is my drive failing?
What is failing?
  • Drive
    Votes: 5 100.0%
  • Cable
    Votes: 0 0.0%
  • Port
    Votes: 0 0.0%
  • Total voters
    5
Baenwort
So first I got:
Oct. 29, 2018, 2:04 p.m. - Device: /dev/da2 [SAT], Self-Test Log error count increased from 2 to 3
So I then ran a smartctl test and got the following results:
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 709 minutes for test to complete.
Test will complete after Tue Oct 30 11:00:06 2018
Use smartctl -X to abort test.
root@thing:~ # smartctl -A /dev/da2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   199   051	Pre-fail  Always	   -	   15
  3 Spin_Up_Time			0x0027   232   201   021	Pre-fail  Always	   -	   7383
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   106
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   055   055   000	Old_age   Always	   -	   32903
 10 Spin_Retry_Count		0x0032   100   100   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   100   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   101
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   55
193 Load_Cycle_Count		0x0032   191   191   000	Old_age   Always	   -	   28663
194 Temperature_Celsius	 0x0022   120   110   000	Old_age   Always	   -	   32
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   224
root@thing:~ # smartctl -x /dev/da2
Model Family:	 Western Digital Red
Device Model:	 WDC WD60EFRX-68MYMN1
Serial Number:	WD-WX21D84PDDT3
LU WWN Device Id: 5 0014ee 20b09eae1
Firmware Version: 82.00A82
User Capacity:	6,001,175,126,016 bytes [6.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5700 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Tue Oct 30 17:52:19 2018 CDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  ( 113) The previous self-test completed having
										the read element of the test failed.
data collection:				( 5564) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
recommended polling time:		( 709) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x303d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAGS	VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate	 POSR-K   200   199   051	-	15
  3 Spin_Up_Time			POS--K   232   201   021	-	7383
  4 Start_Stop_Count		-O--CK   100   100   000	-	106
  5 Reallocated_Sector_Ct   PO--CK   200   200   140	-	0
  7 Seek_Error_Rate		 -OSR-K   200   200   000	-	0
  9 Power_On_Hours		  -O--CK   055   055   000	-	32904
 10 Spin_Retry_Count		-O--CK   100   100   000	-	0
 11 Calibration_Retry_Count -O--CK   100   100   000	-	0
 12 Power_Cycle_Count	   -O--CK   100   100   000	-	101
192 Power-Off_Retract_Count -O--CK   200   200   000	-	55
193 Load_Cycle_Count		-O--CK   191   191   000	-	28666
194 Temperature_Celsius	 -O---K   121   110   000	-	31
196 Reallocated_Event_Count -O--CK   200   200   000	-	0
197 Current_Pending_Sector  -O--CK   200   200   000	-	0
198 Offline_Uncorrectable   ----CK   100   253   000	-	0
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	0
200 Multi_Zone_Error_Rate   ---R--   200   200   000	-	224
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
							|||____ S speed/performance
							||_____ O updated online
							|______ P prefailure warning
General Purpose Log Directory Version 1
SMART		   Log Directory Version 1 [multi-sector log support]
Address	Access  R/W   Size  Description
0x00	   GPL,SL  R/O	  1  Log Directory
0x01		   SL  R/O	  1  Summary SMART error log
0x02		   SL  R/O	  5  Comprehensive SMART error log
0x03	   GPL	 R/O	  6  Ext. Comprehensive SMART error log
0x06		   SL  R/O	  1  SMART self-test log
0x07	   GPL	 R/O	  1  Extended self-test log
0x09		   SL  R/W	  1  Selective self-test log
0x10	   GPL	 R/O	  1  NCQ Command Error log
0x11	   GPL	 R/O	  1  SATA Phy Event Counters log
0x21	   GPL	 R/O	  1  Write stream error log
0x22	   GPL	 R/O	  1  Read stream error log
