emk2203
- Nov 11, 2012
I am running transmission in a jail and would like to have the resulting downloaded files to have a different owner than the transmission user.
I know that I can run transmission as a different user by adding transmission_user and transmission_group to the jail's rc.conf, but then I have one user owning all of the files. I want to be able to assign different file owners per script.
What is the proper way to do this? For file ownership to change, the script would need to use sudo or run as root. I am hesitating because sudo is not even a part of the jail environment, I fear glaring security issues if I just install sudo or run the script with suid as root.
