gunnahafta
- Nov 5, 2018
I updated last night to:
Version:
TrueNAS-12.0-U4
FreeBSD 12.2-RELEASE-p6 df578562304(HEAD) TRUENAS (from cli when logging in via putty)
I notice right away in the dashboard the CPU widget it will only load the average cpu usage in the middle of the dial at the time the page loads. Doesn't change after that and doesn't show CPU temp at all. Also it doesn't show the CPU usage (total and across all cores) nor the CPU temp (total and across all cores) counters at all.
However if i click the CPU Reports icon in the top right I get a historic graph pretty much right up to the point of opening the screen showing CPU usage, system load, CPU temp plus all the stats like min, max, mean etc. But it update from there unless I reload again.
Version:
TrueNAS-12.0-U4