0x30	   GPL,SL  R/O	  9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W	 16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS	  16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS	   1  Device vendor specific log
0xb7	   GPL,SL  VS	  40  Device vendor specific log
0xbd	   GPL,SL  VS	   1  Device vendor specific log
0xc0	   GPL,SL  VS	   1  Device vendor specific log
0xc1	   GPL	 VS	  93  Device vendor specific log
0xe0	   GPL,SL  R/W	  1  SCT Command/Status
0xe1	   GPL,SL  R/W	  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 33 (device log contains only the most recent 24 errors)
		CR	 = Command Register
		FEATR  = Features Register
		COUNT  = Count (was: Sector Count) Register
		LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
		LH	 = LBA High (was: Cylinder High) Register	]   LBA
		LM	 = LBA Mid (was: Cylinder Low) Register	  ] Register
		LL	 = LBA Low (was: Sector Number) Register	 ]
		DV	 = Device (was: Device/Head) Register
		DC	 = Device Control Register
		ER	 = Error register
		ST	 = Status register
Error 33 [8] occurred at disk power-on lifetime: 32894 hours (1370 days + 14 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 01 b1 56 99 a8 40 00  Error: UNC at LBA = 0x1b15699a8 = 7270209960
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 01 00 00 00 00 01 b1 56 91 a8 40 00 43d+13:31:16.977  READ FPDMA QUEUED
  60 01 00 00 38 00 01 b1 56 90 a8 40 00 43d+13:31:16.925  READ FPDMA QUEUED
  60 01 00 00 30 00 01 b1 56 8f a8 40 00 43d+13:31:16.925  READ FPDMA QUEUED
  60 01 00 00 28 00 01 b1 56 8e a8 40 00 43d+13:31:16.925  READ FPDMA QUEUED
  60 01 00 00 20 00 01 b1 56 8d a8 40 00 43d+13:31:16.925  READ FPDMA QUEUED
Error 32 [7] occurred at disk power-on lifetime: 32894 hours (1370 days + 14 hours)
  40 -- 51 00 00 00 01 b0 9a 2d 90 40 00  Error: UNC at LBA = 0x1b09a2d90 = 7257861520
  60 01 00 00 38 00 01 b0 9a 34 78 40 00 43d+13:30:54.457  READ FPDMA QUEUED
  60 01 00 00 30 00 01 b0 9a 33 78 40 00 43d+13:30:54.456  READ FPDMA QUEUED
  60 01 00 00 28 00 01 b0 9a 32 78 40 00 43d+13:30:54.456  READ FPDMA QUEUED
  60 01 00 00 20 00 01 b0 9a 31 78 40 00 43d+13:30:54.456  READ FPDMA QUEUED
  60 01 00 00 18 00 01 b0 9a 30 78 40 00 43d+13:30:54.456  READ FPDMA QUEUED
Error 31 [6] occurred at disk power-on lifetime: 32894 hours (1370 days + 14 hours)
  40 -- 51 00 00 00 01 b0 98 4f 30 40 00  Error: UNC at LBA = 0x1b0984f30 = 7257739056
  60 01 00 00 38 00 01 b0 98 55 c0 40 00 43d+13:30:44.919  READ FPDMA QUEUED
  60 01 00 00 30 00 01 b0 98 54 c0 40 00 43d+13:30:44.919  READ FPDMA QUEUED
  60 01 00 00 28 00 01 b0 98 53 c0 40 00 43d+13:30:44.919  READ FPDMA QUEUED
  60 01 00 00 20 00 01 b0 98 52 c0 40 00 43d+13:30:44.919  READ FPDMA QUEUED
  60 01 00 00 18 00 01 b0 98 51 c0 40 00 43d+13:30:44.919  READ FPDMA QUEUED
Error 30 [5] occurred at disk power-on lifetime: 32894 hours (1370 days + 14 hours)
  40 -- 51 00 00 00 01 b0 96 66 98 40 00  Error: UNC at LBA = 0x1b0966698 = 7257613976
  60 01 00 00 38 00 01 b0 96 6d 98 40 00 43d+13:30:38.249  READ FPDMA QUEUED
  60 01 00 00 30 00 01 b0 96 6c 98 40 00 43d+13:30:38.249  READ FPDMA QUEUED
  60 01 00 00 28 00 01 b0 96 6b 98 40 00 43d+13:30:38.249  READ FPDMA QUEUED
  60 01 00 00 20 00 01 b0 96 6a 98 40 00 43d+13:30:38.249  READ FPDMA QUEUED
  60 01 00 00 18 00 01 b0 96 69 98 40 00 43d+13:30:38.249  READ FPDMA QUEUED
Error 29 [4] occurred at disk power-on lifetime: 32842 hours (1368 days + 10 hours)
  40 -- 51 00 00 00 01 b0 9a 42 50 40 00  Error: UNC at LBA = 0x1b09a4250 = 7257866832
  60 00 10 00 90 00 02 ba a0 f2 90 40 00 41d+09:24:50.900  READ FPDMA QUEUED
  60 00 10 00 88 00 02 ba a0 f0 90 40 00 41d+09:24:50.900  READ FPDMA QUEUED
  60 00 10 00 80 00 00 00 40 02 90 40 00 41d+09:24:50.900  READ FPDMA QUEUED
  60 01 00 00 78 00 01 b0 9a 54 10 40 00 41d+09:24:50.900  READ FPDMA QUEUED
  60 01 00 00 38 00 01 b0 9a 53 10 40 00 41d+09:24:50.900  READ FPDMA QUEUED
Error 28 [3] occurred at disk power-on lifetime: 32842 hours (1368 days + 10 hours)
