captainkent
- Nov 12, 2016
Hi guys,
I've recently gotten into home automation, and wanted to run a domoticz jail in FreeNAS. Like many people on the forums, I stumbled upon the issue of getting my Aeotec Z-Stick Gen5 working inside my jail. After some hard work, patience and lots of Googling, I finally figured it out. See below how to do it.
Installing domoticz and open-zwave (see link)
Create a jail, and in the jail run
If running into issues with the wrong boost lib, use this guide to install an older boost lib. This is a recent bug known during the creation of this post, it might be solved soon!
Create a new user in the webgui of FreeNAS.
For open-zwave support:
See what happens when you use
To solve this, make sure you can see your Z-Wave stick being loaded, and figure out it's unique address. The output of dmesg.
Add the unique address number to /etc/devfs.rules with some extra rules.
where the number is my address number. If you add the wrong number, the rule will disappear after a reboot. Now I know my device is accessible at /dev/cuaU0 (note the capital U!).
Once this worked, I made a symbolic link to my jail
Then from within the jail, make sure to add permissions to the device
In the future I want to everything to run through domoticz:domoticz, so I added the domoticz user to the dialer group, but I'm not sure if this is neccessary. Now if I run ./MinOZW my output is:
Note that it finds the correct .xml file for my device!
Once this is all working, go ahead and compile domoticz
change the number to how many cores you're willing to use to speed up the build.
Then for autostart
and paste the following
If someone could pitch in to clean up the rc.d file that would be much appreciated!
That's it, after you have set it up, you can add the Z-Wave stick in the Domoticz webgui.
pkg update
pkg upgrade
pkg install
pkg install sqlite3 expat curl libiconv gmake cmake subversion git devel/boost-libs devel/boost-python-libs devel/boost-all
- Account -> Users -> Add User
- Fill in a username ('domoticz') and a full name
- Disable password logins
- Change the shell to ‘nologin’ to disable logins at all
- Remember the ‘user id’ (this is important! In my case it is ‘1010’)
pw useradd -n domoticz -u 1010 -m -s /sbin/nologin
cd /home/domoticz
git clone https://github.com/OpenZWave/open-zwave.git open-zwave-read-only
cd open-zwave-read-only
gmake
./MinOZW ttycuaU0
or what your correct devicename is, most likely this is where the headaches start as you won't get a proper response.To solve this, make sure you can see your Z-Wave stick being loaded, and figure out it's unique address. The output of dmesg.
umodem0 on uhub2
umodem0: <vendor 0x0658 product 0x0200, class 2/0, rev 2.00/0.00, addr 5> on usbus0
umodem0: data interface 1, has no CM over data, has no break
[devfsrules_jail_allow_usb=5]
add path 'cu*' unhide
ln -s /dev/cuaU0 /path/to/jail/dev/ttyUSB0
chown root:domoticz /dev/ttyU*
chmod 660 /dev/ttyU*
root@domoticz_1:/home/domoticz/open-zwave-read-only # ./MinOZW
Starting MinOZW with OpenZWave Version 1.4.2893
2018-01-25 09:01:25.234 Error, Cannot find a path to the configuration files at ../../../config/, Using config/ instead...
2018-01-25 09:01:25.235 Info, Reading config/options.xml for Options
2018-01-25 09:01:25.235 Warning, Failed to Parse options.xml: Failed to open file
2018-01-25 09:01:25.236 Always, OpenZwave Version 1.4.2893 Starting Up
2018-01-25 09:01:25.236 Info, Setting Up Provided Network Key for Secure Communications
2018-01-25 09:01:25.236 Warning, Failed - Network Key Not Set
2018-01-25 09:01:25.236 Info, mgr, Added driver for controller /dev/ttyUSB0
2018-01-25 09:01:25.236 Info, Opening controller /dev/ttyUSB0
2018-01-25 09:01:25.237 Info, Trying to open serial port /dev/ttyUSB0 (attempt 1)
2018-01-25 09:01:25.237 Info, Serial port /dev/ttyUSB0 opened (attempt 1)
2018-01-25 09:01:25.237 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-01-25 09:01:25.237 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-01-25 09:01:25.237 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-01-25 09:01:25.237 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-01-25 09:01:25.238 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-01-25 09:01:25.238 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-01-25 09:01:25.451 Detail, Unsolicited message received while waiting for ACK.
