I had my FreeNAS box set up to use DHCP and my router was configured to assign it a static/reserved IP.
The other day I switched ISPs and routers, and forgot about this configuration. When I reset the FreeNAS box, it changed IP addresses and is working for the most part but all of my jails are gone.
Can I set FreeNAS to use a static IP to change it back to the former IP? Will this fix my jail issue or is that unrelated?
Unfortunately setting up my new router to assign it a static IP is proving difficult...
