[How-To] Manually upgrade mono from 5.10 to 5.20 in a FreeNAS Jail
rknaub
Member
Thanks for the guide, followed it perfectly and didn't run into any issues that I could tell. However, after I restarted the jail it will no longer load the Lidarr page. It pings, but wont load. Deleted my lidarr jail and installed a fresh one, then followed this guide again with the same issue.
FreeNAS 11.3u1
zperetz
Member
Thanks for the guide, followed it perfectly and didn't run into any issues that I could tell. However, after I restarted the jail it will no longer load the Lidarr page. It pings, but won't load. Deleted my lidarr jail and installed a fresh one, then followed this guide again with the same issue.
FreeNAS 11.3u1
Try to do in lidarr (where mono will actually work) jail:
fetch https://curl.haxx.se/ca/cacert.pem -o /tmp
/usr/local/bin/cert-sync /tmp/cacert.pem
and restart the jail.
ARRRRGGGGHHH
Member
On a fresh jail fails when doing Hsot 11.3-u1 jail 11.3-p7
"/usr/ports/lang/mono # make -DBATCH install clean"
Gives following error.
root@SRT-New:/usr/ports/lang/mono # make -DBATCH install clean
===>  Installing for mono-5.20.1.34_3
===>  Checking if mono is already installed
===>   Registering installation for mono-5.20.1.34_3
pkg-static: Unable to access file /usr/ports/lang/mono/work/stageusr/local/%%HEAPVIZ%%bin/mono-heapviz:No such file or directory
*** Error code 74
Stop.
make: stopped in /usr/ports/lang/mono
Any ideas?
zperetz
Member
*** Error code 74
Somehow /usr/ports/lang/mono/work/stageusr/local/%%HEAPVIZ%%bin/mono-heapviz compiled as wrong path. I would recommend to find the file with wrong instruction and change it manually (edit to right path or delete)
bartdesign
Newbie
There are two files i needed to change to fix this.
grep -r %%HEAPVIZ%% /usr/ports/lang/mono/*
To find them, remove the %%HEAPVIZ%% text and save and recompile.
roenlond
Newbie
Thanks a ton! That solved my issues. To be clear, you need to edit the found files in a text editor (nano for example) and remove the %%HEAPVIZ%% text, for me it was these two files:
/usr/ports/lang/mono/pkg-plist
/usr/ports/lang/mono/work/.PLIST.mktmp
dgcurtis
Newbie
I've been going around and around on this. I tried the 5.20 instructions multiple times but kept having issues so now I'm trying the 6.8 steps. The patch file has a lot of lines that begin with "%%PPC%%" and "%%NO_PPC%%". Are they supposed to be there? Are there any repositories that offer mono already compliled? Thanks
dgcurtis
Newbie
Thanks for that. I'm a linux guy and working in freebsd is a bit different.
zamana
Member
Message #75 has packages for update via pkg.
Hi!
Instead of trying to compile mono myself, I decided to use the package from the message #75.
I uninstalled the stock mono (5.10) and installed the 6.8.105 version to test in my Jackett jail.
