koolcats123
- Feb 22, 2017
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 ada0: <WDC WD40EFRX-68WT0N0 82.00A82> ACS-2 ATA SATA 3.x device ada0: Serial Number WD-WCC4E0YY99HK ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 3815447MB (7814037168 512 byte sectors) ada0: quirks=0x1<4K> ada0: Previously was known as ad4 ada1 at ahcich1 bus 0 scbus1 target 0 lun 0 ada1: <WDC WD40EFRX-68WT0N0 82.00A82> ACS-2 ATA SATA 3.x device ada1: Serial Number WD-WCC4E7EXPT4T ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 3815447MB (7814037168 512 byte sectors) ada1: quirks=0x1<4K> ada1: Previously was known as ad6 ada2 at ata2 bus 0 scbus2 target 0 lun 0 ada2: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device ada2: Serial Number Z3035Y35 ada2: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes) ada2: 3815447MB (7814037168 512 byte sectors) ada2: quirks=0x1<4K> ada2: Previously was known as ad8 ada3 at ata3 bus 0 scbus3 target 0 lun 0 ada3: <ST4000DM000-2AE166 0001> ACS-3 ATA SATA 3.x device ada3: Serial Number WDH0XV9N ada3: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes) ada3: 3815447MB (7814037168 512 byte sectors) ada3: quirks=0x1<4K> ada3: Previously was known as ad10 ada4 at ata4 bus 0 scbus4 target 0 lun 0 ada4: <ST4000DM000-2AE166 0001> ACS-3 ATA SATA 3.x device ada4: Serial Number WDH0VVPR ada4: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes) ada4: 3815447MB (7814037168 512 byte sectors) ada4: quirks=0x1<4K> ada4: Previously was known as ad12 ada5 at ata5 bus 0 scbus5 target 0 lun 0 ada5: <WDC WD20EARX-008FB0 51.0AB51> ATA8-ACS SATA 3.x device ada5: Serial Number WD-WCAZAH025808 ada5: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes) ada5: 1907729MB (3907029168 512 byte sectors) ada5: quirks=0x1<4K> ada5: Previously was known as ad14 da0 at umass-sim0 bus 0 scbus7 target 0 lun 0 da0: <ADATA USB Flash Drive 1100> Removable Direct Access SPC-4 SCSI device da0: Serial Number 14B2417581240014 da0: 400.000MB/s transfers da0: 59200MB (121241600 512 byte sectors) da0: quirks=0x2<NO_6_BYTE> SMP: AP CPU #2 Launched! SMP: AP CPU #1 Launched! SMP: AP CPU #3 Launched! Timecounter "TSC-low" frequency 1496630730 Hz quality 1000 Trying to mount root from zfs:freenas-boot/ROOT/default []... <118>Loading early kernel modules: GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) <118>savecore: reboot after panic: Solaris(panic): blkptr at 0xfffffe001362f2c0 has invalid CHECKSUM 0 <118>savecore: writing compressed core to /data/crash/textdump.tar.3.gz <118>/data/crash/vmcore.3 not found <118>Setting hostuuid: 5eda2040-5bcb-11d9-857a-5404a667a51d. <118>Setting hostid: 0x92bf3fa0. <118>No suitable dump device was found. <118>Entropy harvesting: interrupts ethernet point_to_point swi. <118>Starting file system checks: <118>Mounting local file systems:. <118>Beginning ZFS volume imports <118> <118> Importing 17177318048554058877 <118> <118><118> spa=Extra async request task=1 txg 599593 open pool version 5000; software version 5000/5; uts 10.3-STABLE 1003510 amd64 spa=Extra async request task=32 txg 599595 import pool version 5000; software version 5000/5; uts 10.3-STABLE 1003510 amd64 <118>ZFS volume imports complete <118>Loading kernel modules: hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/8/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI> <118>Writing entropy file:. <118>Setting hostname: freenas.local. <118>ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib /usr/local/lib/compat /usr/local/lib/nss /usr/local/lib/perl5/5.20/mach/CORE <118>32-bit compatibility ldconfig path: /usr/lib32 /usr/local/lib32/compat <5>re0: link state changed to DOWN <118>Starting dhclient. <118>re0: no link ...... <5>re0: link state changed to UP <118> got link <118>DHCPDISCOVER on re0 to 255.255.255.255 port 67 interval 4 <118>DHCPOFFER from 192.168.0.1 <118>DHCPREQUEST on re0 to 255.255.255.255 port 67 <118>DHCPACK from 192.168.0.1 <118>bound to 192.168.0.23 -- renewal in 60 seconds. <118>Starting Network: lo0 re0. <118>lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 <118> options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> <118> inet6 ::1 prefixlen 128 <118> inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 <118> inet 127.0.0.1 netmask 0xff000000 <118> nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> <118>re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 <118> options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> <118> ether 54:04:a6:67:a5:1d <118> inet 192.168.0.23 netmask 0xffffff00 broadcast 192.168.0.255 <118> nd6 options=9<PERFORMNUD,IFDISABLED> <118> media: Ethernet