2018-01-25 09:01:25.452 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x33, 0x2e, 0x39, 0x35, 0x00, 0x01, 0x99
2018-01-25 09:01:25.452 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2018-01-25 09:01:25.452 Info, contrlr, Static Controller library, version Z-Wave 3.95
2018-01-25 09:01:25.452 Detail, Node045, Expected reply was received
2018-01-25 09:01:25.452 Detail, Node045, Message transaction complete
2018-01-25 09:01:25.452 Detail, contrlr, Removing current message
2018-01-25 09:01:25.453 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-01-25 09:01:25.455 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xf2, 0x9f, 0x32, 0x46, 0x01, 0xce
2018-01-25 09:01:25.455 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xf29f3246. Our node ID = 1
2018-01-25 09:01:25.455 Detail, Node159, Expected reply was received
2018-01-25 09:01:25.455 Detail, Node159, Message transaction complete
2018-01-25 09:01:25.455 Detail, contrlr, Removing current message
2018-01-25 09:01:25.455 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-01-25 09:01:25.456 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2018-01-25 09:01:25.457 Detail,
2018-01-25 09:01:25.457 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2018-01-25 09:01:25.457 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2018-01-25 09:01:25.457 Info, contrlr, The PC controller is a primary controller.
2018-01-25 09:01:25.457 Detail, Node215, Expected reply was received
2018-01-25 09:01:25.457 Detail, Node215, Message transaction complete
2018-01-25 09:01:25.457 Detail, contrlr, Removing current message
2018-01-25 09:01:25.457 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-01-25 09:01:25.461 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x00, 0x00, 0x86, 0x00, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfb
2018-01-25 09:01:25.461 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2018-01-25 09:01:25.461 Info, contrlr, Serial API Version: 1.0
2018-01-25 09:01:25.461 Info, contrlr, Manufacturer ID: 0x0086
2018-01-25 09:01:25.461 Info, contrlr, Product Type: 0x0001
2018-01-25 09:01:25.461 Info, contrlr, Product ID: 0x005a
2018-01-25 09:01:25.461 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2018-01-25 09:01:25.461 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2018-01-25 09:01:25.461 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2018-01-25 09:01:25.461 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2018-01-25 09:01:25.461 Detail, Expected reply was received
2018-01-25 09:01:25.461 Detail, Message transaction complete
2018-01-25 09:01:25.462 Detail,
2018-01-25 09:01:25.462 Detail, contrlr, Removing current message
2018-01-25 09:01:25.462 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-01-25 09:01:25.463 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2018-01-25 09:01:25.463 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2018-01-25 09:01:25.463 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2018-01-25 09:01:25.463 Detail, Node172, Expected reply was received
2018-01-25 09:01:25.464 Detail, Node172, Message transaction complete
2018-01-25 09:01:25.464 Detail, contrlr, Removing current message
2018-01-25 09:01:25.464 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2018-01-25 09:01:25.520 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x00, 0x49, 0x2f, 0x02, 0x9d, 0x51, 0xed, 0x3b, 0xdd, 0x6f, 0x61, 0x95, 0x27, 0xfc, 0xa8, 0x48, 0x48, 0xc4, 0x59, 0xbe, 0x89, 0xe0, 0xc7, 0xb4, 0x90, 0xcf, 0x5c, 0xe8, 0x44, 0xcd, 0xf9, 0xf3, 0xfc
2018-01-25 09:01:25.520 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2018-01-25 09:01:25.520 Detail, Node032, Expected reply was received
2018-01-25 09:01:25.520 Detail, Node032, Message transaction complete
2018-01-25 09:01:25.520 Detail, contrlr, Removing current message
2018-01-25 09:01:25.520 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2018-01-25 09:01:25.622 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc5
2018-01-25 09:01:25.622 Info, mgr, Driver with Home ID of 0xf29f3246 is now ready.
