Keven
- Aug 10, 2016
hi,
it's been a couple time i receive this email
* Boot pool status is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected..
my boot pool is running on a mirror 2 usb drive. the first is a 8GB Sony (7-8 years old) and the second is a sandisk cruzer 16GB (1 years old). I suspect that it is the Sony that is starting to go away, but because i can't run smart test on usb drive i cannot be sure. anyway i have decide to made the switch to an SSD since they become so cheap. now i want to replace the Sony, but i don't see how to identify the sony usb in the "Boot Pool Status" page. i only see the mirror with 2 gptid device, but it is not matching the serial number of my usb drive...
i don't know how to find the gptid of the usb drive in the shell.
one of the email i received mentioning the boot pool error said the following
pool: freenas-boot
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
see: http://illumos.org/msg/ZFS-8000-9P
scan: scrub repaired 0 in 0 days 00:28:51 with 0 errors on Thu Apr 2 04:13:51 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/4ac8579a-46b8-11e9-a905-0cc47a855da0 ONLINE 0 0 0
gptid/4ae916a8-46b8-11e9-a905-0cc47a855da0 ONLINE 0 0 2
also side question. Is it possible to run a mirror of 3 drive for the boot pool?
| freenas-boot | 0 | 0 | 0 | ONLINE | |
| mirror | 0 | 0 | 0 | ONLINE | |
| /dev/gptid/4ac8579a-46b8-11e9-a905-0cc47a855da0 | 0 | 0 | 0 | ONLINE | more_vert |
| /dev/gptid/4ae916a8-46b8-11e9-a905-0cc47a855da0 | 0 | 0 | 0 | ONLINE | more_vert |
pool: freenas-boot
state: ONLINE