autoselect (1000baseT <full-duplex>) <118> status: active <118>Starting devd. ums0: <Logitech USB Laser Mouse, class 0/0, rev 2.00/56.01, addr 3> on usbus2 ums0: 8 buttons and [XYZT] coordinates ID=0 uhid0: <NOVATEK USB Keyboard, class 0/0, rev 1.10/1.04, addr 4> on usbus2 <118>Starting ums0 moused. <118>add net fe80::: gateway ::1 <118>add net ff02::: gateway ::1 <118>add net ::ffff:0.0.0.0: gateway ::1 <118>add net ::0.0.0.0: gateway ::1 <118>Generating host.conf. <118>Warning: unrecognized source [mdns] <118>[: False: bad number <118>Starting syslog_ng. <118>Creating and/or trimming log files. <118>Starting watchdogd. GEOM_ELI: Device ada5p1.eli created. GEOM_ELI: Encryption: AES-XTS 128 GEOM_ELI: Crypto: hardware <118>Setting up system for textdumps. <118>debug.ddb.textdump.pending: 0 -> 1 <118>debug.debugger_on_panic: 1 -> 1 <118>No core dumps found. <118>Alarm clock <118>Updating motd:. <118>Mounting late file systems:. <118>Starting ntpd. <118>Can't load /usr/local/etc/smb4.conf - run testparm to debug it <118>/etc/rc: WARNING: failed precmd routine for vmware_guestd <118>Performing sanity check on openssh configuration. <118>Starting openssh. <118>Starting smartd. <118>Starting pbid... <118>Performing sanity check on nginx configuration: <118>nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok <118>nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful <118>Starting nginx. <118>Starting mdnsd. <118>Starting dbus. <118>Starting collectd. <118>Flushed all rules. <118>Waiting up to 5 seconds for ixdiagnose to finish... done. <118>Starting zfsd. <118>Configuring syscons: blanktime. <118>Starting cron. <118> <118>Fri Feb 17 21:31:20 EST 2017 panic: Solaris(panic): blkptr at 0xfffffe00125382c0 has invalid CHECKSUM 0 cpuid = 3 KDB: stack backtrace: db_trace_self_wrapper() at db_trace_self_wrapper+0x2b/frame 0xfffffe0456808360 kdb_backtrace() at kdb_backtrace+0x39/frame 0xfffffe0456808410 vpanic() at vpanic+0x126/frame 0xfffffe0456808450 panic() at panic+0x43/frame 0xfffffe04568084b0 vcmn_err() at vcmn_err+0xcf/frame 0xfffffe04568085e0 zfs_panic_recover() at zfs_panic_recover+0x60/frame 0xfffffe0456808640 zfs_blkptr_verify() at zfs_blkptr_verify+0xbe/frame 0xfffffe0456808680 zio_read() at zio_read+0x2f/frame 0xfffffe0456808710 spa_load_verify_cb() at spa_load_verify_cb+0x1b2/frame 0xfffffe0456808790 traverse_visitbp() at traverse_visitbp+0x293/frame 0xfffffe04568088d0 traverse_dnode() at traverse_dnode+0xd2/frame 0xfffffe0456808940 traverse_visitbp() at traverse_visitbp+0xaa8/frame 0xfffffe0456808a80 traverse_visitbp() at traverse_visitbp+0x7af/frame 0xfffffe0456808bc0 traverse_visitbp() at traverse_visitbp+0x7af/frame 0xfffffe0456808d00 traverse_visitbp() at traverse_visitbp+0x7af/frame 0xfffffe0456808e40 traverse_visitbp() at traverse_visitbp+0x7af/frame 0xfffffe0456808f80 traverse_visitbp() at traverse_visitbp+0x7af/frame 0xfffffe04568090c0 traverse_dnode() at traverse_dnode+0xd2/frame 0xfffffe0456809130 traverse_visitbp() at traverse_visitbp+0x591/frame 0xfffffe0456809270 traverse_impl() at traverse_impl+0x32e/frame 0xfffffe04568093b0 traverse_pool() at traverse_pool+0x17f/frame 0xfffffe0456809480 spa_load() at spa_load+0x1af9/frame 0xfffffe04568095c0 spa_load_best() at spa_load_best+0x6f/frame 0xfffffe0456809620 spa_import() at spa_import+0x23b/frame 0xfffffe04568096f0 zfs_ioc_pool_import() at zfs_ioc_pool_import+0xa4/frame 0xfffffe0456809740 zfsdev_ioctl() at zfsdev_ioctl+0x560/frame 0xfffffe04568097e0 devfs_ioctl_f() at devfs_ioctl_f+0x139/frame 0xfffffe0456809840 kern_ioctl() at kern_ioctl+0x255/frame 0xfffffe04568098b0 sys_ioctl() at sys_ioctl+0x140/frame 0xfffffe0456809990 amd64_syscall() at amd64_syscall+0x41e/frame 0xfffffe0456809ab0 Xfast_syscall() at Xfast_syscall+0xfb/frame 0xfffffe0456809ab0 --- syscall (54, FreeBSD ELF64, sys_ioctl), rip = 0x801a0280a, rsp = 0x7fffffffbcd8, rbp = 0x7fffffffbd50 --- KDB: enter: panic
That was the output of msgbuf.txt file when i tried to import the volume "Hayes", i tried many different commends like readonly, -R and -f but with no luck. Doing research on similar problems lead me to check the memory, which i did using memtest for 24 hours and before that trying if freenas 10 would fix it. If you want to see my zfs volume see the link at the bottom of this post, Extra is just a jail volume. Right now i don't know if this can be fixed but it would be nice if anyone can help. :)
Specs;
Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz
FreeNAS-9.10.2-U1
16GB Corsair Ram (no-ecc)
zpool import in shell;
http://i.imgur.com/HeqwPCT.png
System Specs;
http://i.imgur.com/xC4aMZ5.png
