how to change hdd and migrate data
gudvin.dll
i have a problem.
one of the disks broken
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA																																							 _of_first_error
# 1  Extended offline	Completed: read failure	   90%	 10763		 189																																							 7052224
# 2  Short offline	   Completed: read failure	   90%	 10754		 189																																							 7052224
# 3  Extended offline	Completed: read failure	   90%	 10751		 189																																							 7052224
# 4  Extended offline	Completed: read failure	   90%	 10601		 185																																							 8593584
# 5  Short offline	   Completed: read failure	   90%	 10592		 185																																							 8593584
# 6  Extended offline	Completed: read failure	   90%	 10589		 185																																							 8593584
# 7  Short offline	   Completed without error	   00%	 10520		 -
# 8  Extended offline	Completed: read failure	   80%	 10434		 136																																							 3341720
# 9  Short offline	   Completed without error	   00%	 10424		 -
#10  Extended offline	Completed: read failure	   80%	 10422		 136																																							 3341712
#11  Short offline	   Completed without error	   00%	 10352		 -
#12  Extended offline	Completed: read failure	   80%	 10290		 136																																							 3341712
#13  Extended offline	Completed: read failure	   80%	 10278		 136																																							 3341712
#14  Short offline	   Completed without error	   00%	 10256		 -
#15  Short offline	   Completed without error	   00%	 10184		 -
#16  Extended offline	Completed: read failure	   80%	 10170		 136																																							 3341712
#17  Extended offline	Completed: read failure	   80%	 10159		 136																																							 3341712
#18  Short offline	   Completed without error	   00%	 10089		 -
#19  Short offline	   Completed without error	   00%	 10088		 -
#20  Extended offline	Completed: read failure	   40%	 10029		 425																																							 5221840
#21  Extended offline	Completed: read failure	   40%	 10018		 425
root@freenas:~ # zpool list
NAME		   SIZE  ALLOC   FREE  EXPANDSZ   FRAG	CAP  DEDUP  HEALTH  ALTROOT
freenas-boot  83.5G  8.11G  75.4G		 -	  -	 9%  1.00x  ONLINE  -
media		 2.72T   468G  2.26T		 -	 3%	16%  1.00x  ONLINE  /mnt
storage	   2.72T   840G  1.90T		 -	 4%	30%  1.00x  ONLINE  /mnt
dies a media pool
i need change disk and migrate all data to new hdd.
how to do it?
I think that this is done by the command zpool export , but i'm newbie to zfs and i'm afraid to spoil my data
gpsguy
Active Member
How are your pools configured? Please post the output of zpool status.
Chris Moore
While you are getting the pool layout, also give us a full rundown of the hardware you are using.
gudvin.dll
Intel(R) Pentium(R) CPU G3420 @ 3.20GHz
8 gb ddr3
hdd 1
Device Model: ST3000VX000-1CU166
Serial Number: W1F3HDTP
hdd 2
Device Model: WDC WD30EFRX-68N32N0
Serial Number: WD-WCC7K7EJH2SC
sys hdd
Device Model: OCZ-AGILITY2
Serial Number: OCZ-780JM4IH4RFZDO2N
gudvin.dll
root@freenas:~ # zpool status
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:00:48 with 0 errors on Thu Apr 19 03:45:48																																							  2018
		NAME		STATE	 READ WRITE CKSUM
		freenas-boot  ONLINE	   0	 0	 0
		  ada0p2	ONLINE	   0	 0	 0
errors: No known data errors
  pool: media
 state: ONLINE
		corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
		entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 0 days 00:47:03 with 0 errors on Mon Apr 16 16:02:40																																							  2018
		media										 ONLINE	   0	 0	 0
		  gptid/f031fe8c-0dc0-11e8-b716-74d435ec1d7f  ONLINE	   0	 0	 0
errors: 3 data errors, use '-v' for a list
  pool: storage
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:14:12 with 0 errors on Sun Mar 18 00:14:13																																							  2018
		storage									   ONLINE	   0	 0	 0
		  gptid/69b69a14-0db5-11e8-b716-74d435ec1d7f  ONLINE	   0	 0	 0
root@freenas:~ #
Well, you already have some data corruption on your media pool, and that may prevent doing the disk replacement--if your data is of any value to you, you really need to set up a pool with redundancy. But be that as it may, by far the easiest thing to do is what @garm suggested--replace the disk through the GUI. Power down the system, plug in the new disk (don't remove the old one yet), and reboot. Go to Storage in the GUI, click the Media volume, click Volume Status (the button at the bottom that looks like a sheet of notebook paper). Select the one disk that's part of the pool and click Replace Disk at the bottom. In the window that pops up, select your new disk from the drop-down, and click Replace. Wait for the resilver to complete, and cross your fingers.
gudvin.dll
  pool: media
 state: ONLINE
status: One or more devices is currently being resilvered.  The pool will
		continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Tue Apr 24 20:22:53 2018
		470G scanned at 288M/s, 209G issued at 128M/s, 470G total
		209G resilvered, 44.47% done, 0 days 00:34:46 to go
		media										   ONLINE	   0	 0	 0
		  replacing-0								   ONLINE	   0	 0	 0
			gptid/bd1299c3-47db-11e8-88ca-74d435ec1d7f  ONLINE	   0	 0	 0  (resilvering)
		/mnt/media/temp/ubuntu-17.10.1-server-amd64.iso.part
		/mnt/media/temp/House.M.D.s06e10.rus.LostFilm.TV.avi
		/mnt/media/Serials/House_MD/House M.D. 2 - LostFilm.TV/House.M.D.s02e11.rus.LostFilm.TV.avi
That's looking good. Once the resilver completes, the old disk will be taken offline automatically. At a convenient time, you can down the server and remove it.
Chris Moore
The damaged files can't be fixed. You might want to consider deleting them and getting replacement versions.
It is pretty easy to add mirror drives to the single drive pools that you have. That should give you some protection from faults like this in the future.
PhilipS
You also have two 3GB disks with plenty of free space - any reason they were not setup as mirrors to begin with?