After this Jackett was up and running, but it was unable to test all my Indexers. An example:
2020-04-26 13:12:34.7103 Error Jackett.Common.IndexerException: Exception (1337x): Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED
at /usr/ports/lang/mono/work/mono-6.8.0.105/external/boringssl/ssl/handshake_client.c:1132 ---> System.Net.Http.HttpRequestException: The SSL connection could not be establi
at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00048] in <a02834dd37054d85a3a6cea43dcb4dcb>:0
at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <a02834dd37054d85a3a
at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool)
at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <a02834dd37054d85a3a6cea43dcb4dcb>:0
at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <a02834dd37054d85a3a6cea43dcb4dcb>:0
--- End of inner exception stack trace ---
at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threadi
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore (System.IO.Stream stream, System.Net.Security.SslClientAuthenticationOptions sslOptions, System.Threading.Ca
at System.Net.Http.HttpConnectionPool.CreateConnectionAsync (System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) [0x00322] in <
at System.Net.Http.HttpConnectionPool.WaitForCreatedConnectionAsync (System.Threading.Tasks.ValueTask`1[TResult] creationTask) [0x000a2] in <28f499dad82444d1b9c9d01dc98b44d6
at System.Net.Http.HttpConnectionPool.SendWithRetryAsync (System.Net.Http.HttpRequestMessage request, System.Boolean doRequestAuth, System.Threading.CancellationToken cancel
at System.Net.Http.DecompressionHandler.SendAsync (System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) [0x000ca] in <28f499dad8
at CloudflareSolverRe.ClearanceHandler.SendRequestAsync (System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) [0x00090] in <f5c1
at CloudflareSolverRe.ClearanceHandler.SendAsync (System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) [0x000a4] in <f5c188d583e
at System.Net.Http.HttpClient.FinishSendAsyncBuffered (System.Threading.Tasks.Task`1[TResult] sendTask, System.Net.Http.HttpRequestMessage request, System.Threading.Cancella
at Jackett.Common.Utils.Clients.HttpWebClient.Run (Jackett.Common.Utils.Clients.WebRequest webRequest) [0x0048a] in <3cc60d4069ca4eb2a48188474494f73e>:0
at Jackett.Common.Utils.Clients.WebClient.GetString (Jackett.Common.Utils.Clients.WebRequest request) [0x0010b] in <3cc60d4069ca4eb2a48188474494f73e>:0
at Jackett.Common.Indexers.BaseWebIndexer.RequestStringWithCookies (System.String url, System.String cookieOverride, System.String referer, System.Collections.Generic.Dictio
at Jackett.Common.Indexers.CardigannIndexer.PerformQuery (Jackett.Common.Models.TorznabQuery query) [0x0086f] in <3cc60d4069ca4eb2a48188474494f73e>:0
at Jackett.Common.Indexers.BaseIndexer.ResultsForQuery (Jackett.Common.Models.TorznabQuery query) [0x00091] in <3cc60d4069ca4eb2a48188474494f73e>:0
at Jackett.Common.Indexers.BaseIndexer.ResultsForQuery (Jackett.Common.Models.TorznabQuery query) [0x000ee] in <3cc60d4069ca4eb2a48188474494f73e>:0
at Jackett.Common.Indexers.BaseWebIndexer.ResultsForQuery (Jackett.Common.Models.TorznabQuery query) [0x0006b] in <3cc60d4069ca4eb2a48188474494f73e>:0
at Jackett.Common.Services.IndexerManagerService.TestIndexer (System.String name) [0x000a3] in <3cc60d4069ca4eb2a48188474494f73e>:0
at Jackett.Server.Controllers.IndexerApiController.Test () [0x000e1] in <eaaeba9717bf4318a79c0123fd1e761a>:0
at Microsoft.AspNetCore.Mvc.Internal.ActionMethodExecutor+TaskOfIActionResultExecutor.Execute (Microsoft.AspNetCore.Mvc.Infrastructure.IActionResultTypeMapper mapper, Micros
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeActionMethodAsync () [0x00131] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeNextActionFilterAsync () [0x0009e] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Rethrow (Microsoft.AspNetCore.Mvc.Filters.ActionExecutedContext context) [0x0001b] in <b4ef600f4a594fe2865a8f97f
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Next (Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker+State& next, Microsoft.AspNetCore.Mvc.Internal.C
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeInnerFilterAsync () [0x0002f] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeNextResourceFilter () [0x0009f] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Rethrow (Microsoft.AspNetCore.Mvc.Filters.ResourceExecutedContext context) [0x0001b] in <b4ef600f4a594fe2865a8f97f915fb9
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Next (Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker+State& next, Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker+S
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeFilterPipelineAsync () [0x0002f] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeAsync () [0x0012e] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Builder.RouterMiddleware.Invoke (Microsoft.AspNetCore.Http.HttpContext httpContext) [0x001cb] in <6092a16d93814eba828b517a2b132f80>:0
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke (Microsoft.AspNetCore.Http.HttpContext context) [0x00384] in <427697fe42b7459ba5302fb76d339d3b>:0
at Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware.Invoke (Microsoft.AspNetCore.Http.HttpContext context) [0x0043e] in <f352e566abf6421e87eafbcf57a0b237>:0
at Jackett.Server.Middleware.CustomExceptionHandler.Invoke (Microsoft.AspNetCore.Http.HttpContext httpContext) [0x0008a] in <eaaeba9717bf4318a79c0123fd1e761a>:0  Jackett.Com
Certainly something related whit SSL, but what? What package needs to be installed in this case?
