Dashboard Widgets Not Loading
dudemanbacon
I'm experiencing the following issues with the Dashboard widgets. Memory Usage, CPU Usage and CPU Temp widgets on the Dashboard will not load at all. The Storage widget only loads the left half, showing the amount of available storage, the right side displays "Disk details not available". The Load Average and Network Info widgets load just fine.
OS Version:
FreeNAS-11.2-U2.1
(Build Date: Feb 27, 2019 20:59)
Processor:
Intel(R) Xeon(R) CPU X5675 @ 3.07GHz (24 cores)
Memory:
20 GiB
I searched the forums and found some related/similar bugs, but they are all closed, stating they were fixed in the Beta3 patch. Does anyone know how I can troubleshoot this? Thanks in advance.
Redcoat
skywise_ca
I'm having the same issue, no updates from bandwidth, memory, or any of the CPU related widgets. (nice blue bars sweeping across the top though)
I'm up at FreeNAS-11.2-U5.
davenpro
I too am having the same widget issues (along with blue sweeping bars up top) since upgrading to 11.2. I'm currently on FreeNAS-11.2-U5, but would love for this to get resolved.
