I have used https://www.ixsystems.com/community...in-a-jail-for-local-useage.73583/#post-510078 as a reference.
But wanted to avoid ruby and rubywarden and also wanted to use https://github.com/dani-garcia/bitwarden_rs
The setup is for local lan + vpn access, do not open it to the internet.
I have tested it with
Using the server with native bitwarden apps eg. iOS/firefox. With this setup nothing goes to their servers.
The post follows the building process described on https://github.com/dani-garcia/bitwarden_rs/wiki/Building-binary
Make sure to:
* Fill in Certificate details, or not (just enter through)
* Letsencrypt if dns is working on your local host
ssh into your freenas host
In this sample I used my own ca but there is an other solution with LetsEncrypt https://wiki.freebsd.org/BernardSpil/LetsEncrypt
If you need web-vault, we will build it here
Install dependencies and fix some issues.
Finally build the web-vault
At this point we have every componets and will have to put them together
Let's setup our nginx fronted server.
Create the bitwardenrs init script
If you made it here, you will have a working self singed cerificate "protected" web-vault with a working bitwarden_rs backend.
But because its a self signed cert you will have to import your CA cert into every client.
Make sure to:
# create your jai as root and login sudo iocage create -n bitwarden -r 11.2-RELEASE vnet="on" boot="on" dhcp="on" bpf="yes" sudo iocage console bitwarden
# install runtime and build dependencies, this will ask some questions, jus say Y pkg install sqlite3 nginx git sudo vim-tiny bash node npm python27-2.7.17_1
# some npm dependency will need to have python2.7 and will fail with python3 cd /usr/local/bin/ # set the symlink ln -s /usr/local/bin/python2.7 python cd -
# Add new bitwardenrs user to the jail echo "Set the user below to: bitwardenrs" echo "Enter every line, no need for other configs, only your password echo adduser -s bash
# allow sudo, we will use it later visudo # ADD bitwardenrs ALL=(ALL) ALL # change to the new user to build and execute our service su bitwardenrs cd id # should look like: uid=1001(bitwardenrs) gid=1001(bitwardenrs) groups=1001(bitwardenrs)
# install latest rust version, pkg version is outdated and can't build bitwarden_rs curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh # include the rust env variables source $HOME/.cargo/env
mkdir CA
cd CA
# generate the CA key
openssl genrsa -out server_rootCA.key 4096
# create certificate request
openssl req -x509 -new -nodes -key server_rootCA.key -sha256 -days 3650 -out server_rootCA.pem
# discover the default interface and its ip address (will only work with internet access)
export DEFAULT_INTERFACE=$(route get 1.1.1.1 | grep interface | cut -d \ -f 4)
export DEFAULT_IP=$(ifconfig $DEFAULT_INTERFACE | grep 'inet' | awk -F ' ' '{ print $2 }')
# construct the CA config file
cat << EOF > server_rootCA.csr.cnf
[req]
default_bits = 4096
prompt = no
default_md = sha256
distinguished_name = dn
[dn]
C=Some
ST=Some
L=Some
O=Some
OU=local_RootCA
emailAddress=.
CN = ${DEFAULT_IP}
EOF
# create the v3 extension config
cat << EOF > v3.ext
authorityKeyIdentifier=keyid,issuer
basicConstraints=CA:FALSE
keyUsage = digitalSignature, nonRepudiation, keyEncipherment, dataEncipherment
subjectAltName = @alt_names
[alt_names]
IP = ${DEFAULT_IP}
EOF
# create the nginx server key
openssl req -new -sha256 -nodes -out server.csr -newkey rsa:4096 -keyout server.key -config <( cat server_rootCA.csr.cnf )
# create the nginx server certificate
openssl x509 -req -in server.csr -CA server_rootCA.pem -CAkey server_rootCA.key -CAcreateserial -out server.crt -days 3650 -sha256 -extfile v3.ext
# copy private key sudo cp server.key /usr/local/etc/nginx/cert.key # copy server.crt sudo cp server.crt /usr/local/etc/nginx/cert.crt
# got back to the users home cd .. echo # and finnaly checkout the latest bitwarden_rs release git clone https://github.com/dani-garcia/bitwarden_rs/ cd bitwarden_rs/ git checkout "$(git tag --sort=v:refname | tail -n1)" # and build it with sqlite support cargo build --features sqlite --release cargo install diesel_cli --no-default-features --features sqlite-bundled cd ..