2018-01-25 09:01:25.622 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2018-01-25 09:01:25.622 Info, contrlr, Node 001 - New
2018-01-25 09:01:25.622 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2018-01-25 09:01:25.622 Detail, Node001, QueryStage_ProtocolInfo
2018-01-25 09:01:25.622 Detail, Node001, Queuing (Query) Get Node Protocol Info (Node=1): 0x01, 0x04, 0x00, 0x41, 0x01, 0xbb
2018-01-25 09:01:25.622 Detail, Node001, Queuing (Query) Query Stage Complete (ProtocolInfo)
2018-01-25 09:01:25.622 Info, Node001, Initializing Node. New Node: false (false)
2018-01-25 09:01:25.622 Detail, Expected reply was received
2018-01-25 09:01:25.622 Detail, Message transaction complete
2018-01-25 09:01:25.623 Detail, contrlr, Removing current message
2018-01-25 09:01:25.623 Detail, Node001, Notification: DriverReady
2018-01-25 09:01:25.623 Detail, Node001, Notification: NodeNew
2018-01-25 09:01:25.623 Detail, Node001, Notification: NodeAdded
2018-01-25 09:01:25.623 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2018-01-25 09:01:25.633 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2018-01-25 09:01:25.633 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2018-01-25 09:01:25.633 Detail, Node015, Expected reply was received
2018-01-25 09:01:25.633 Detail, Node015, Message transaction complete
2018-01-25 09:01:25.634 Detail, contrlr, Removing current message
2018-01-25 09:01:25.634 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2018-01-25 09:01:25.635 Detail, contrlr, Removing current message
2018-01-25 09:01:25.635 Info, Node001, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=1): 0x01, 0x04, 0x00, 0x41, 0x01, 0xbb
2018-01-25 09:01:25.638 Detail, Node001, Received: 0x01, 0x09, 0x01, 0x41, 0x93, 0x16, 0x01, 0x02, 0x02, 0x01, 0x33
2018-01-25 09:01:25.638 Info, Node001, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2018-01-25 09:01:25.638 Info, Node001, Protocol Info for Node 1:
2018-01-25 09:01:25.638 Info, Node001, Listening = true
2018-01-25 09:01:25.638 Info, Node001, Beaming = true
2018-01-25 09:01:25.638 Info, Node001, Routing = false
2018-01-25 09:01:25.638 Info, Node001, Max Baud Rate = 40000
2018-01-25 09:01:25.638 Info, Node001, Version = 4
2018-01-25 09:01:25.638 Info, Node001, Security = false
2018-01-25 09:01:25.641 Info, Node001, Basic device class (0x02) - Static Controller
2018-01-25 09:01:25.641 Info, Node001, Generic device Class (0x02) - Static Controller
2018-01-25 09:01:25.641 Info, Node001, Specific device class (0x01) - Static PC Controller
2018-01-25 09:01:25.641 Info, Node001, COMMAND_CLASS_BASIC is not mapped
2018-01-25 09:01:25.641 Info, Node001, Mandatory Command Classes for Node 1:
2018-01-25 09:01:25.641 Info, Node001, None
2018-01-25 09:01:25.641 Info, Node001, Mandatory Command Classes controlled by Node 1:
2018-01-25 09:01:25.641 Detail, Node022, Expected reply was received
2018-01-25 09:01:25.641 Detail, Node022, Message transaction complete
2018-01-25 09:01:25.642 Detail,
2018-01-25 09:01:25.642 Detail, Node001, Removing current message
2018-01-25 09:01:25.642 Detail, Node001, Notification: NodeProtocolInfo
2018-01-25 09:01:25.642 Detail, Node001, Notification: ValueAdded
2018-01-25 09:01:25.642 Detail, Node001, Query Stage Complete (ProtocolInfo)
2018-01-25 09:01:25.642 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2018-01-25 09:01:25.642 Detail, Node001, QueryStage_Probe
2018-01-25 09:01:25.642 Detail, Node001, QueryStage_WakeUp
2018-01-25 09:01:25.642 Detail, Node001, QueryStage_ManufacturerSpecific1
2018-01-25 09:01:25.642 Detail, Node001, Load Controller Manufacturer Specific Config
2018-01-25 09:01:25.652 Info, Product name collision: VRS15-1LZ Switch type 301 id 209 manufacturerid 1d, collides with VRS15-1LZ Binary Scene Switch, type 301 id 209 manufacturerid 1d
2018-01-25 09:01:25.652 Info, Product name collision: VRF01-1LZ Multilevel Scene Switch - 1.5A Fan type 1001 id 209 manufacturerid 1d, collides with VRF01-1LZ Quiet Fan Speed Control, type 1001 id 209 manufacturerid 1d