  40 -- 51 00 00 00 01 b0 9a 38 88 40 00  Error: UNC at LBA = 0x1b09a3888 = 7257864328
  60 01 00 00 78 00 01 b0 9a 48 a0 40 00 41d+09:24:42.564  READ FPDMA QUEUED
  60 01 00 00 70 00 01 b0 9a 47 a0 40 00 41d+09:24:42.564  READ FPDMA QUEUED
  60 01 00 00 68 00 01 b0 9a 46 a0 40 00 41d+09:24:42.564  READ FPDMA QUEUED
  60 01 00 00 60 00 01 b0 9a 45 a0 40 00 41d+09:24:42.564  READ FPDMA QUEUED
  60 01 00 00 58 00 01 b0 9a 44 a0 40 00 41d+09:24:42.564  READ FPDMA QUEUED
Error 27 [2] occurred at disk power-on lifetime: 32842 hours (1368 days + 10 hours)
  40 -- 51 00 00 00 01 b0 99 88 28 40 00  Error: UNC at LBA = 0x1b0998828 = 7257819176
  60 01 00 00 38 00 01 b0 99 8e 78 40 00 41d+09:24:35.313  READ FPDMA QUEUED
  60 01 00 00 30 00 01 b0 99 8d 78 40 00 41d+09:24:35.313  READ FPDMA QUEUED
  60 01 00 00 28 00 01 b0 99 8c 78 40 00 41d+09:24:35.313  READ FPDMA QUEUED
  60 01 00 00 20 00 01 b0 99 8b 78 40 00 41d+09:24:35.313  READ FPDMA QUEUED
  60 01 00 00 18 00 01 b0 99 8a 78 40 00 41d+09:24:35.313  READ FPDMA QUEUED
Error 26 [1] occurred at disk power-on lifetime: 32842 hours (1368 days + 10 hours)
  40 -- 51 00 00 00 01 b0 99 7d a8 40 00  Error: UNC at LBA = 0x1b0997da8 = 7257816488
  60 01 00 00 68 00 01 b0 99 84 78 40 00 41d+09:24:28.322  READ FPDMA QUEUED
  60 01 00 00 08 00 01 b0 99 83 78 40 00 41d+09:24:28.322  READ FPDMA QUEUED
  60 01 00 00 60 00 01 b0 99 82 78 40 00 41d+09:24:28.311  READ FPDMA QUEUED
  60 01 00 00 58 00 01 b0 99 81 78 40 00 41d+09:24:28.311  READ FPDMA QUEUED
  60 01 00 00 50 00 01 b0 99 80 78 40 00 41d+09:24:28.311  READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed: read failure	   10%	 32904		 7257864096
# 2  Extended offline	Completed: read failure	   40%	 32893		 7257613976
# 3  Conveyance offline  Completed without error	   00%	 32886		 -
# 4  Short offline	   Completed: read failure	   10%	 32885		 7257861504
# 5  Short offline	   Completed: read failure	   10%	 32880		 7257859088
# 6  Extended offline	Completed: read failure	   40%	 32876		 7204548288
# 7  Short offline	   Completed without error	   00%	 32856		 -
# 8  Short offline	   Completed without error	   00%	 32832		 -
# 9  Short offline	   Completed without error	   00%	 32808		 -
#10  Short offline	   Completed without error	   00%	 32784		 -
#11  Short offline	   Completed without error	   00%	 32760		 -
#12  Short offline	   Completed without error	   00%	 32736		 -
#13  Short offline	   Completed without error	   00%	 32712		 -
#14  Extended offline	Completed: read failure	   40%	 32709		 7204535024
#15  Short offline	   Completed without error	   00%	 32688		 -
#16  Short offline	   Completed without error	   00%	 32664		 -
#17  Short offline	   Completed without error	   00%	 32640		 -
#18  Short offline	   Completed without error	   00%	 32616		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SCT Status Version:				  3
SCT Version (vendor specific):	   258 (0x0102)
SCT Support Level:				   1
Device State:						Active (0)
Current Temperature:					31 Celsius
Power Cycle Min/Max Temperature:	 28/41 Celsius
Lifetime	Min/Max Temperature:	  2/42 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:	 2
Temperature Sampling Period:		 1 minute
Temperature Logging Interval:		1 minute
Min/Max recommended Temperature:	  0/60 Celsius
Min/Max Temperature Limit:		   -41/85 Celsius
Temperature History Size (Index):	478 (92)
Index	Estimated Time   Temperature Celsius
  93	2018-10-30 09:55	32  *************
 ...	..( 14 skipped).	..  *************
 108	2018-10-30 10:10	32  *************
 109	2018-10-30 10:11	31  ************
 ...	..(  6 skipped).	..  ************
 116	2018-10-30 10:18	31  ************
 117	2018-10-30 10:19	32  *************
 ...	..( 21 skipped).	..  *************
 139	2018-10-30 10:41	32  *************
 140	2018-10-30 10:42	31  ************
 ...	..( 17 skipped).	..  ************