# WEB-VAULT
# clone the repository
git clone https://github.com/bitwarden/web.git web-vault
cd web-vault
# switch to the latest tag, is not working here, dani-garcia/bw_web_builds lacks v2.12.0 patch
# export WEB_VERSION="$(git tag --sort=v:refname | tail -n1)"
# lets use the last working version
export WEB_VERSION=v2.11.0
git checkout ${WEB_VERSION}
# download and apply the bitwarden_rs patch
curl https://raw.githubusercontent.com/dani-garcia/bw_web_builds/master/patches/${WEB_VERSION}.patch >${WEB_VERSION}.patch
git apply ${WEB_VERSION}.patch -v
# there is no native freebsd version from node-sass 4.11, lets bump it to 4.12.0
cat package.json |sed -e 's/"node-sass": "^4.11.0",/"node-sass": "^4.12.0",/' | tee package.json
# download submodules
npm run sub:init
# manually install angular/compiler-cli
npm i @angular/compiler-cli
# install all the other dependencies
npm install
# sweetalert will fail with the latest angular2 so fix it
# https://github.com/t4t5/sweetalert/issues/738
# PATCH sweetalert.d.ts ....
cat <<EOF >node_modules/sweetalert/typings/sweetalert.d.ts
import swal, { SweetAlert } from "./core";
export default swal;
export as namespace swal;
EOF
npm run dist
cd # copy bitwarden_rs dist cp -r ~/bitwarden_rs/target/release bitwarden_rs_dist cd bitwarden_rs_dist # and copy the web-vault files cp -r ../web-vault/build web-vault
su # be root
bash
# create nginx.conf
cat << EOF >/usr/local/etc/nginx/nginx.conf
worker_processes 1;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
sendfile on;
keepalive_timeout 65;
server {
listen 80;
return 301 https://\$host$request_uri;
server {
listen 443;
server_name localhost;
ssl_certificate /usr/local/etc/nginx/cert.crt;
ssl_certificate_key /usr/local/etc/nginx/cert.key;
ssl on;
ssl_session_cache builtin:1000 shared:SSL:10m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
ssl_prefer_server_ciphers on;
access_log /var/log/nginx/bitwarden_rs_web_vault.log;
location / {
proxy_set_header Host \$host;
proxy_set_header X-Real-IP \$remote_addr;
proxy_set_header X-Forwarded-For \$proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto \$scheme;
proxy_pass http://localhost:8000;
proxy_read_timeout 90;
proxy_redirect http://localhost:8000 https://localhost;
EOF
# enable and start nginx
sysrc nginx_enable="YES"
service nginx start
mkdir -p /usr/local/etc/rc.conf.d/
# limit the rocket server only to localhost
echo "ROCKET_ADDRESS=127.0.0.1" >/usr/local/etc/rc.conf.d/bitwardenrs
cat <<EOF > /usr/local/etc/rc.d/bitwardenrs
#!/bin/sh
# PROVIDE: bitwardenrs
# REQUIRE: LOGIN DAEMON NETWORKING
# KEYWORD: jail rust
# Enable this script by adding:
# bitwardenrs_enable="YES"
# ... to /etc/rc.conf
. /etc/rc.subr
name="bitwardenrs"
rcvar="bitwardenrs_enable"
bitwardenrs_chdir=/home/bitwardenrs/bitwarden_rs_dist
# This is the tool init launches
command="/usr/sbin/daemon"
pidfile="/var/run/\${name}.pid"
# This is the tool daemon launches
task="./bitwarden_rs"
procname="/bin/bash"
command_args="-u bitwardenrs -p \${pidfile} \${task}"
load_rc_config $name
run_rc_command "\$1"
EOF
sudo sysrc bitwardenrs_enable="YES"
sudo chmod +x /usr/local/etc/rc.d/bitwardenrs
sudo service bitwardenrs start
