aftereffectsmagic
- Nov 3, 2016
Hi there,
Still working on sourcing parts for my ESXi and FreeNAS (as a VM) build. I am loosely following Stux's AIO build guide (a great resource, to be sure)!
I came across some info saying that ESXi can be booted from a 32 GB Sandisk Cruzer Fit USB 3.0 drive (older reported issues with this seem to be resolved). So would it be absurd for me to go ahead and get three 32 GB Cruzer Fit USB drives, two for a mirrored FreeNAS install, and one to be used as the ESXi boot device? My X8DTU has eight USB 2.0 connectors.
I realize this may hinge on whether or not my datastore will be mostly static- if anyone has a baseline comparison chart or some insight I can use so I can better understand whether my ESXi datastore will be mostly static or not that would be great. My feeling is that it will be mostly static, from the info I've read.
Another option is to go for a 32 GB Intel Optane M.2 drive for the ESXi boot, keep two USBs for the FreeNAS boot, and source an adapter so it can be used with my PCIe riser card on my X8DTU motherboard. This would be the second least expensive option.
Thanks for your quick suggestions / tips! Clearly new to all of this, so am open to all of your recommendations :)
