How to identify the correct failed USB boot drive
depasseg
FreeNAS Replicant
I received an alert that one of my 2 boot USB drives failed so I'm going to replace it. The problem is I can't figure out which one it is. I have 2 Sandisk Cruzer mini's. Any tips?
With a hard disk, I'd try to dd if=/dev/adaXX and look for the blinky light, but I can't see anything on these things.
Bidule0hm
Server Electronics Sorcerer
The only 100 % reliable way is to use the serial number, however on USB drives it's not written anywhere so unless you wrote it on a sticker placed on the drive you'll not be able do to that.
depasseg
FreeNAS Replicant
I can turn it off and pull them out to see if the S/n is legible.
Of course, I can't even find the corresponding S/n for the failed da1 device in FreeNAS. Grrrr
Bidule0hm
Yep, you can do that, but just be careful to not write a single bit to the stick during the process.
Use my script (link is in my signature) or directly the commands inside it ;)
depasseg
FreeNAS Replicant
Thanks for the reminder, but your scripts don't seem to work for these USB drives. glabel and smartctl come up empty.
[root@freenas2] ~# zpool status -v
  pool: freenas-boot
state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
        Sufficient replicas exist for the pool to continue functioning in a
        degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
        repaired.
  scan: scrub repaired 0 in 0h7m with 0 errors on Tue Oct 13 03:52:41 2015
        freenas-boot  DEGRADED     0     0     0
          mirror-0  DEGRADED     0     0     0
            da1p2   FAULTED      1     1     0  too many errors
            da2p2   ONLINE       0     0     0
errors: No known data errors
  pool: tank2
state: ONLINE
  scan: none requested
        tank2                                           ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/e59fb1bc-8443-11e5-8981-001f33eaf869  ONLINE       0     0     0
            gptid/e6689760-8443-11e5-8981-001f33eaf869  ONLINE       0     0     0
            gptid/e73d4371-8443-11e5-8981-001f33eaf869  ONLINE       0     0     0
            gptid/e819921f-8443-11e5-8981-001f33eaf869  ONLINE       0     0     0
            gptid/e8f87625-8443-11e5-8981-001f33eaf869  ONLINE       0     0     0
            gptid/e9cdb4bc-8443-11e5-8981-001f33eaf869  ONLINE       0     0     0
[root@freenas2] ~# glabel status -s da1p2
glabel: No such geom: da1p2.
[root@freenas2] ~# glabel status -s da2p2
glabel: No such geom: da2p2.
[root@freenas2] ~# smartctl -i /dev/da1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
/dev/da1: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
[root@freenas2] ~#
Bidule0hm
Ah, yes, of course, it's a USB drive, silly me...
So the next question is "how do we get the serial number for a USB drive?", I'll let you search this one :P
depasseg
FreeNAS Replicant
Finally figured it out using a combination of "camcontrol devlist" and "camcontrol inquiry da2" (since da1 is toast, it wasn't responding to any inquiries,duh! smack forehead). dmesg | grep da1 would have worked, but /var/log/messages already rolled over (surprisingly, nothing showed up when running "dmesg".