 158	2018-10-30 11:00	31  ************
 159	2018-10-30 11:01	33  **************
 ...	..( 18 skipped).	..  **************
 178	2018-10-30 11:20	33  **************
 179	2018-10-30 11:21	34  ***************
 ...	..(  9 skipped).	..  ***************
 189	2018-10-30 11:31	34  ***************
 190	2018-10-30 11:32	33  **************
 ...	..(  6 skipped).	..  **************
 197	2018-10-30 11:39	33  **************
 198	2018-10-30 11:40	32  *************
 ...	..(  7 skipped).	..  *************
 206	2018-10-30 11:48	32  *************
 207	2018-10-30 11:49	31  ************
 ...	..( 16 skipped).	..  ************
 224	2018-10-30 12:06	31  ************
 225	2018-10-30 12:07	32  *************
 ...	..( 11 skipped).	..  *************
 237	2018-10-30 12:19	32  *************
 238	2018-10-30 12:20	33  **************
 ...	..( 25 skipped).	..  **************
 264	2018-10-30 12:46	33  **************
 265	2018-10-30 12:47	32  *************
 ...	..( 13 skipped).	..  *************
 279	2018-10-30 13:01	32  *************
 280	2018-10-30 13:02	33  **************
 ...	..( 42 skipped).	..  **************
 323	2018-10-30 13:45	33  **************
 324	2018-10-30 13:46	32  *************
 ...	..( 10 skipped).	..  *************
 335	2018-10-30 13:57	32  *************
 336	2018-10-30 13:58	33  **************
 ...	..(  7 skipped).	..  **************
 344	2018-10-30 14:06	33  **************
 345	2018-10-30 14:07	34  ***************
 346	2018-10-30 14:08	33  **************
 ...	..( 28 skipped).	..  **************
 375	2018-10-30 14:37	33  **************
 376	2018-10-30 14:38	32  *************
 ...	..(  5 skipped).	..  *************
 382	2018-10-30 14:44	32  *************
 383	2018-10-30 14:45	33  **************
 ...	..( 27 skipped).	..  **************
 411	2018-10-30 15:13	33  **************
 412	2018-10-30 15:14	34  ***************
 ...	..( 68 skipped).	..  ***************
   3	2018-10-30 16:23	34  ***************
   4	2018-10-30 16:24	33  **************
 ...	..( 24 skipped).	..  **************
  29	2018-10-30 16:49	33  **************
  30	2018-10-30 16:50	32  *************
 ...	..(  4 skipped).	..  *************
  35	2018-10-30 16:55	32  *************
  36	2018-10-30 16:56	33  **************
 ...	..( 52 skipped).	..  **************
  89	2018-10-30 17:49	33  **************
  90	2018-10-30 17:50	32  *************
  91	2018-10-30 17:51	32  *************
  92	2018-10-30 17:52	32  *************
SCT Error Recovery Control:
		   Read:	 70 (7.0 seconds)
		  Write:	 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID	  Size	 Value  Description
0x0001  2			0  Command failed due to ICRC error
0x0002  2			0  R_ERR response for data FIS
0x0003  2			0  R_ERR response for device-to-host data FIS
0x0004  2			0  R_ERR response for host-to-device data FIS
0x0005  2			0  R_ERR response for non-data FIS
0x0006  2			0  R_ERR response for device-to-host non-data FIS
0x0007  2			0  R_ERR response for host-to-device non-data FIS
0x0008  2			0  Device-to-host non-data FIS retries
0x0009  2		   22  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2		  136  Device-to-host register FISes sent due to a COMRESET
0x000b  2			0  CRC errors within host-to-device FIS
0x000f  2			0  R_ERR response for host-to-device data FIS, CRC
0x0012  2			0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4	  8097004  Vendor specific
is it the drive or do I need to talk my family through swapping the SATA cable first?
Mihalich
You have a problem with the disk.
Cable's fine.
PS Maybe die disk heads.
If SMART is telling you you have read errors:
Then it can only be the disk... SMART is run by the disk on the disk, so eliminates cabling and ports.
Chris Moore
That is all you should have needed to see.
In addition to what's already been pointed out, these also point to the disk.
Baenwort
And confirmed to be disk. I had a hotspare swap in automatically and over thanksgiving I'll pull the dead drive for warranty repair.
