cronsloth
- Jul 26, 2017
I'm not entirely sure if this is a known issue or just me not knowing all the underpinnings of how IPMI functions. But Here is my issue if anyone has any insight.
I have a SuperMicro Server w/IPMI:
Product Name: X9DRL-3F/iF
I also have 'LAGG' configured to port bond my two NIC's on the server. So IPMI is sharing the same NIC(s) with the LAGG.
Everything was working fine until I needed to reboot our server. Since the reboot, IPMI isn't pingable, or available via HTTP or HTTPS. However, within the FreeNAS terminal, IPMITool shows it is setup and running properly.
I'm wondering if, due to the LAGG setup or the way IPMI chooses a NIC it may have gotten confused or something and disallowed access to itself.
I attached some output but I can do other commands if someone has a suggestion.
If it helps, nMAP scan results in showing HTTP and HTTPS as 'filtered'....yes, nmap returns a result when PING doesn't....sounds software based to me in that it is blocking connections but I could be wrong, and don't know how to change it using 'IPMITOOL' or 'IPMICFG'
Thanks in advance....
(ps I changed the values of my MAC address, IP, etc. but they are correctly setup in real life)
[root@freenas ~]# ipmitool chassis status System Power : on Power Overload : false Power Interlock : inactive Main Power Fault : false Power Control Fault : false Power Restore Policy : always-off Last Power Event : Chassis Intrusion : inactive Front-Panel Lockout : inactive Drive Fault : false Cooling/Fan Fault : false [root@freenas ~]# ipmitool lan print 1 Set in Progress : Set Complete Auth Type Support : NONE MD2 MD5 PASSWORD Auth Type Enable : Callback : MD2 MD5 : User : MD2 MD5 : Operator : MD2 MD5 : Admin : MD2 MD5 : OEM : MD2 MD5 PASSWORD IP Address Source : Static Address IP Address : 10.10.0.101 Subnet Mask : 255.255.255.0 MAC Address : 00:25:90:ff:ff:ff SNMP Community String : public IP Header : TTL=0x00 Flags=0x00 Precedence=0x00 TOS=0x00 BMC ARP Control : ARP Responses Enabled, Gratuitous ARP Disabled Default Gateway IP : 10.10.0.1 Default Gateway MAC : 00:00:00:00:00:00 Backup Gateway IP : 0.0.0.0 Backup Gateway MAC : 00:00:00:00:00:00 802.1q VLAN ID : Disabled 802.1q VLAN Priority : 0 RMCP+ Cipher Suites : 1,2,3,6,7,8,11,12 Cipher Suite Priv Max : aaaaXXaaaXXaaXX : X=Cipher Suite Unused : c=CALLBACK : u=USER : o=OPERATOR : a=ADMIN : O=OEM Bad Password Threshold : Not Available
