Core, so I pretty slow with all these overheads.
I think I have two options:
- Use SCALE on the compute node and jus deploy my services there? I guess I can fine tube how many cores/threads can be used by pods and pods will have access to it without any overheads?
- Install ubuntu on the compute node and add it as a node into my current rancher orchestration?
Also, with SCALE:
- can I assign DIRECT access to NVME disks for the certain nodes?
- can I run VMs if necessary (similar to VMs in CORE)?
And finally, for higher performance and future proof should I go, for example, with 2x Skylake Xeon Gold 6136 or EPYC 7401P, or save some money and stick with two Xeon E5 2(6|7|8|9)xx?
Thanks!
Also, with SCALE:
Thanks!