Thanks.
Regards.
jasonsansone
Member
Hi!
Thanks.
Regards.
Is Jackett the most recent build? I have Jackett running on the same indexers without issue.
zamana
Member
Yes. Version 0.16.137.0.
Jackett is running fine. The individual indexers' test that it's failling...
Have you tried?
jasonsansone
Member
Have you tried?
Yes. Just tested. 1337x works fine. That site has multiple urls... which are you using? Can you browse to it from a web browser? The SSL error seems to indicate the site's SSL certificate has expired or been revoked.
zamana
Member
Well... it turns out that you are right.
I upgraded again to mono version 6.8.0.105 and Jackett is running fine, along with all the indexers. Seems it was a circunstancial error that I considered more general.
Thanks for making me test again.
Regards.
minituff
Neophyte
I am currently trying to run the following but I keep getting an error after about an hour:
echo '{"pkgs":["ca_root_nss","llvm80","libepoxy-1.5.2"]}' > /tmp/pkg.json
iocage create -n mono_patch -p /tmp/pkg.json -r 11.3-RELEASE dhcp="on" vnet="on" bpf="yes" boot="on"
rm /tmp/pkg.json
iocage exec mono_patch "fetch 'https://bugs.freebsd.org/bugzilla/attachment.cgi?id=211960' -o /tmp/mono-patch-6.8.0.105"
iocage exec mono_patch "mkdir -p /usr/local/etc/pkg/repos"
iocage exec mono_patch "echo -e 'FreeBSD: { url: \"pkg+http://pkg.FreeBSD.org/\${ABI}/latest\" }' > /usr/local/etc/pkg/repos/FreeBSD.conf"
iocage exec mono_patch "pkg update"
iocage exec mono_patch "pkg upgrade -y"
iocage exec mono_patch "portsnap fetch extract"
iocage exec mono_patch "echo -e 'cd /usr/ports/lang' > /tmp/mono_patch.sh"
iocage exec mono_patch "echo -e 'cp -R mono mono68105' >> /tmp/mono_patch.sh"
iocage exec mono_patch "echo -e 'patch -E < /tmp/mono-patch-6.8.0.105' >> /tmp/mono_patch.sh"
iocage exec mono_patch "echo -e 'cd /usr/ports/lang/mono' >> /tmp/mono_patch.sh"
iocage exec mono_patch "echo -e 'make -DBATCH install' >> /tmp/mono_patch.sh"
iocage exec mono_patch "echo -e 'make -DBATCH package' >> /tmp/mono_patch.sh"
iocage exec mono_patch "echo -e 'mv /usr/ports/lang/mono/work/pkg/mono-6.8.0.105.txz /' >> /tmp/mono_patch.sh"
iocage exec mono_patch "sh /tmp/mono_patch.sh"
root@mono-patch:/usr/ports/lang # mv /usr/ports/lang/mono/work/pkg/mono-6.8.0.105.txz /
mv: rename /usr/ports/lang/mono/work/pkg/mono-6.8.0.105.txz to /mono-6.8.0.105.txz: No such file or directory
None of the guides posted here seem to be working, have they gone outdated in the past few months?
minituff
Neophyte
I actually ended up figuring it out thanks to comment #75 by jasonsansone. The install ran perfectly.
---- How I did it ----
  1. Follow the link (comment #75 by jasonsansone) go to the link and download mono-6.8.0.105.txz
    1. https://www.ixsystems.com/community...20-in-a-freenas-jail.78871/page-4#post-573573
  2. Move the file into your Sonarr jail
    1. I used FileZilla to transfer tile to /tmp/mono-6.8.0.105.txz in my Jail
  3. Install the package (from inside the jail)
    1. pkg install /tmp/mono-6.8.0.105.txz
I was trying to figure all this out to upgrade Sonarr to V3 on my Freenas machine. I created a guide in my reddit post if anyone is interested:
minituff
Neophyte
What shell was used for compilation?
I tried running the commands 1 by 1 in SSH (using the default shell). I also tried saving commands into a mono_patch.run file and I ran it using the bash mono_path.run command.
The commands were executing with both methods. I didn't realize the shell would make a big difference as long as the command was going through. If it makes a difference then I'll be learning something new today.