[root@freenas2] /var/log# dmesg
[root@freenas2] /var/log# camcontrol devlist
<ST6000DX000-1H217Z CC48>          at scbus0 target 0 lun 0 (ada0,pass0)
<ST6000DX000-1H217Z CC48>          at scbus1 target 0 lun 0 (ada1,pass1)
<ST6000DX000-1H217Z CC48>          at scbus2 target 0 lun 0 (ada2,pass2)
<ST6000DX000-1H217Z CC48>          at scbus3 target 0 lun 0 (ada3,pass3)
<ST6000DX000-1H217Z CC48>          at scbus4 target 0 lun 0 (ada4,pass4)
<ST6000DX000-1H217Z CC48>          at scbus5 target 0 lun 0 (ada5,pass5)
<SMI USB DISK 1100>                at scbus7 target 0 lun 0 (pass6,da0)
<SanDisk Cruzer Fit 1.27>          at scbus8 target 0 lun 0 (pass7)
<KVM vmDisk-CD 0.01>               at scbus9 target 0 lun 0 (pass8,cd0)
<SanDisk Cruzer Fit 1.27>          at scbus10 target 0 lun 0 (pass9,da2)
[root@freenas2] /var/log# camcontrol inquiry 8:0:0
[root@freenas2] /var/log# camcontrol inquiry 10:0:0
pass9: <SanDisk Cruzer Fit 1.27> Removable Direct Access SCSI-6 device
pass9: Serial Number 4C53000123819101112
pass9: 40.000MB/s transfers
[root@freenas2] /var/log# camcontrol inquiry da2
pass9: Serial Number 4C5302234567819101112
depasseg
FreeNAS Replicant
Upon further review, even this method doesn't work, since the serial number reported by camcontrol doesn't match the serial number printed on either USB drive (not even close to the right format). I'm just going to roll the dice and pull one to see what message pops up in the console (the new USB detected alert).
Bidule0hm
Yeah, but you can plug the USB stick in another PC and read its S/N to see which is which.
depasseg
FreeNAS Replicant
I tried that. The numbers are completely different.
For instance, here are the serial numbers from camcontrol:
4C530102841224103441
4C530009340819108345
And here are the serial numbers printed on the USB sticks:
BM140824736V
BM141224736V
Anyone see a pattern?
Robert Smith
Perhaps, larger number on the inside corresponds to the larger number on the outside, and vice versa…
But yea, wow. I think we need a recommendation to mark USB drives before usage, or to use different brands/models together for easy identification which is which.
If you can import the USBs one at a time on another FreeNAS, you should be able to figure out which one shows as healthy with the second drive missing. I am just not completely sure that the second FreeeNAS won’t try writing anything to the stick.
Bidule0hm
Yes, but we are (as humans) pretty good at finding pattern who doesn't mean anything, so...
BM140824736V
BM141224736V
rogerh
Take one out and see if the machine boots? If not, its the other one you want.
joeschmuck
Old Man
That is exactly what I'd do. Also, just because FreeNAS said it failed, I'd take the failing device and verify it just didn't become corrupt and verify there is a hardware failure. If you find out that the device did fail, next you should ask yourself why did it fail, too much writing? If the device was only corrupt (not hardware failures) then I'd submit a bug report about the drive corruption and watch to see if the new boot device fails.
depasseg
FreeNAS Replicant
That's actually what I ended up doing (shutting down, pulling one out, starting up, shut down, start with the other). Of course they were both ok at that point. I ran a scrub and 132KB was corrected on one drive. I'll keep an eye on it and if it gets worse/happens again I'll replace it.
joeschmuck
Old Man
My concern is possible data corruption caused by FreeNAS and is the only reason I think you should check the USB flash drive to ensure it was a hardware failure. You could test it with some dd command or maybe on a different computer using some throughput test and loop it for several hours. I think it would be good to rule out FreeNAS software as the culprit.
depasseg
FreeNAS Replicant
I should mention that I have mirrored USB drives running ZFS. Wouldn't the scrub correct the corruption?
joeschmuck
Old Man
You would think it should. If you run into more corruption though you should find out if its software causing it or hardware. It could be difficult to track down without quality testing equipment to measure signal response times. Eh, might be more trouble than it's worth unless it's an obvious failure.
melloa
Hey, @joeschmuck, did any of the above changed? In other words, any way to identify the failed USB to be replaced?
  • Like
Reactions: cmh
cmh
Dealing with the same, asked on the FB group and was directed here. (by melloa, it looks like!) I think I may have lucked out - my Cruzer Fits are 16GB and 8GB. The 8 failed. I think I'll just power down and look for the 8G.
Also think I'm going to mix brands from now on.
Now, when I swap out the failed one and resilver, do I have to do anything extra in terms of making the new one bootable? I know (or assume) the current one is bootable, so if I resilver and then the current good one fails, will I be able to boot the system?
