How to build your own Bitwarden_rs jail
testcb00
Ghost231, I find that I cannot use the following code to make to IP as variable
export DEFAULT_INTERFACE=$(route get 1.1.1.1 | grep interface | cut -d \  -f 4)
export DEFAULT_IP=$(ifconfig $DEFAULT_INTERFACE | grep 'inet' | awk -F ' ' '{ print $2 }')
I replace the DEFAULT_IP to my Intranet IP and try to generate a self-signed cert by these command and get
root@bitwarden:~/CA # openssl req -new -sha512 -nodes -out server.csr -newkey rsa:8192 -keyout server.key -config <(cat server_rootCA.csr.cnf)
Missing name for redirect.
Do I have misunderstanding in the step?
da_da
Is it possible to serve multiple IP's
one for management internal and one for external connections...
Also, is there way to place the vault outside the jail?
da_da
Found the answer for the DATA location.
Need to mount the location of the data to /usr/local/www/vaultwarden/data/
raidflex
I am still running Truenas Core, and only use jails not docker. Is still the most up to date guide on setting up and configuring a Bitwarden local server?
testcb00
The package name is changed to vaultwarden and you might not need to follow the guide.
I use simple method, create a Base Jail with allow_raw_sockets
# install required package pkg install -y vim bash vaultwarden nginx
# edit your nginx server config vim /usr/local/etc/nginx/nginx.conf
# create vhost for vaultwarden vim /usr/local/etc/nginx/conf.d/vaultwarden.conf
# copy vaultwarden environment setting cp /usr/local/etc/rc.conf.d/vaultwarden.sample /usr/local/etc/rc.conf.d/vaultwarden
# edit vaultwarden environment, set SIGNUPS_ALLOWED to true and enable logging vim /usr/local/etc/rc.conf.d/vaultwarden LOG_FILE='/usr/local/www/vaultwarden/data/bitwarden.log' export LOG_FILE SIGNUPS_ALLOWED='true'
# add vaultwarden & nginx to rc.d and start service sysrc vaultwarden_enable=YES && \ sysrc nginx_enable=YES && \ service vaultwarden start && \ service nginx start
Remind that you need SSL Certificate for https connection. I buy a cheap domain and use Let's Encrypt to get the Certificate (though I need to renew each 3 months). Using the Certificate with correct DNS Resolver setting, the https function well.
victort
One issue with this is that to get SMTP working you need to change one option in the vaultwarden file as per this github post.
in /usr/local/etc/rc.conf.d/vaultwarden you need to change SMTP_SSL to SMTP_SECURITY and use either starttls force_tls or off
victort
I use vaultwarden with caddy, behind a caddy reverse proxy that automatically handles certificates for me.
victort
I have created a script to automate the install of Vaultwarden here based off of @danb35 scripts.
