how to recavery password
plz can any body help me how i can recovery password in freenas
i cant access the freenas be web because i forget the password
Then go to the machine locally. There's a menu option #7 that will reset your GUI login credentials.
If you don't have a keyboard and monitor hooked up to the computer, then you are out of luck. That's the only way....
joeschmuck
Old Man
I don't have the ability to move this to the help thread, can someone move it. It does not belong in the Announcements area.
