TrueCommand - Not able to create 3 node cluster
So i have a very strange issue, I have 3 supermicro 4U 24 bay nodes.
When i go to create any 3 node cluster for the servers, i can select nodes 1 and 2 or node 3 by itself, it will not allow me to select all 3 nodes to create the cluster.
I have installed a license as well to make sure i was not hitting the 50 disk limit
I am going to be posting this in both TrueNas Scale forums and in the TrueCommand forums as i am not sure which system is causing this issue
Node 1
Platform: Generic
Version: TrueNAS-SCALE-22.02.1
HostName: ArchiveNode1
Motherboard: X9DR3-LN4F+
Motherboard Firmware: 3.48
Intel(R) Xeon(R) CPU E5-2643 0 @ 3.30GHz 2x cpu's
196.7 GiB ECC Memory
Pri-Pool
Pool Status:
ONLINE
Used Space:
0%
Disks with Errors:
0
Path:
/mnt/Pri-Pool
Free Space:
145.19 TiB
Total Disks:
24 (data)
Data:
4 vdev
Caches:
0
Spares:
0
Node 2
Platform: Generic
HostName: ArchiveNode2
Motherboard Firmware: 2.10
Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz 2x cpu's
125.9 GiB ECC Memory
Pri-Pool
Pool Status:
ONLINE
Used Space:
0%
Disks with Errors:
0
Path:
/mnt/Pri-Pool
Free Space:
145.19 TiB
Total Disks:
24 (data)
Data:
4 vdev
Caches:
0
Spares:
0
Node 3
Platform: Generic
HostName: ArchiveNode3
Motherboard: X10DRH-C
Motherboard Firmware: 3.91.00
Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz 2x cpu's
112.9 GiB ECC Memory
Pri-Pool
Pool Status:
ONLINE
Used Space:
0%
Disks with Errors:
0
Path:
/mnt/Pri-Pool
Free Space:
145.19 TiB
Total Disks:
24 (data)
Data:
4 vdev
Caches:
0
Spares:
0
Kris Moore
SVP of Engineering
Administrator
This was a known bug, but good news is I think we've resolved it here. Update will be going out for SCALE 22.02.2 next Tuesday 6/21, and then TC nightly image which has a support for cluster building (Including SMB shares). Hang tight, be available in a few days.
omg, i was seriously thinking i was losing my mind, i rebuilt my environment 3 times incase i did something wrong.
Thank you, Thank you. I will be eagerly awaiting the update.