2018-01-25 09:01:25.655 Info, Node001, Opening config param file config/aeotec/zw090.xml
2018-01-25 09:01:25.655 Detail, Node001, QueryStage_NodePlusInfo
2018-01-25 09:01:25.655 Detail, Node001, QueryStage_SecurityReport
2018-01-25 09:01:25.655 Detail, Node001, QueryStage_ManufacturerSpecific2
2018-01-25 09:01:25.655 Detail, Node001, QueryStage_Versions
2018-01-25 09:01:25.655 Detail, Node001, QueryStage_Instances
2018-01-25 09:01:25.655 Info, Node001, Essential node queries are complete
2018-01-25 09:01:25.655 Detail, Node001, QueryStage_Static
2018-01-25 09:01:25.655 Detail, Node001, QueryStage_Associations
2018-01-25 09:01:25.655 Detail, Node001, QueryStage_Neighbors
2018-01-25 09:01:25.655 Detail, Requesting routing info (neighbor list) for Node 1
2018-01-25 09:01:25.655 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2018-01-25 09:01:25.655 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2018-01-25 09:01:25.655 Detail, Node001, Notification: EssentialNodeQueriesComplete
2018-01-25 09:01:25.656 Detail,
2018-01-25 09:01:25.656 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2018-01-25 09:01:25.660 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2018-01-25 09:01:25.660 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2018-01-25 09:01:25.660 Info, Node001, Neighbors of this node are:
2018-01-25 09:01:25.660 Info, Node001, (none reported)
2018-01-25 09:01:25.660 Detail, Expected reply was received
2018-01-25 09:01:25.660 Detail, Message transaction complete
2018-01-25 09:01:25.660 Detail, Node001, Removing current message
2018-01-25 09:01:25.660 Detail, Node001, Query Stage Complete (Neighbors)
2018-01-25 09:01:25.660 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2018-01-25 09:01:25.660 Detail, Node001, QueryStage_Session
2018-01-25 09:01:25.661 Detail, Node001, QueryStage_Dynamic
2018-01-25 09:01:25.661 Detail, Node001, QueryStage_Configuration
2018-01-25 09:01:25.661 Detail, Node001, QueryStage_Complete
2018-01-25 09:01:25.661 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-01-25 09:01:25.661 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2018-01-25 09:01:25.661 Info, Node query processing complete.
2018-01-25 09:01:25.661 Detail, Node001, Notification: NodeQueriesComplete
2018-01-25 09:01:25.661 Detail, contrlr, Notification: AllNodesQueried
cd /home/domoticz/
git clone https://github.com/domoticz/domoticz.git domoticz
cd domoticz
cmake -DCMAKE_BUILD_TYPE=Release
make -j 2
Then for autostart
nano /usr/local/etc/rc.d/domoticz
#! /bin/sh
# PROVIDE: domoticz
# REQUIRE: LOGIN cleanvar
# KEYWORD: shutdown
# Add the following lines to /etc/rc.conf to enable domoticz:
#domoticz_enable (bool): set to "YES" to start domotics at boot
#domoticz_dbdir (str): Default to "/var/db/domoticz"
# domoticz database directory
#domoticz_user (str): Default to www, user for starting domoticz
#domoticz_group (str): Default to www, group for stating domoticz
#domoticz_pidfile (str): Custum PID file path and name
# Default to "/var/run/domoticz/${hostname}.pid".
#domoticz_args (str): Custom additional arguments to be passed
. /etc/rc.subr
name="domoticz"
rcvar="domoticz_enable"
stop_cmd="${name}_stop"
load_rc_config $name
: ${domoticz_dbdir:="/home/domoticz/domoticz"}
: ${domoticz_user:=root}
: ${domoticz_group:=wheel}
: ${domoticz_enable:=NO}
: ${domoticz_directory:=/home/domoticz/domoticz/domoticz}
: ${domoticz_args:="-syslog -daemon"}
#: ${domoticz_args:="-syslog -dbase /home/domoticz/domoticz/db/domoticz.db -daemon -wwwbind 0.0.0.0 -p /var/run/domoticz_1.pid"}
pidfile=${domoticz_pidfile:-"/var/run/domoticz/${hostname}.pid"}
command="/home/domoticz/domoticz/domoticz"
command_args="-dbase ${domoticz_dbdir}/domoticz.db -pidfile ${pidfile} ${domoticz_args}"
domoticz_stop() {
if [ -e "${pidfile}" ]; then
echo "Stopping ${name}..."
kill -9 `cat ${pidfile}`
rm ${pidfile}
else
run_rc_command "$1"
